Question about Nissin Speedlite Di622 TTL Flash for Canon
Why is there no triggering voltage? - Nissin Speedlite Di622 TTL Flash for Canon
What is the voltage measurement fuel injector
The vast majority of fuel injectors are ground controlled. This means that of the two wires going to the injector one is held at steady 12 - 14 volts while the other lead is pulsed to ground by the ECM. This type of injector circuit is called negative trigger. There are, however, a few (European) manufacturers that have used positive or battery voltage trigger injector circuitry in the past. With positive injector trigger, the positive side is the one being triggered by the ECM.
May 24, 2016 | Cars & Trucks
I have Sunpak 622 Super Pro Handle Mount TTL Flash. Would it be compatible with a Pentax K50?
Before you attach it to your camera you must check the trigger voltage first, never use an old flash unit until you check the trigger voltage with a multimeter, most old flash units have a huge trigger voltage that will damage your camera.
Very simple to check the voltage on that Sunpak 622, turn on your volt meter and set it to about 200 volts DC, turn on your Sunpak flash and apply the RED lead to the bottom contact, apply the Black lead to the side of the hot shoe and look for the ground, usually a small metal piece on the side. Now look at the meter, if it shows a voltage of 6 volts or less then it is safe to use on your camera, if voltage is higher, say 12 volts or more, don't use it. A high trigger voltage will certainly mess up your camera in the long run. Even if it has a safe voltage of 6 volts or less, you will only be able to use that flash in Manual Mode, the newer cameras will not sync or recognize an old flash unit.
I have an old Vivitar flash unit that I can safely use on my Canon XTI because the old vivitar has a trigger voltage of 5 volts, safe for all newer digital cameras.
Mar 04, 2015 | Pentax Cameras
Why is my alarm going off intermittently after being locked for no reason throughout the night and day?
Could be a drop in voltage. Alarms sense voltage change to trigger. When you open a door or cause any component to draw voltage while the alarm is activated it will trigger. Apparently something is drawing voltage or causing it to drop while you car is sitting. your battery may be going bad and the voltage is dropping past the benchmark level of the alarm trigger and it is going off. It can happen if the battery is marginal and it gets very cold out or there is a short in a component causing voltage to change.
Feb 12, 2015 | Cars & Trucks
Camera and flash gun trigger voltage
Hi Syd,
Vivitar 2800 and 2800D are two different flashes. The first is an old flash, having high trigger voltage, which, as you will see, still can be used with your Fuji. The second is a member of modern flashes, having a low-voltage release. Manufacturers specify the highest applicable voltage at the trigger (hotshoe or PC) terminal; at most digital cameras it reaches several hundred volts.I believe, this is, what your seller was asking. As far as I know, Fuji doesn't mention this value in the user manual of the Finepix 9500, but I met reports of people, who called Fuji and asked that and the answer was 400 volts!
So the short answer is: buy any wireless trigger if you have the 2800D, and tell the seller the flash has about 200 volts if your flash is an older 2800.
I wonder if you did already use your flash with your Fuji?
Laszlo
Nov 27, 2008 | Cameras
What is the trigger voltage for Pentax AF 500FTZ
When using a digital camera with a flash unit of unknown trigger voltage, you are risking the life of your camera. Excessive trigger voltages can disable the cameras internal circuitry to the point where it is totally beyond repair.
I do not have, in my files. the trigger voltage for the specified flash unit. I only have the specs for larger portables and studio flash gear.
A simple test , however, will reveal the exact trigger voltage. If you have a multi-meter or a DV voltmeter with a 250 VDC range (just to be in the safe side) you can preform this test at home or an electronics service technician can do it for you in a few minutes.
The test lead are placed across the synch contacts on the foot of the unit or plugged into the sunch socket if the flash unit has one. If the reading is more that 4 or 5 volts you can still safely use the flash with the aid of a protector device which goes in between the flash and the camera. Theses are available at better camera shops and dealers.
Ed
Nov 16, 2008 | Pentax AF-500 FTZ TTL Flash
Vivitar trigger voltage
Yes, you can. The flash has a low-voltage trigger circuit.
Laszlo
Nov 14, 2008 | Cameras
Contacts voltage
Originally the 45CT1 had high trigger voltage. In the production period Metz improved it to a much lower voltage release circuit. Metz homepage (metz.de) holds the information, from which serial number on have 45-CT1s low trigger voltage. However, even the high trigger voltage was lower than 200 volts, thus safe for your Fuji.
Laszlo
May 03, 2008 | Metz 45 CL-1 Flash
What is the trigger voltage?
The trigger voltage can take a maximum of 40v. We do not recommended the use of strobes with a higher volage without a voltage regulator or a sync filter.
Aug 29, 2005 | Fuji FinePix S3 Pro Digital Camera
Nissin Speedlite Di622 TTL Flash for Canon Logo
111 people viewed this question
Top Nissin Cameras Experts
jc21680
Level 1 Expert
Doberman
Richard McGrath
Level 1 Expert
Are you a Nissin Camera Expert? Answer questions, earn points and help others
