Question about Cannon Office Equipment & Supplies
Ink catridge jammed cannon printer how to get it out
  • Diane michalski Apr 16, 2015
    Can someone help me remove jammed ink catridge cannon printer that's all the details
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 142 Answers
Wiggle it make sure you have released it
Posted on Oct 19, 2015
yooperbud
  • 8637 Answers
SOURCE: cannon printer feed paper
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 26, 2009
gwbm
  • 353 Answers
SOURCE: to make my Epson printer, model "Epson stylus C42UX" work in India, with Indian ink catridges T038 & T039
This is a tricky one, but there are possibilities.
1. Buy a set of epson C42 cartridges from the cheapest source and keep refilling them - you will need a (very cheap) resetter.
2. Transfer the C42 chip to the C41 cartridge - they are only clipped in place. I don't know if this will work because I only have knowledge of C42 cartridges - the C41 cartridges may be keyed so they wont fit in a C42 cartridge carrier. You may be able to identify a clone manufacturer for which this is possible. You will also need the resetter for this solution.
3. Fit a Continuous ink system (CISS) see for example http://svp.co.uk/products-solo.php?pid=3569&prepg=1
Posted on Jan 31, 2009
SOURCE: Carrier Jam
1 Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
Did the error message return?
Yes: Continue to step 2.
No: Attempt a test scan. If the error message does not reappear, the error is resolved.
2 Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Contacting Lexmark.
No: Continue to step 3.
3 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Insert the color cartridge, close the top cover, reinsert the power supply, and power on the AIO.
Yes: Repeat step 3 with another color cartridge. If the printer fails again, continue to step 4.
No: Repeat step 3 and install the black/photo cartridge. If both cartridges are installed, attempt a test scan. If the error message does not reappear, the error is resolved.
4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black/photo cartridge. Then close the top cover, reinsert the power supply, and power the AIO on.
Yes: Repeat step 4 with another black/photo cartridge. If the printer fails again, continue to Contacting Lexmark.
No: Install the color cartridge. If the printer fails, continue to Contacting Lexmark. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved.
Posted on Mar 26, 2009
exil0r
  • 118 Answers
SOURCE: catridge problem
when printing try to press resume button for about 5 seconds
Posted on Apr 06, 2009
xptareq2000
  • 1447 Answers
SOURCE: my hp 1310 says no colur ink catridge found.
No
some model hp deskjet all in one used duel cartrdge because it is a color popier
Posted on Jun 16, 2009
My ink cartridge is stuck. I tried to turn it off and on again and to push the paper leveler down but nothing helps.
My Canon Selphy CP740 start to jam ink ribbon and ink - Fixya
www.fixya.com/support/t10013530-canon_selphy_cp740_start
Jan 4, 2013 - My Canon Selphy CP740 start to jam ink ribbon and ink cartridge is blocked and cann't be removed from printers. ... Question about Canon SELPHYCP740 InkJet Photo Printer .... SOURCE: CP760 SELPHY CP760 COMPACT PHOTO PRINTER Thermal: ink cassette stuck in the canon selphy printer CP7.
Selphy CP740 - Catridge Eject Solution - YouTube
? 0:46
https://www.youtube.com/watch?v=9TqHINBmbgQ
Sep 11, 2013 - Uploaded by Mahadhir Shaarani
Selphy CP740 - Catridge Eject Solution. Mahadhir Shaarani ...Replacing Ink for Canon Selphy - Duration: 6:23. Jenuine Crafts... How to Print Different Sizes with the Canon Selphy Printer - Duration: 12:08. Janet Wakeland ...
Color ink cassette stuck in canon selphy 'Canon SELPHY ...
Feb 03, 2016 | Canon Selphy Cp800 Compact Photo Printer -...
No ink catridges on cannon mg 5420
It could be your ink cartridges are not compatible. Are you using ink from cannon?
Sep 12, 2014 | Office Equipment & Supplies
There is an error single. We see a paper stuck inside, but can't all the way through it...can't get it out of the back., but can be seen from the front - we can't remove ink cartridge either
i know that answer, its base on my experience... i buy cannon printer,, maybe its almost the same thing as yours, if the ink contaminated inside on your printer its not easy to get out the catridges. open the platen then wait to stop the box of the catridge. then you can take out the 2 catridges, you can go to store to refill. then the paper stuck hold a minutes and then slowly pull.
Dec 14, 2010 | Brother HL 2140 Laser Printer
The ink wont work do i have to have coloured ink as well for the printer to work???
no it is not necessary to coloured catridge .but the two spots should be filled with an empty or new catridge. if this is not woking open the catridges and check
Sep 17, 2010 | Cannon Office Equipment & Supplies
Will not scan due to no colour ink. do not want to
hi,
As you dont want to use the colour ink,When you give the print command you wil get the print properties page ,In that you can select black and white so that you wil not use up the colour catridge. It uses black catridge only.
thanx
Jul 21, 2010 | Canon MP140 PHOTO AIO All-In-One InkJet...
How to change the ink catridges in cannon MX310
please your open the printer head couver and you there ink catridge
and out of printer and add ther in place in printer and close the printercouver
Sep 14, 2009 | Canon PIXMA MX310 All-In-One Printer
Ink and paper jam red ligths on ana off ?
Epson Stylus Printer
Please remove catridges from the Printer.
Clean the place with a white cloth along with cleaning liquid in the seat, where the catridges are sitting.
Use genuine Catridges for this Epson printer.
Dust and other things to be removed from the Printer.
Insert the papers in the In tray and check for the paler pulling sensor is working properly.
Paper jam can be taken care, after carefully removing small pieces of papers jammed in the printer.
Finally switch off the printer and machine and reboot the system.
Still problem comes, please contact the local printer engineer to assist you in this issue.
Jul 19, 2009 | Epson Stylus C66 InkJet Photo Printer
Price of catridge of cannon ip1300
these are the cartridges used in 1300
CL-41 FINE Colour Cartridge
PG-40 FINE Black Cartridge
click here for cl 41 prices
http://www.google.com/products?q=cl-41
Click here for pg-40 prices
http://www.google.com/products?q=pg-40
Let me know if you need anything else.
Thanks,
Ekse
Mar 05, 2009 | Canon PIXMA iP1300 Printer
Problem after replacing both ink cartridges on MP160
i want to use just scaner from my cannon pixma MP160, but i don't have catridge or the catridge was broken. can every one resolve may problem?
Jul 27, 2008 | Canon PIXMA MP160 All-In-One Printer
Top Cannon Office Equipment & Supplies Experts
Cosma Papouis
Cosma Papouis
Greg Cann
Greg Cann
Iqbal Husain
Iqbal Husain
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
