KX-TGA101S is an add-on handset for a Panasonic KX-TG1000 series cordless phone system. One of the models that is compatible with the handset is the KX-TG1032S. You can find the manual for the phone system on the product page here: https://shop.panasonic.com/support-only/KX-TG1032S.html . Assuming that you do not have voice mail from your telephone provider, you can change the number of rings from the Answering Device Settings Menu.
Start with the phone system in standby (no incoming or outgoing calls) mode. Press Menu and use the up/down keys to navigate to Answering Device. Press OK to enter the sub-menu. Navigate to Settings and press OK. Navigate to Ring Count and press OK. Use the up/down arrows to choose a new number of rings. Press OK to save and press Off to exit the menu system. Note: if the ring count is set to Toll Saver mode, the answering system will pick up on the second ring if there are new messages. It will pick up the incoming call on the fourth ring if there are no new messages.
See page 31 of the manual for the KX-TG1032 for this information. See page 23 for the way to navigate through the menu and a list of the menu tree items. The current link to the manual is ftp://ftp.panasonic.com/telephone/om/kx-tg1031_en_om.pdf .
Call forwarding is a feature of PABX and Public Exchange systems so do you mean the phone rings once and then 'forwards' to another different telephone number ? If so, then you need to contact the company / person controlling your Lines as you cannot change this on your phone.
It appears your telephone service provider has turned on voice mail service. We recommend you turn off that service by contacting your service provider.
We have two phones KX-T7731 (Main phone) + KX-T7020 in another office. We talking on phone and another call comes in it use to ring on the spare phone. Now it does not ring until 4th ring and goes right into answering machine. It use to ring on second ring. Is there a way to program phone to ring on second phone after second ring?
plug in your tel pin to line socket instead of phone plug. ther must be two plugs for tel.
line is for tel line from wall and tel for external tel unit
The Voice Mail feature is set by your phone company, not by the phone. Typically the phone company will set it for 20 seconds, or approximately 4 rings. This is called your voice mail "Ring Cycle"
Call them up (the customer service number should be on your phone bill) and they should be able to increase or decrease your ring cycle for you at no charge.
Push Menu, Scroll to Initial Setting and push Select, go to Set Answering and push select, go to Ring Count and push select, you should be able to scroll up or down to the number of rings, in your case 6, and then push save
This phone is made to work on a Panasonic phone system. Are you connecting it to a Panasonic phone system or just a normal phone line?
If you do not have a Panasonic phone system I doubt this phone will do anything (just as you describe) If you do have a Panasonic system do you have other phones that start with KX-T7??? on the system and have you tried this phone in one of the ports another phone is currently working on?
