Why am I seeing clear oil under my washing machine?
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 40 Answers
Your vent hole on your gear casing is clogged so the oil leaks out
Posted on Apr 17, 2015
E 15 message
is the water outlet pipe clear check by blowing down the pipe to see if the pipe is clear as sometimes remained water in the bottom of the machine is not pumped out so the machine cant go onto the next cycle, I know it sounds funny but when I moved from my old address I left the dishwasher someone collected my old washing machine and turned the stopcocks off under the sink for both machines and forgot to turn the dishwasher tap back on again leaving the dishwasher not working, its a possibility eric
Dec 09, 2017 | Washing Machines
How do I fix my hover 730 washing machine that's spraying out little drops of oil.
oil out is water in
after 35 years the seals and shafts will be very difficult to get if not impossible
consider a new machine
Feb 26, 2016 | Washing Machines
No oil movement in bubble on top of machine
ead the needle raise the presser ft and stomp the power foot down, now check the bubble when the machine is running full tilt. when the machine is running slow you will not see the oil flow. also ck the screen on the oil uptake under machine for dirt.
May 10, 2014 | Juki DDL-8700
Oil leak found under washer. Cannot tell where this is coming from or what cycle. Washing machine still seems to be working okay.
the most likely cause if the oil looks like motor oil that you put in your car but only thicker,is that it is leaking from the transmission which is very common in ge washers the oil is in the transmission to lube the gears which make the machine agitate
to be sure you could remove the front panel and would see alot of oil in the base frame
to remove the panel place a screwdriver between the panel and top and feel around and find 2 clips (one on each side) press on those clips while pulling the panel out
Jul 19, 2011 | GE WBSR3140DW Top Load Washer
I am finding oil under my washer.
your transmissions lower oil seal is leaking and needs to be replaced,if the top seal goes,you will start to see oil droplets on your clothes when washed and this is called "wash-back"
Jan 01, 2011 | GE WBSR3140DW Top Load Washer
It stops working after the wash will not drain, or spin just a beeps and blinks error brand new machine used 10 times only so far What do I do???
Remove the panel under the door by removing the three screws from under the bottom lip, Behind this panel you will see the drain filter (looks like gas cap on a car) Unscrew this cap and clear any debris from the filter. This should clear the problem.
If you have any further questions, please feel free to ask.
Nov 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Pavt454 will not stay balanced.in spin cycle.any kind of load
Your machine has a "snubber" on it. part number 21002026. it sounds like the snubber (clear/white plastic ring) is worn out. take the front panel off the machine and look at the base. you will prob see white powder down there. if not, then you will see oil. if you see oil, your transmission is leaking. if you see the white powder, then the snubber is worn out. the problem is that you need to remove the brake to get to the snubber. DO NOT TRY THIS YORSELF if you do not have the propper tools. THE BRAKE IS UNDER ALOT OF PRESSURE. you will get seriously hurt if you do not have the correct tools to do this job.
Dec 29, 2008 | Maytag Performa PAV2200
Oil leak from bottom of maytag neptune tl - about 4 years old
sounds like seal leak in tub water is leaking onto drive unit and washing over it bring and oil it can with it couls be big bucks some parts may be under warranty call service but be sure to get estimate first
Nov 27, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Oil spill under washing machine
Sorry, this could be bad. The transmission might have blown a seal. It's a big job to fix, if this is the problem. It might be time to consider replacing the machine.
Premmy
Oct 21, 2008 | Washing Machines
WASH MACHINE IS LEAKING GEAR OIL ON FLOOR AND WON'T SPIN THE CLOTHES OUT
If there is oil leaking out, you may have a leaking gearbox.
There is nothing you can do about that but replace the gearbox.
Here is a website link for parts.
http://www.theappliancepartswarehouse.com/seo_indexing.html?m=Whirlpool&s=18500
you can copy and paste this in your web search window
Feb 07, 2008 | Whirlpool LSN1000LW Top Load Washer
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
