My jet wash is buzzing when I turn it on but no water is coming out
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Check inlet valves water supp
Posted on Apr 16, 2015
Water is coming through the tray but there is a buzzing sound & there is not much water. Could there be a blockage with the jet stream feed into the drum of our Zanussi Jet stream 1400 ?
more than likely, the buzzing sound is probably the circ pump struggling. this is very common. first check filter is clear. if it is there is a hose from the circ pump to the top of the tub or to the door seal, make sure that isn't blocked. don't worry ab there not being much water in the machine, these machines don't use much.
Sep 01, 2016 | Zanussi Washing Machines
Whirlpool washing machine does not rinse just a buzzing noise
The buzzing is the water valve, the timer is sending power to the valve but no water is coming out. I would set to wash and as it is filling up change the water to cold then to hot while it's filling. I bet either cold or hot will buzz (usually hot). Once you determine which (clod or hot) shut that supply off, take that water line off the washer, put the end in the washer and turn the supply back on. If water comes out then look inside the valve where the hose connects, it could be clogged. If you have water going to the valve and you don't see a clog then the problem is inside the valve...replace valve.
Oct 21, 2014 | Whirlpool Washing Machines
I turn the knob to the wash cycle and need and pull it but no water is coming out. It just makes a buzzing noise
The buzz is the solenoid on the water valve. Is the water turned on?. Your screens could be clogged if you have hard water in your area.
To get to the water valve so you can replace it you must flip up the controls:
This video shows how to change the motor on one of these washers.
Not all are the same but the controls all flip up:
I have a manual and more videos HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 08, 2011 | Estate TAWS800JQ Top Load Washer
When I turn the washing machine on, water will not fill and the machine makes a humming/buzzing sound??
Sounds like you don't have your water turned on or no water coming into the house. Could be water valve in machine is bad or screens in water valve is cloged.
Mar 12, 2010 | Danby DWM5500 Front Load Washer
Hi my water is not coming out to wash my front windscreen,
Do you hear a buzzing noise?if noy then its your washer pump if you do then its your washer jets are clogged up with dirt a fine needle will unblock them
Mar 03, 2010 | 2003 Mini Cooper
Soap is not disolving. Falls out of holder and stays on door and floor of washer.
Are dishes also not coming clean? Most likely, there is not enough water chruning in the tub to rinse soap out of cup during wash cycle. Sufficient wash action will wash the soap out of the cup and dissolve it in the water within a few seconds of the cup opening.
Most likely causes are:
Not enough water entering dishwasher (check level after fill... Should be slightly below bottom wash arm)
Water filling but draining during wash cycle. Check toward end of wash cycle but before drain. See if water level is diminished from start of wash cycle.
New 'water saver' dishwashers are notorious for having smaller water jets, and thus easier to stop-up jets. Check the jets on all wash arms to be sure they are cleared of food particles.
Another way to check the wash arms is to manually position them at specific locations, momentarily run the dishwasher for a few seconds, then open the door to inspect the location of the wash arms. Do this three or four times to eliminate the possibility of coincidence.
If the wash arms do not move from the location that you put them, the most likely cause is food particles stopping up the water jets. These jets not only clean the dishes but also the water pressure they generate turn the arms inside the dishwasher to properly distribute water pressure on the dishes.
Sometimes you can dislodge and remove food particles stuck in one of the jets with a toothpick or other small probe. Others require that you remove the arm(s) and get a little more creative. I use compressed air to clear mine, but not everyone has access to compressed air, so use whatever you can to remove the food particles.
Simply dislodging them from the water ports is usually not effective... As soon as water pressure is applied, the particles return to the jets and stop them up again. The real fix in this instance is to completely remove the food particles from the arm if you can.
Hope this help. Good luck.
Sep 11, 2009 | Dishwashers
Buzzing noise! when the
sounds like you have a problem with the water solenoids (the electronic controlled water valves) the buzzing is an indication that it is trying to open or close and unable to do so. an electric current creates a magnetic field pulling a spring loaded valve sealed inside a tube allowing water to pass. it starts buzzing when it can't pull the valve all the way and just vibrates.
May 03, 2008 | Westinghouse WWS833ES Super Capacity Top...
Maytag jet clean dishwasher model# dwc7400aaw
Normally when you have low water pressure and/or cleaning issues, this an indication of a clog in your main wash pump. You will need to remove the lower spray arm and the coarse screen to get to the main wash pump sump. Inspect the impeller area of the pump. This area is usually where accumulations of debris collect and keep the pump from pulling enough water. Things like orange seeds, lemon seeds, bottle cap liners, chicken bones, and jar labels are just a few of the items I have personally found. Although, dishwashers do a good job at removing most food particles, they are not garbage disposals. I bet you will find a clog in the sump somewhere. Let me know if this helps.
Jul 31, 2007 | Jet Tech Systems STEALTH Dishwasher
Washing Machines Logo
Top Washing Machines Experts
