Question about Sylvania SDVD9805 9-Inch Twin, Dual Screen DVD Player, play the s
Change region code to 0
Region code currently set to 1. Want to set to 0 (multi region).
  • 135 Answers
SOURCE: Unlock region codes
Go to www.videohelp.com enter your machine's model number, hit search, then scroll down and look to your right- If there is a region free hack for it they will have it...If it is a new model, you might want to check back with them in a month.
Posted on Jun 30, 2008
1Guru
  • 61 Answers
SOURCE: i want change the region code 1 to all region
One european player is the Sigmatek sbr1000 and it seems to be also a clone of Funai. Which is what your sylvania basically is.
We can use any DVD or bluray by using this code with the remote : 973501, you have to use this code each time you turn off the power and change DVD region.
Insert your DVD, say wrong region, open, use remote for 973501 then close, it's done.
Please let me know if this is ok on the Magnavox.
Posted on Dec 12, 2008
SOURCE: Unlock Region Code for LG XB12 Mini Home Theater
Below is the only known process to unlock the region settings on that model of dvd player.
Make sure there is no disc in it
Turn on by pressing "Power"
(--------) apears an "No Disc"
Press "Pause" on remote and "314159"
"Code" apears
Press "0"
"Code 00" apears
press "enter"
Turn off and on
Hope this works for you, let me know. If it doesn't then there are no available region hacks for your dvd player.
Thank you for trying Fixya!
Posted on Mar 25, 2009
muntejaya
  • 10421 Answers
SOURCE: unlocking my Sylvania SRD 3900 from region 1 to
Please unlock it here : www.dvddemystifiziert.de/codefree_en/sony.html
Regards,
Posted on Feb 21, 2011
muntejaya
  • 10421 Answers
SOURCE: region settings for sylvania dvd/vcr player
Hello, Please get the code here : www.dvdoverseas.com/dvd.htm
www.regionfreedvd.net/
Regards, Jay__Okmn8uj
Posted on Feb 25, 2011
How to unlock a Toshiba blue-ray DVD player bdx2150 to all regions Please help Thanks
If the current firmware in your blu-ray player supports multi region then try this.
1. Power on the blu-ray player.
2. Press "Setup" on the remote to enter Setup Menu.
3. Using the remote, enter "8520". A new submenu will appear.
4. Set DVD region code to "0" for DVD Multi Region.
5. Set BD region code as required using the remote buttons.
"1" = Region A, "2" = Region B, "4" = Region C
6. Press "Setup" button to exit the menu.
If this does not work then try upgrading the bluray firmware.
Search for Toshiba BDX2150 firmware and see if there is a newer firmware than the one you have installed.
Nov 05, 2017 | Toshiba Televison & Video
Is there a Unlock code for bush btvd91216w
This is everything that I have:
Try this general bush unlock:
Press Open tray
Press 2, 8, 1, 2 and Enter to get to the manufacturers settings
Select the required region, by pressing Enter on 9 for multi region
Press Close tray
If that didn't work, try this:
Try this one:
1. Press the Open button on your remote control to open the drive tray
2. Press the 9 button on your remote control
3. Press the 7 button on your remote control
4. Press the 3 button on your remote control
5. Press the 5 button on your remote control
6. Using the on screen menu, highlight the region option
7. Press the Right button on your remote control
8. Using your remote control, select 1 for region 1, 2 for region 2, and so on, or 0 for multi-region playback
9. Press the Enter button on your remote control
10. Press the Open button on your remote control to close the drive tray
Then there is the following and good luck:
Bush 1000
  1. Open the tray
  2. Insert a disc with desired region code, but do not close the disc tray
  3. Press 0, 1, 2, 3, Play
Bush 1005 / 2004A / DVDAV7
  1. Press the OPEN/CLOSE on the remote
  2. Press 3, 3, 0, 8, 8
  3. Press the button for the desired region or 0 for multi-region
  4. Press OPEN/CLOSE
  5. The on-screen display will now indicate the currently selected region
Bush 2000
  1. Open the disc tray
  2. Insert RC-1 DVD, don't close the disc tray
  3. Press 0, 1, 2, 3
  4. Press PLAY
    To activate RC 2:
  2. Insert RC-2 DVD, don't close the disc tray
  3. Press RETURN and PLAY
Bush 2002 / 2004
  1. Press OPEN
  2. Press 7, ENTER, 7
    A menu should appear (codefree=13)
    Method 2:
  1. Press OPEN
  2. Press 2, 0, 0, 1
Bush 2005 / 2008 / 2009
  1. Turn on the player
  2. Press OPEN/CLOSE
  3. Press ZOOM
  4. Press A/B
  5. Press Up, Left, Down, Right
    A note should be displayed.
  6. Turn it off
  7. Turn it on
Bush 2023 / 2024 / 2523
  1. Press OPEN
  2. Press 2, 8, 1, 2, Enter
  3. Set the country code to 13 and press Close
Bush 2028
    already region free
Bush 2039
  1. Press OPEN
  2. Press PROG
  3. Press ENTER three times
  4. Use UP/DOWN to select region
  5. Press STOP several times to set the region
Bush 2047
  1. Press OPEN, SETUP
  2. Go to "Preferences"
  3. Enter 2, 8, 1, 2
  4. Use UP/DOWN keys to select the region
  5. Press SETUP, OPEN
Bush DVD-102
  1. Press OPEN/CLOSE
  2. Press 2, 0, 0, 1
  3. Press ENTER
  4. Select RC (codefree=13). You can disable MacroVision, too.
  5. Press OPEN/CLOSE
Bush DVD-142TV
  1. Press DVD function on your TV set
  2. Press DVD Setup on the remote
  3. Press 1, 3, 6, 9
  4. Press Left three times
  5. Press RIGHT once
  6. Select VERSION
  7. Change the region code
Bush DVD-143TV
  1. Press DVD/TV, DVD
  2. Open the tray
  3. Press SETUP, Right, Left, Down, Up, Display
  4. Enter 0 (or 1-6 for other RC)
  5. Press Enter
    VCD/SVCD playback
  1. Press SETUP on remote
  2. Press Next, Prev, Next, Prev
    Ver should appear in the top right
  3. Change 3001 to 3000
  4. Change 5001 to 5000
Bush DVDAV11K
  1. Open the tray (be sure to be in stop mode)
  2. Press SETUP, Next, Prev, Next, Prev
  3. Select 255 for region free (use LEFT/RIGHT)
  4. Press SETUP
Bush DVDR3000
  1. The disc tray has to be empty
  2. Press TV/DVDR
  3. Press RETURN, DISPLAY
  4. Enter 8, 8, 8, 0
Bush DVHS1
  1. Press the DVD button on the remote
  2. Press OPEN
  3. Press 0, 5, 2, 0
  4. Press UP, DOWN, LEFT, RIGHT
  5. Change the region (0 = multi-region)
Bush DVRHS02
  1. Push SETUP button on the remote
  2. Select SYSTEM INFO on the menu
  3. Enter 1, 1, 0, 1
  4. It shows the current region code
  5. Push 0 on the remote for region free
Bush 2001 / 2020 / 2026 / 2029 / 2035XI / 2038 / 2042 / 5020 / BTV213DVD / DVR3000 / DVRS01 / PDVD0707 no known hacks
Jun 12, 2012 | Bush Televison & Video
Region free code for LG BH7520
With your set on and without disc in the tray:
1. Press PLAY from your remote control
2. Press the following button sequence: 1590 2379 390
3. Press PLAY again
This will release the region verification in your home theater (region free). However, some DVDs (multiregion in particular) will not play, since they require region detection from the player unit.
Jun 10, 2012 | LG Televison & Video
I have a LG HT554PH home cinema and would like a region code to enable it to play region 1 dvds. i have just paid £5 from a website and it is no use my dvd player wasnt on the list. there is a reion...
Hi
To make the player as region free, switch on the LG HT554 Player. Push the eject button to open the tray. Now, press “0” on your player 4 times or until the region code settings shows up on your player. It will show the current region code and will then ask for new region code. Press “0” on your remote to set it as a new region code(0=All Regions). Press Enter key on remote, now restart your player and check the player by playing the DVD’s. It should be region free now.
Please post back for any further assistance. If you are satisfied please do accept the solution.
Daniel
Jul 23, 2010 | Audio Players & Recorders
PHILIPS DVD player 616K, how to change region or get into right region. my player was working OK. Suddenly it stopped functioning and showed/diplayed '' wrong region'' on the TV screen.
Changing the region code for DVD616K :
1. Press OPEN/CLOSE, and wait for the tray to open.
2. Use the remote control to input digital key '1', '1', '1', '0' in that order
if that dont work go 1, 1 1, 1 in that
order.
Kindly leave a few seconds between each entry, the microprocessor is slow
with these entries.
3. Press number '7', '8' or '9' to display the current region code of the DVD
player.
OR
4. Press any number of '0' to '6' to set the required region code. The OSD
will display the new region code of the DVD player.
5. Region '0' will be the setting for multi region
6. The region setting will be saved in the FLASH memory.
7. Press OPEN/CLOSE again, the DVD player will return to normal operation.
note: you want to chose region 0 so u can use all regions
Nov 15, 2009 | Computers & Internet
Mac book pro is currently locked to region 1,
Home Index DVD Region Codes
In order for you to view a DVD's content, the region code on the DVD and the region code for DVD Player must be the same. Your DVD drive is automatically set to a region code the first time you play a coded DVD. If the region code for a DVD does not match the current region code for DVD Player, a dialog appears for you to change the code for DVD Player.
IMPORTANT: You can set the region code for DVD Player only five times (including the original setting). The fifth time you change the code, it will be permanently set. The following map and table indicate the code for the various regions. Some DVD discs can be played in any region, and are sometimes referred to as having region code 0. These discs can be played regardless of the region to which DVD Player is set.
Mar 30, 2009 | Apple Computers & Internet
Setting the player to region free
Apologies everyone.......
The instructions for the DVD-P181 are actually correct as described in other posts but can be a bit confusing. Please allow me to clarify using my example;
With your DVD-P181 switched on, follow these instructions using your Remote Control;
1/ Press the <DVD> button
2/ Press <0><0><0><0><0> (this is 0, 5 times)
3/ Press <repeat> (careful not to press the <repeat A-B> button)
4/ Press <7><6><8><8><4> (ONLY if your player is currently region 4 - refer to the table below for other pre-set regions)
5/ The Region window should now appear on screen saying that your current region is Region 4 and asking what region you want to change it to.
6/ Press <0> for the new Region (0 is region-free)
7/ Press <Open/Close> button once (to open the tray)
8/ Press <Open/Close> button again (to close the tray
9/ Press <Power> button to turn the player off
Now, when you turn the player back on, you should be able to play DVD's from any region. Good luck everyone.
_______________________________________________
This table refers to Step 4. You need to choose the Region code which your machine is currently set to, to unlock the Region Menu which allows you to set the device to another region.
In my example, the DVD player was purchased in Australia is by default set to Region 4. The 5 digit number I needed was 76884.
5 digit code:
region 1 : 29334
region 2 : 37867
region 3 : 56732
region 4 : 76884
region 5 : 53814
region 6 : 24462
Dec 28, 2008 | Samsung DVD-M105 DVD Player
Region code Samsung BD - P1400
1. Make sure the player is switched on, and is at the Samsung logo screen.
2. Also check the tray is shut and that there's no disc in the player.
3. Now press the REPEAT button on the remote, followed by a five digit code.
4. This code is different depending on what region your player is *currently* set to: R1 - 29334 R2 - 38767 R3 - 56732 R4 - 76884 R5 - 53814 R6 - 24462 So for example if you have an R2 player, press REPEAT-3-8-7-6-7.
5. If you've done this correctly (and your player is compatible with the hack), you should see a number at the top left corner of the screen corresponding to the current region.
6. Now, pressing any number from 1 to 6 will change to the corresponding region. Or, press 9 for "auto-region" mode.
7. Next, press OPEN/CLOSE to open the tray, followed by Standby (or DVD POWER) on the remote to close it and put the player into Standby mode.
8. The next time you turn your player on, the new region will be set. Don't forget that if you want to hack it again, you'll need to use a different code, as listed above. If it's currently set to "region 9", use the code for the last *proper* region you set it to.
or this...
Multi-Region on a Samsung BD-P1000 R2:
1. Switch on unit
2. Remove any disc
3. Wait fo NO DISC message
4. Press REPEAT on the remote control (NOT REPEAT A-B)
5. Type 57538 followed by the desired region number on the remote control
NOTE: 9 = Multi Region mode
6. Press OPEN/CLOSE on the remote control
Switch unit off
7. Enjoy :0)
Apr 27, 2008 | Televison & Video
I own an LG (LH-W750TA) DVD player that is set for DVD region 4. I am after an unlocking code to allow me to view DVDs from region 1 NTSC.
Open tray
Press PAUSE
Enter 0 0 0 0 0
Region change screen should appear.
Enter region 1 - 6 or 0 for multi-region.
Press PAUSE
Apr 23, 2008 | Televison & Video
Setting region codes to code 1
*To convert this player to Multi-Region
1. Open the drive tray
2. Press the Setup button on your remote control
3. Press the buttons 1, 9 and 9, in order and one at a time on your remote control
4. Select the Region option from the menu and change to a specific region or all regions
To convert this player to Multi-Region if the above does not work
1. Press the 7 button on your remote control
2. Press the 6 button on your remote control
3. Press the Select button on your remote control
4. Highlight the Region option and press 1 for region 1, 2 for region 2, and so on, or 0 for multi-region playback
5. By visiting the next page of this hidden menu, you may be able to disabled Macrovision by setting an option to 0, although this particular setting does not survive power off
6. Press the Setup button on your remote control
Done!
Oct 18, 2007 | Pioneer DV-373 DVD Player
Sylvania SDVD9805 9-Inch Twin, Dual Screen DVD Player, play the s Logo
288 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
