Question about Schwinn Cycling
How do you purchase a replacement needle for the Schwinn air pump?
    Top Expert:
  • Schwinn Master
  • 10,875 Answers
Go to walmart
Posted on Apr 16, 2015
2 Suggested Answers
  • 32 Answers
SOURCE: lost nozzle off air pump hose where it attaches to
Go to your local bike shop they will sell replacements
Posted on Sep 01, 2009
How to use a Schwinn Aluminum Frame Pump to pump up a bike tire??? I have it on the tire but the air comes out of the top piece instead of the part hooked to the tire!
THE TRICK TO SWITCHING OVER THE OUTLET FOR THE PUMPED AIR IS BACK PRESSURE. IF WHAT YOU ARE FILLING IS COMPLETELY FLAT, BLOW INTO THE FITTING YOU WANT TO USE AND IT WILL SWITCH OVER.
Sep 05, 2011 | Schwinn Bicycle Aluminum Frame Pump
I can't seem to use this on my bicycle tires. what am I doing wrong?
What kind of valve do you have on your bicycle tires - standard (like a car) or Presta (narrow with manual screw down valve)? If you unscrew the head of the pump you should be able to reverse the rubber gasket to fit each type - wide for standard and narrow for Presta.
Jun 03, 2011 | Schwinn Bicycle Aluminum Frame Pump
I have a schwinn bicycle pump and i need to know how to use the bike tire part and not the needle part
The needle part for blowing up basketballs and the like simply unscrews from the bike tire part. Depending on the type of tire you have, you might have to get an adapter. If it looks like your car tire stem, it's called a Schraeder valve, and you should be all set. If it is thinner and has a tip that you unscrew, it is called a Presta valve, and you may or may not need an adapter depending on your pump.
Hope this helps.
Jan 21, 2011 | Zefal Bicycle Duo 821 XLT Frame Pumps
SCHWINN AIR DRIVER 1100:HOW DO I USE IT TO PUMP AIR INTO BEACH CRUISER TIRES
SCHWINN AIR DRIVER 1100How do you assemble the air pump for bike tire
May 09, 2010 | Cycling
How does one get the needle to work
Hi
That pump was making me nuts tonight so I had to pull it apart to see how it works. It looks like the air should come out of the needle when the lever in the rear is resting down. The squishy rubber tip up front should push the internal valve to the rear and the needle hole lines up. My issue is that the assbly was jammed up and it would not let me put the thing on a tube valve. So if you can't put the pump on a tire then the internals are stuck forward in the "air out the front" area. Try to give the hole a nice push to the rear and see if the needle kicks in. It works like a faucet sort of.
Pull off the front valve and see if the internal piston moves front and rear while you push it back and the lever will push it forward. I think they are of low quality based on the few I have seen.
Dec 18, 2009 | Schwinn Cycling
How do you inflate a Bicycle tire with the small portable pump? the air is coming from the needle to inflate balls and not from the nozzle. It is a Schwinn small portable bicycle pump.
Usually, the needle used to inflate balls is an attachment to the pump. Is there a lever near the fitting the needle comes out of? Moving the lever 90 degrees from its current position should allow you to pull the needle attachment out. The hole the needle came out of is where the valve stem from your tire goes to pump the tire up. Jam the stem in the hole, crank the lever back to lock it in and pump away. Unlock the lever to release the stem when the tire's inflated and you're golden.
Jul 06, 2009 | Schwinn Cycling
Cycling Logo
Top Schwinn Cycling Experts
Michial Gueffroy
Tony
michael
michael
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
