How do I reset alarm F21? - Washing Machines
    Top Expert:
  • Washing Mach... Master
  • 52,047 Answers
Since you forgot make and model google it yourself we could but without information makes it a mute effort
Posted on Apr 16, 2015
I want to know how can i cleare the erro f21 about siemens washing mechine.
Error f21 happens when the machine does not drain in an appropriate time. This can be caused by a blockage in the drain or a faulty pump. There is a previous post in relation to resetting this error. have siemens washing machine that says f21 what does that mean
Jan 14, 2017 | Siemens Washing Machines
How can I reset alarm F21 on Bosch washing machine type WIM40?
Dear Sir,
it is requested you that we have a washing machine Type: WIM40 & RN # WAE20463tr/12 it has still showing error on display as "F21 alaram" Kindly resolve it or tell us solution that what will be.
Best Regards,
Imran Khan Nawab
May 13, 2012 | Bosch Washing Machines
F21 code still flashes after i've unclogged line - reset?
if you cleaned out the pump by removing the center part of it and it still shows f21,either you didn't clear everything out of the pump,after you pull out the center piece stick your finger inside where the impellar is to see if you feel anything rapped around it,if it's clear and still won't drain then you need to buy a new pump and remove the old pump and install the new pump part number 280187 and it's around 120 dollars http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Washer-Parts/Model-MFW9700SB1/3048/0153200/W0705107/00006?blt=06&prst=&shdMod=
Dec 10, 2011 | Maytag EPIC MFW9700S Front Load Washer
Bosch classixx 6 1400 machine stopped working during cycle f21 on display
F21 relates to a motor or control board fault.
However, it is also caused by spikes in the mains and can be spurious.
To reset it.
Turn the appliance knob to the off or reset position, 12 o'clock.
Turn the knob to the 6 o'clock position.
Press and hold the spin button.
While holding it, turn the knob to the 7 o'clock position.
Continue holding the spin button for about 5 seconds.
Release the button.
Turn the knob to off.
When your turn it back on it should have cleared the error code
Nov 27, 2010 | Bosch Washing Machines
Door wont open f21 alarm
F21 indicates that the washer is having problems draining. Check the drain hose to see if it is kinked or if there is an obstruction in the hose.
SUD comes on every time excessive suds are detected. Not using the proper detergent will set this off faithfully. The machine will run a cycle to remove the excessive suds before completing the wash cycle.
You need to clean the drain filter by removing the 3 screws in the bottom of the front panel. Then you will see a white twist cap. Remove the filter and clean it out.
Mar 09, 2010 | Kenmore Elite 45986 Front Load Washer
I need to reset a sony dvp-f21 to give standard
As far as I know, the output of your dvd is standard. If you're not getting a picture, check you have the correct audio and video leads into the correct plugs on both the dvd player and the scart adaptor, then make sure the scart is pushed fully home in the tv.
Also check that you have the correct input selected on your tv. This is done but pressing the button on your remote that has a square or circle with an arrow through it. Keep pressing it until you see your dvd.
Jan 26, 2010 | Sony DVP-F21 DVD Player
Was ''F35'' now its ''F21''
F21 is drain problem.
Try tripping circuit breaker to reset the appliance.
The next step will be undoing the drain pump hose to check for a blockage.
the pump is accessed removing a panel, usually at the front side of the machine.
Steps are explained on user manual.
Keep a container ready to collect water when you undo pump hose.
Parts and diagrams available here.
Nov 14, 2009 | Kenmore Washing Machines
Suds alarm won't go away. We have gotten the F21 alarm for the drain. We clean it out. It was really soapy in it. We tried unplugging it, so it would reset. what is the next step.thanks
Unplug the unit and try tilting the unit back on a 45 degree angle to see if water leaks out of the base, if so this was the fault, also pour White Vinegar into the dispenser and run through a short cycle to kill any foam. If the unit still doesn't work you may have a coin or hair clip stuck in the drain pump or hose, have you checked the drain pump filter? Get back to me with the result,cheers
Oct 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My IC-F21 portable radio wont communicate with each other. is there a reset?
You will need the programming software to check all settings of the two radios. If both radios are programmed the same then you need to run tests on why they wont communicate to each other. Unfortunatly there is no "reset" for the radios. Carl
Jul 19, 2009 | ICOM Informatique Icom IC-F21 16ch UHF...
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
