Question about Ryobi Garden
I have a Ryobi weed eater. It's sat up for about 3 years.I'm trying to get it running again. I can get it started but it dies every time and I've got fresh fuel and cleaned the carburetor what do I do
  • Eugene Rounds Apr 16, 2015
    Hi Jonathan Smith, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? How did you cleaned the carburetor?
  • Ryobi Master
  • 2,760 Answers
Well if it starts but soon dies then you can be sure its not an ignition problem, your problem is gas flow , ck the filter inside the tank , blow air thru it to see its clogged , also if it sat 4 that long ck hoses , I bet they dried up and cracked , this allows air instead of gas in carb
how did u "clean" the carb these things are tiny inside and have lots of little passages that can get stopped up , just a spray or two of carb cleaner is not gonna do it .
Posted on Apr 24, 2015
SOURCE: RYOBI weed eater.hard to start. starts then stops
I have a ryobi doule line bought in 1997..Had same problem put new gas cap on and problem solved..could not get air in....
Posted on Aug 02, 2009
  • 61 Answers
SOURCE: Ryobi weed eater head won't spin
Sounds like the clutch has taken a long trip south. If the clutch pads are not wore out, try some wd40 on the pad hinges.
Posted on Apr 29, 2010
MOTORWIZJ
  • 1338 Answers
SOURCE: Husqavarna 125L E TEC weed eater won't stay running
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
Posted on May 26, 2010
rycgl
  • 1545 Answers
SOURCE: replacing fuel lines on ryobi weed eater,need
This is an ongoing issue for users, and rightfully so. Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Years ago on 2-stroke trimmers, primers were not even used,...you choked the carb with a slide lever and gravity let fuel enter the carb from above...a few pulls, a "pop"...slide it off of choke and away you went.
If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank.
Posted on Jul 10, 2010
hunter19_46m
  • 7482 Answers
SOURCE: I have a RYOBI weed eater model ss30. I can get
Check your fuel filter in the fuel tank,if you have one it may need cleaning or replacement.
If the mower/weedeater is over a year old, then I recommend that you buy
and install a new carburetor repair kit,because the diaphragm will get hard
and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor
internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small
rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid
and letting it run a few times like that and it will flush the gunk out of
the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to
reassemble the carburetor or follow the instructions you get with the
carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need
to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes
to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first
and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Dec 23, 2010
I have a 12 year old Ryobi weed eater/edger....have never had problems until last year...at first, it would run for a while then cut off...I'd have to wait an hour or so until it would crank and run...
This sounds to me like you have a fuel flow problem, check filters and strainers. Old fuel sometimes gels and gums up jets and strainer/filter screens. change the plug, but that is likely not involved with this issue.
Apr 22, 2011 | Garden
Apr 27, 2010 | Ryobi Garden
I have a ryobi weed eater clean carb change filter and spark plug wont run off choke
I have the same problem. It will run if I put it halfway between Half Choke and Full Choke. But, just dies if I put it on Run or Half Choke. Don't ever loan your WE to anyone, They might just try to run it on straight gas--That is what happened on another week eater that I had.
Mar 27, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I have a 31 cc ryobi weed eater start for about
I think a new carburetor kit and a good carburetor tune up is in order my friend. Sounds like it's starving for gas. If it bogs down after warm up when you throttle it, then yes it needs a carb tuning. The L screw is the low side screw and should be turned in lightly until it seats then back it out one and quarter turns (1 1/4). The H screw is your high speed screw. Also, turn it in lightly until it seats, then back it out approximately a 3/4 turn. With these settings the unit should start and may even stay running. Again, if it bogs when throttled, while running turn the L screw out a little more maybe only 1/16th of a turn and then try it again. If it does rev then you'll have to adjust the H screw in about a 1/16th of a turn. But make sure you only do this after the engine has warmed up.
Hope this works, good luck
Skidooer
Sep 27, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
My Ryobi weed eater loses power at working speed after 5 minutes.
you need to replace fuel filter inside the fuel tank . fish it out with and empty tank using a coat hanger and a small hood bent on the end.filters are around $9.00
Aug 21, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Rhobi weed eater stalling
Try spraying some carb cleaner into the intake while its running - with the air filter out..
If that doesnt help & if it sat for a long time without being run - you might need to get the carb reuilt..
Hope this elps !!
rate me good ;o)
Jul 14, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Weed eater starts, runs 5 min. then cuts off
The gas cap may be clogged.
The next time you run the trimmer and it starts to die, loosen the gas cap. If it starts running again, then you know that it's a clogged gas cap.
You may also check the air breather, it may be dirty as well.
Just let me know if you need further assistance.
Jim
Jun 28, 2009 | Poulan Pe550 Gas Edger
Have a Ryobi CS30 Weedeater, will not start, it is about a year old, did not see a spark, just bought new plug.
If you still don't have a spark with the new plug, then you may have a kill switch wire grounding the motor, keeping it from starting. If it's not that, then you have a bad ignition module (coil).
Jim
Jun 07, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
225 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
