Question about Voice Recorders
7 pin or 15 pin foot pedal
Does the Lanier VW 210 use a 15 pin or 7 pin connecter for the foot pedal? Where the foot pedal plugs in has a 7 pin connection, then a space and then an 8 pin connection. I bought this used and it has no instruction manual and I haven't had any luck researching it on the internet.
  • 207 Answers
Re: 7 pin or 15 pin foot pedal
I have a Lanier VW 210 and it uses a 7 pin connector for the foot pedal.
Posted on Sep 18, 2008
0 characters
3 Points
How do I erase the tapes on a Lanier VW-210
Press the telephone button first with one finger and immediately after you press that button press the rewind button, The unit should go into rewind and erase should be flashing on the digital display. When the unit starts rewinding take your finger off of both buttons, if you keep them on ,then the unit will rewind and stop erasing .
Jan 13, 2012 | Lanier Voice Recorders
I need a foot pedal to go with a Lanier P-145 dictation system.
I believe that takes a 5 pin pedal, LX1017. If the connecter has 7 pins, then use the lx0557.
Nov 16, 2011 | Voice Recorders
I have a Lanier Transcriber Model V W-210. Today the fast forward and the reverse did not work. I could hear a motor sound, but the tape did not advance or reverse. The "listen" worked, as did...
This unit most likely has a broken rewind/fast forward rubber belt. This is a very common problem and is easily fixed if you can acquire a new belt. Any place that services Lanier equipment should be able to easily fix this problem.
Sep 20, 2011 | Lanier Voice Recorders
Hello is possible that your power supply is bad or may be just the jack on the unit you have two options you can Send an email to or call (800) 644-9525. Please indicate model, serial and detailed description of problem or try a new power supply at
Apr 14, 2011 | Lanier VW-160D
I have a Lanier model VW 260 transcriber. 1) how do I erase old letters? and 2) does it have the auto rewind feature? (when I release the play pedal it goes back so many seconds) Thank you. Laura...
Hello Laura
Yes your unit has the option for erase Just hold down the REW and Telephone button at the same time make sure that you really want to erase the tape and the auto back space when you relase the foot pedal is the button located inside the front door they called Recall thats for adjusting how long you want to go back. thanks and good luck, if you ever need any type of accssesory please go to at for large selection for professional Transcription units service and accessories
Nov 24, 2010 | Lanier VW-160T
Just started using Lanier model VW 260 transcriber for work. The counter display does not change. The top of the screen shows "Inst", "Length", "Unit No.", Total Units", and "Level". The only numbers it...
Hello the Display work like this insert the tape on the Lanier VW260 with the unit on rewind the tape to the end when you press play the Display start to count
Nov 13, 2009 | Lanier VW-160T
Lanier VW 210 transcriber beeps like it is at the end of the tape
There is a sensor that detects tape movement. Unfortunately they do go bad and will probably need to be replaced.
Nov 26, 2008 | Voice Recorders
Lanier vw-210 dictaphone
It is not a problem at all! The VW-210 & 260 was designed to utilize a two-step erase procedure to prevent accidential erasing of tapes.
1.) Press & HOLD down the TEL button
2.) Immediately press & HOLD down Rewind button UNTIL erase function starts then quickly release both buttons.
Aug 05, 2008 | Voice Recorders
Lanier Transcriber unit will not play
Most likley it is a bad motor or a broken belt. There is a seperate motor or FF and Rewind.. If the motor is bad it is likly that the motor control circuit board is bad also (motor shorts and takes out the board also). If there is no "click" when play is selected it could be the play solenoid is dirty and not engaging. I have repaired thousand of these units through the years and in spite of these issues they were a great sounding unit.
BTW this is true for the VW-210, VW-260, p-139 and simular units.
Mar 02, 2008 | Lanier 260T Desktop Cassette Voice...
Voice Recorders Logo
562 people viewed this question
Top Voice Recorders Experts
David Burkhart
David Burkhart
Are you a Voice Recorder Expert? Answer questions, earn points and help others
