Question about Samsung 3.5 cu. ft. High Efficiency VRT Front Load Washer
Will not drain during cycle
Noticed that the washer was leaving water at the end of the cycle. Checked and cleaned the filter. That was not the issue. If i set it to spin it will pump out the water so i assume the pump is working and not clogged. I have had it for 3 years and I have never had this happen before so i dont think that i am getting any syphoning.
  • 1,602 Answers
Do you know if it is still under warranty???
if i was you i would check into it
it would save you a lot of money in the long run.
Posted on Apr 16, 2015
Supra washer/dryer combo leaking significantly
In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Replacing Door seal: http://www.espares.co.uk/advice/washing-machines/a/7/1464/how-to-replace-the-door-seal-on-a-washing-mac.html
Mar 20, 2013 | Supra SW5L65D Front Load Washer / Dryer
Admiral washer begins leaking water from the bottom during the spin cycle
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Check for tips on the link below to identify parts and removal:
Jan 23, 2013 | Admiral AW22 Top Load Washer
Leaking
Jan 16, 2013 | Washing Machines
GE front loading washer only leaks during stain wash cycle
Sep 03, 2012 | GE Energy Star WCVH6260F Front Load Washer
Maytag washer sav205daww leaking water from bottom of washer when runinning
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.Also check on this link : http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Jul 02, 2012 | Maytag Washing Machines
Model Free standing dishwasher SGS 5002 GB 14 yrs old. The dishwasher does not drain. The dirty water is left in the bottom at end of cycle. I have ensured outside drain is unblocked: I have cleaned all...
Please check if the drain valve is weak/faulty or does not get the votage to open during the cycle , his can be your fault . Also it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Jun 13, 2011 | Bosch Dishwashers
My washing machine overflows during what seems like the rinse cycle. When I shut off the water supply and let it run the water drains out. Whats causing that problem??
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine.This fault indicated can be due to failure of the water level sensors causing overflow but in all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Apr 18, 2011 | Whirlpool LTE5243D Top Load Stacked...
My GE WCSE4160B2WW top load washer is leaking.
Check the easy stuff first, fill hoses tight?- drain hose cracked? Failing those checks, cut a piece of cardboard slightly smaller than the size of your washer. Slip the cardboard under the washer and run a short load. Look carefully at the water mark on the cardboard. The mark on the cardboard the water leak will leave, will help you tell from which side or front to back the leak is common from. This will help point you in the correct direction to look for the trouble maker
thanks.
Nov 05, 2008 | GE WWSE5240D Top Load Washer
Timer Stalling
I would check the water hoses for twisting, make sure the water faucets are turned on all the way, and check the filters at the washer end of the hoses to make sure they are clean. I would also check the drain system to make sure it is clean and the machine is draining well.
Jul 28, 2008 | Frigidaire ATF6000ES Front Load Washer
Whirlpool Front Loader will not drain or spin
Based upon your description, the drain pump has either failed or become clogged.
To check the pump, remove the bottom access panel (three screws along the bottom). There you will find access to the pump clean-out.(Large,white screw cap) BE READY TO CATCH LOTS OF WATER. CAREFULLY AND S_L_O_W_L_Y unscrew the pump clean-out, catching and discarding the water. When the water flow finally stops, completely remove the clean-out filter. Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris
If you need further assistance, let me know
Regards,
reg501
Jul 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Samsung 3.5 cu. ft. High Efficiency VRT Front Load Washer Logo
53 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
