Why did our replacement A/C remote fail?
It would seem from the forum that the remotes constantly die. Ours did after 2 years so we spent $100 on a replacement and it didn't work either! So now we have 2 remotes that don't work and 1 air con that is stuck on one temperature!
    Top Expert:
  • Heating & Co... Master
  • 46,218 Answers
Yes call a service man
Posted on Apr 16, 2015
I purchased a Magnavox Digital Viedo Disc Recorder & Video recorder ZV427 MG9 A. While setting up the DVD player; I was advised by Comcast to switch from their remote control to the Samsung report...
I have a Samsung Blue Ray and haven't had a lot of luck with getting the remote to control anything but my Blue Ray and documentation is hard to come by. I just posted this solution on another similar topic but I think you should try the Synergy V remote. I got mine for free from Time Warner but this seems to be a reasonably priced remote and the most versatile. I've spent up to $100 on universal remotes but this free/inexpensive one does the best job for me and I really liked the price:
I've found that you can use a Synergy V Universal Remote which is supplied by some cable companies like Time Warner, RCN etc. You can also buy this remote. This remote does a good job of controlling all my different components including my LG TV, Bose Sound and Cable Box.
This pdf seems to be best reference.
but there a several others out there if you google for Synergy V.
Nov 28, 2010 | Samsung Remote Control
My Sony Bravia KDL-40D3000 no longer responds to the IR remote. I also have a 46 inch Bravia, and the remote does work with it. The front panel controls work okay. The remote worked for about 2 years, then...
Had the same problem. The infrared receiver quit working. Could not use the factory remote or the cable remote. Simple fix- I just cleaned the infrared receiver. Both remotes now working.
Mar 27, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
My 2 year old remote is not working at all. It is powered up...can I reset..?
My remote is just one month short of being 2 years old and also died. I have tried to reset it myself and with logitech. I have spent approx. 6 hours trying to solve the problem. THEN I was told to buy a new one @ $349.00 and Best Buy said they would be so kind to come to my home to set it up for me for $149.00.
At this point I think the 890 is programed to die at 2 years old. To solve my problem I am going to rewire the TV and move the cable box to the living room where the TV is instead of using a remote to send the signal through the wall. I give up! I'm sure using my cable co. will be much easier, and they do come to the house and service their products.
Dec 19, 2009 | Logitech Harmony 890 LCD Remote Control
Remote does not work, tv is fine
Found universal replacement remote for Viewsonic N2750 at Target for $15. Works perfectly. it's the Sony RM-V310A. Tried all 5 remotes from Walmart, none worked even though it said would work on back of packaging..Target has about 5 Remotes only this one worked. My original remote died after 2 years. ordered an original replacement. that one died after 2 years. They're ****.Manufacturer discontinued it. found one online for $50. Just get the Sony RM-V310A at target.
Oct 14, 2009 | ViewSonic N2750w 27 in. HD-Ready LCD...
2000 Mercedes ML430 Battery Change Failed
you have to resynch your remote once it looses power. the procedure is in your owner's manual. It can also be done from a scan tool but you would have to take the car to a shop. I beleive you hold the lock button and press the unlock button 5 times within 10 seconds and then put the key in the ignition but I cannot remember year for year procedures
Jun 17, 2009 | Mercedes-Benz ML-Class Cars & Trucks
Tv turns off when it feels like it
There are 4 possibilities.
1. weak remote batteries
2. failing remote button pad
3. failing infra-red LED in remote
4. failing infra-red receiver in TV.
First, try another fresh set of batteries.
Next, replace the remote, third, have a TV shop look at it.
May 12, 2009 | Mitsubishi VS-45609 TV
TV Repair Discovery
It is possible that it is due to the power supply since you said "I can turn the TV off with the remote, but can't turn it on again unless toggle the power switch off (and then on) the set itself and only then can I use the remote to turn the TV on"
The power supply could be failing which could cause that symptom. Otherwise if it was not the Power supply it would likely be the main video board that is failing. In any case I would probably take a look at the power supply first as it seems to be a common fail point of the Akai LCT2715.
If it is the power supply you can have it replaced by a TV repair service. They usually do not bother repairing them which ends up 1) costing you more 2) being unnecessary. I offer to repair these Power Supplies if they are indeed faulty. I charge $100 + Return Shipping for the repair.
Oct 13, 2008 | Akai LCT2715 27 in. LCD Television
Harmony 880 doesnt work on devices
I did some more searching and it sounds like the IR emitters die. People see to have sucess with replacing the emitters with new or ones from an old remote. I will find out :)
http://forums.logitech.com/logitech/board/message?board.id=remote_hardware&thread.id=724&view=by_date_ascending&page=2
Jun 21, 2008 | Logitech Harmony 880 LCD Remote Control
Heating & Cooling Logo
32 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
