Question about Toshiba E-Studio 242 Digital Copier
Close side cover - Toshiba E-Studio 242 Digital Copier
  • Toshiba Master
  • 653 Answers
The side cover is underneath the bypass unit, make sure is close...
Posted on Aug 18, 2015
How to fix Canon IR2520 Cover sensor error?
Hi. Have you check the lower cover ( right side of the machine ) . If all covers are closed maybe is a sensor problem
Jan 17, 2018 | Canon Office Equipment & Supplies
Closed 1st side cover konica minolta bizhub 185
Check the 2 actuator at Right Door assy, may be broken, so while closing it is not blocking/hitting the sensors on body.
check properly - at Rear-Top & Front-Below on Right Door assy.
Dec 09, 2016 | Konica Minolta bizhub Office Equipment &...
Toshiba estudio 280 says close side cover, where is side cover?
26288766-l5zkkje5jzxho11gzzfexnty-4-0.png this is the side cover opening /closing sensor try to clean it and see the masege remove or not
Sep 22, 2016 | Toshiba Office Equipment & Supplies
The screen states "close cover E" It is closed but the screen keeps saying " close cover E" ?
The Exit 2 interlock switch is either broken or off it's base or defective. If you open up the top door on left side of print, there is a push button switch that mounts on the back side. If you're standing on the left side of printer it's located on the top left. Make sure it's mounted properly and try to push the button with your finger and see if error goes away, if not replace switch, part number 110E11580.
http://www.iteminconline.com/110e11580_xerox-5500-door-b-interlock-switch.htm
Sep 23, 2015 | Xerox WorkCentre Pro 123/128 Printer
E.studio232. How do I respond to "close side cover" message?
The side cover is located under the bypass unit...
U need to close it properly...
Aug 28, 2015 | Toshiba Office Equipment & Supplies
My konica bizhub 163 gives massage 1st side cover open close 1st side cover,how do i clear the massage. pliz help me.
1st Side cover is front cover.The cover which you use to open to install or check toner bottle.When you close that cover and machine gives caution then it means cover is not properly closed
"OR"
The 1st side cover switch is not working properly.
There is a knob at the end of the front cover, make sure it it aligned with the switch.
Front cover Micro Switch can be dirty due to toner spilling/dropping inside the machine.Clean it and then recheck.
Jun 20, 2015 | Konica Minolta bizhub Office Equipment &...
My Toshiba e-studio 233 copier is giving the error message, "Close side cover." Opening any cover to close again changes the message to "Close x" where x is the part opened, until that...
there is a switch at the side that is being push by the cover when it closes check this switch to be sure it hits the button when close or you may replace the switch it has a problem.
Jun 27, 2011 | Office Equipment & Supplies
Side cover open
yes there is a cover switch, but if this is a new printer, changed it under warranty, but if this problem occurred now you have to find a problem, why this door won't close correctly. the cover switch is located on the left side if the cover
Apr 10, 2008 | Konica Minolta magicolor 5430 DL Laser...
Brother MFC 7820N error message "back cover open" but cover is closed. machine is now not functional as error message can't be removed
If you open the back cover (depress the release button on the top right) If you lift it up look for two black anchors that grab the base when you close the lid. I have one that has a broken tab on the left side, which happens to be the same side as the cover closed switch. If the top is not closed all the way the rollers do not line up and the cover switch is not depressed to let normal operation. Also, if the switch arm is busted (case colored plastic push pin protruding from the cover) it will not make contact with the switch when closed. Try closing the cover and push down on left side of the fax. Does the error go away? If not, the actuator arm or the switch are bad.
James
Apr 06, 2008 | Office Equipment & Supplies
Toshiba E-Studio 242 Digital Copier Logo
97 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
