Question about Singer Sewing Machines
I bought SINGER ROTOMATIC SEWING MACHINE 18 years back.it's motor is very fast.as I found that thread and needle breaks while stitching.even my machine also moves due to motor speed.
    Master:
  • Singer Master
  • 470 Answers
Is this a Singer Fashion Maker Rotomatic 974?
Enter 974 into the Singer Manual search below:
Instruction Manuals
Posted on Apr 16, 2015
    Top Expert:
  • Singer Master
  • 44,351 Answers
Then use a lighter foot on the pedal . it only runs as fast as your foot tells it to
SOURCE: Singer 4572 model: thread breaking, skipping stitches
I have this same machine and it does this sometimes, too. I've found it's usually due to a couple of things: 1. The thread is caught on the spool in the little **** that holds the initial starter piece. If you turn the spool around with the **** on the side away from the bobbin maker, that usually does it. 2. The needle is not in with the thread going from front to back (it may be in with the thread going from side to side). 3. The thread is bad. (I had one spool that actually had "lumps" in it!
Hope this helps - good luck.
Posted on Aug 13, 2009
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
SOURCE: singer stylist sewing machine 534 is not stitching
Feed dog drive gear(2) are plastic and are probably stripped. Always replace them in pairs. While you are at it replace both hook drive gears as well. It will run as good as new.
Posted on Mar 28, 2009
  • 18 Answers
SOURCE: Singer 457 Zig Zag Sewing Machine not catching bobbin thread.
There are manuals avilable online to purchase for the singer machines, SOrry I was not able to locate a site that has them for free.
.... http://sewingonline.co.uk/singer-manuals.html
Posted on Aug 16, 2009
  • 139 Answers
SOURCE: how to thread & what needles for singer 660 A2 sewing machine
You can download a manual here:
http://parts.singerco.com/IPsvcManuals/
Posted on Apr 07, 2010
My singer heavy duty 5532 makes a knocking noise when I use the decorative stitches
check thread and make sure thread has been in its threading slot in your bobbin case
Mar 23, 2016 | Singer 5532 32-Stitch Heavy Duty Sewing...
My top thread breaks about every 10th stitch on my xl 5000. I have bought new thread, replaced needle.....I don't know what to do next! Please help!!!
Try this-When you pull your thread through the channel for the automatic needle threader, make sure you pull back on the thread hard. There is a groove that the thread must pass through to keep it from breaking. I had mine in the shop for the same problem and that is what they had me do. No more breaking.
Dec 12, 2010 | Singer Quantum XL-5000 Computerized Sewing...
Bobbin thread will not stitch.
Have you had the machine serviced since you purchased it? This is something that should be done at least once a year.
Take the machine to a certified Singer dealer and explain what is happening. There may or may not be something that needs to be adjusted.
Your warranty is still in effect, but is now limited. Attempting to repair it yourself or having someone who is not a Singer dealer repair it will invalidate the remaining warranty.
Apr 16, 2010 | Singer 3116 Simple
Singer Futura 250E - thread is shredding after 5-6 stitches
no damage to the machine yet
check the thread size you are using as you may have to use a needle with a bigger eye
thread is made by winding the material around and around then using a product to hold the material ends together
as a result thread will not last indefinitely and will break easily
you may have to use only thread from manufacturers that you know make good thread
Apr 03, 2017 | Singer CE-200 Quantum Futura Computerized...
Singer 301A needle breaks
do you have a book, refer to threading. This machine threads differently than most, threads like a 221 featherweight. Needle goes in backwards, and threads backwards. in wrong and you can have problems, also threading can cause your problem if you have missed tension or a thread guide. great little machine
Jun 01, 2009 | Singer Quantum XL-1000 Computerized Sewing...
Singer 301A stitch jam
your machine threads from right to left. the needle flat spot faces left. big loopy things means that the upper part of the machine is not threaded properly. as far as the needle hitting the bobbin case, it sounds as if someone removed the hook (part that holds the case) and put it back on 180 degrees off.
Need instructions on threading singer pixie sewing machine
i need help too i bought this machine for my 9 year old daughter i thought she was just breaking it bieng so young and inexperienced but my husband and myself have tried also and the same problem accured i tried to follow the instructions but they are so very hard to follow can someone please help me? I keep threading the machine the needle and the threading the bobbin but i get half a stitch and it breaks again. Does
anyone know what im doing wrong?
Apr 24, 2009 | Singer Sewing Machines
Singer simple sewing machine will not sew
Mar 15, 2009 | Singer 3116 Simple
Needle jams and breaks off
Needle jams....Thread is caught in the hook...solution...Remove the upper thread and bobbin case,turn the handwheel backwards and forwards by hand and remove the thread remands.
Needles breaks
1. Needles is damaged..Insert new needle
2. The needle is not correctly inserted....insert flat side towards the back
3. Wrong needle size for the fabric...Choose a needle to suit the thread and fabric.
Mar 24, 2008 | Singer 1116 Mechanical Sewing Machine
Aug 13, 2007 | Singer 5062 Mechanical Sewing Machine
Sewing Machines Logo
103 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
