Question about Health & Beauty
Can I have a replacement head?
Phillips satin ice epilator
    Master:
  • 752 Answers
Generally, yes, replacement heads are available. Depends on the precise model number. I'm assuming tat you have a model HP6436
Try here
Shaving Head Philips HP6405 HP6409 HP6436 HP6455 HP6459 RASURADOR...
or search the Philips website, and maybe ask them.
I found this page
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=HP6436/02&slg=EN&scy=GB
You may have to contact them to find out about buying heads. It probably depends on which country you are in - you don't say. Spare parts are often available less expensively from sources other than the manufacturer.
16.April.2015
Posted on Apr 16, 2015
    Top Expert:
  • 10,875 Answers
Sure
My Silk Epil 7 has stopped working, the epillator head has stopped rotating. I doubt that some hair has got stuck inside. Could ypu please help?
My Braun worked fine the last time I used it & would not come on when I tried it today. Worked on it & found it to be jammed with hair. Would not rotate. Scrubbed it with a toothbrush, started digging out the hair, forced it to rotate, scrubbed it some more, & rotated it some more. The more I worked with it the more hair kept coming out. It's rotating fine now. I think I'm going to clean it with my water pik. My Braun is the kind that can be used with water & the top part comes off. Haven't used it yet but I think I have fixed it. Wish I could get it apart to clean it out but the head of the screw is strange & I don't have anything that will turn it.
Aug 31, 2011 | Braun 5270 Epilator
How to clean a remington EP6010 epilator?
AFTER EACH USE
CLEANING THE EPILATION HEAD Ensure the epilator is turned off and disconnected from the mains. Press the head release button/s and open the head assembly. (Diagram G) Turn the head assembly upside down. Using your thumbs, push the small sides together and push the epilation head upwards. This releases the curved epilation head. Brush the accumulated hair from the tweezers by turning the barrel manually. NOTE: The body of the epilator is not washable. Do not submerge in water.
TO REMOVE RESIDUE To remove residue from the stainless steel tweezers, dampen a swab with alcohol. Gently run the swab over the tweezers until the residue has been removed.
Online Manual: http://uk.remington-europe.com/pdf/ep6010_user_manual.pdf
Feb 28, 2011 | Remington Health & Beauty
How to disassemble the main body of a Braun Silk.epil super soft plus
Take it into a Braun service centre for best results. Or you can follow this video. You will see there are hidden tabs that lock the body together.
How to replace broken battery in Braun Silk epil 7
Aug 21, 2010 | Braun Silk-epil 3370 Epilator
Satinelle HP6409 Epilator: I have epilator philips satinelle ice with europia...
The epilator is universal voltage so the power lead should not matter. You could get an adaptor to convert from Europe to US and that would do fine.
Otherwise, try http://www.support.philips.com/support/service/onlineStore.jsp?userCountry=us&userLanguage=en
May 16, 2010 | Philips Satinelle HP6409 Epilator
The spring has fell out of the head when i was changing top i dont know how it goes back together
pull the black thing with the little blades until it detach, put the spring inside the hole, reassemble
May 09, 2010 | Braun Silk-epil 3370 Epilator
Replacement foil for a Philips HP6453
If you're in Australia usually anyone who is a Breville or a Kambrook Service Center can help you. Their Service Centers are listed here http://www.kambrook.com.au/service_agentsearch.asp?type=parts
Otherwise, go to http://www.philips.com/global/index.page select your country and contact their Customer Service.
Apr 10, 2009 | Philips Philishave Satin-ice 2-in-1 HP...
Emjoi Head AP98R
i have the same problem, I have had this replaced once already. It has just happened again for a second time!! Contacted Sunbeam and they do not sell parts and will not touch as it is out of warrantee!! Sorry
Dec 14, 2008 | Emjoi AP98R Epilator
Health & Beauty Logo
115 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
