Question about Refrigerators
Can I replace my phillips satin ice head - Refrigerators
    New Friend:
  • 3 Answers
Well maybe
Posted on Apr 16, 2015
The ice maker continues to ice over
What is the make and model? I had a similar problem with my LG side-by-side. Found the whole icemaker part online for less than $50us and it took under 5 minutes to swap out with jsut a phillips head screw driver.
Oct 29, 2015 | Refrigerators
Ice Maker not making ice cubes model # FRS26FCDW1
Remove the cover on the front of the ice maker and you will see a large gear with a Phillips screw in the center. Use a screw driver (phillips) and rotate it clockwise. It will start to rotate on its own and should make a revolution and fill with water. If it does replace the ice maker. If it makes a revolution and doesn't fill with water, make sure the fill tube is not frozen, and if it is not frozen. advance it again and determine if power is getting to the valves.
Feb 17, 2015 | Frigidaire Refrigerators
My ice maker won't come out.
When I serviced these units I had to take the freezer door off to access the ice maker. There are two screws in the front of the icemaker and 2 tong and groves which hold the icemaker to the freezer celling. These tong and grooves in the back on the ice maker right and left corners.
Once the ice maker is free, you will need a small flat head screw driver to wedge into the icemaker connector to disconnect the wiring.
If you are 100% sure your problem is the ice maker assembly, you may want to consider purchasing the new assembly before starting this task. This way you can inspect the top to the icemaker for mounting.
The two screws are either hex or Phillips heads. If it is a hex head you need to make sure the 1/4" hex head can fit into the recess where the screws are located. Some 1/4" hex head drivers are too large in outside diameter.
Before you condemned the ice maker have you considered:
1.) There is a square red reset in the front center bottom.
2.) I assume since you have defrosted the freezer there is not a ice cube jamming the ice maker.
3.) And since you defrosted the freezer you do not have a frozen fill tube.
Last thing; press the red reset button. If the ice maker cycles but does not fill, then you have a water supply problem. This could be a kink in the water line, water shut off valve could be bad restricting 50-60 PSI required pressure, or a bad water solenoid valve. Check the solenoid valve for continunity with your Ohm meter.
Oct 26, 2014 | Samsung RF265AA Bottom Freezer French Door...
How to replace fan 3 speed switch in hampton bay ceiling light
Remove the switch housing from the fan with a Phillips screwdriver. Depending on the model, there are either two attaching screws on the base of the switch housing, or three screws around the upper rim of the housing. Once the screws have been removed, unscrew the brass finial surrounding the chain on the outside of the switch housing and pull the chain through to detach the housing from the fan.
Insert a thin flat headed screwdriver into the slot next to each wire; twist the screwdriver and pull the soldered ends of the wires out. If the wires are connected to the terminals with screws, undo the screw a few turns and pull the terminals out from under the screw heads. Undo the two screws holding the switch to the fan and remove it.
  • Take the old switch to the nearest electrical or home improvement outlet and buy an identical replacement part. If there are two similar switches and you're not sure which is the right one, describe the fan to a sales assistant and tell him how many operating speeds it's equipped with.
  • ceiling light
  • May 27, 2012 | Hampton Bay 52 In.Carriage House II in...
    I have a GE Profile refrigerator, Model PFSS6PKWBSS, with icemaker on door. Water is collecting under Deli-draw and leaking down freezer door onto floor. How do I fix leak?
    Hi
    Try and access the ice dispenser assembly and check from where the water is leaking. You would need to disassemble the ice dispenser and ice maker to check this. The ice dispenser is located in the upper portion of the freezer compartment. This assembly stores ice made by the icemaker and dispenses ice on demand from the door dispenser target switch.
    1. Remove the upper ice bucket tray.
    2. Slide out the ice dispenser assembly.
    3. Remove the ice cube solenoid linkage Phillips head screw and slide the linkage back.
    4. Remove the ice crusher cover Phillips head screws (2) and remove the cover.
    5. With a pair of pliers, twist off the backing plate tabs located on either side of the crusher.
    6. With 2 small flat-blade screwdrivers, unlock the ice crusher locking tabs located at either side of the ice crusher.
    7. Lift the ice crusher out of the bucket.
    8. Remove the ice crusher back cover.
    9. Remove the locking ring from the ice crusher auger.
    10. Remove the plastic nut with a pair of pliers by turning it clockwise.
    11. Remove the spacers and blades. The blades are numbered for reassembly.
    Icemaker--
    The icemaker is located in the upper rear of the freezer compartment and supplies ice to the dispenser tub.
    1. Disconnect the icemaker cable connector.
    2. Remove 1/4-in. icemaker mounting screws and slide out the icemaker.
    This refrigerator is equipped with an Electronic Icemaker.
    Hope this helps... Please post back if you need more information.
    Daniel
    May 01, 2011 | Refrigerators
    I am trying to take apart my cuisinart ice cream maker and 3 of the bolts are phillips but the last one I have no idea what kind of head it is and can not unscrew it. Is it some special cuisinart bolt...
    Hey G,
    This bit set has all the "special" safety bits you need... I have one and its always had what I needed..(even has the reverse three blade phillips head.. - they use them on police monitoring ankle bracelets) ....you will need a driver handle..
    good luck..
    100 Pc Security Bit Set with Case
    Dec 16, 2010 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
    How to replace screen on Pavilion dv7-1040us. is diferent from other hps I have replaced, cannot figure out how to remove it.
    Here it is! Have fun!
    1. Remove the four 4 mm P1 Phillips-head screws that secure the hinges to the display panel enclosure.
    2. Remove the two 4 mm P1 Phillips-head screws that secure the metal tabs on the bottom center edge of the LCD panel to the display panel enclosure.
    3. Lift the LCD panel out of the display panel enclosure.
    LCD Panel replacement Note: Before replacing the LCD panel, remove the left and right hinges from the old LCD panel and install them on the new LCD panel.
    1. Place the LCD panel into the display panel enclosure.
    2. Replace the two 4 mm P1 Phillips-head screws that secure the metal tabs on the bottom center edge of the LCD panel to the display panel enclosure.
    3. Replace the four 4 mm P1 Phillips-head screws that secure the hinges to the display panel enclosure.
    To remove in order to replace LCD, you will have to remove WLAN, keyboardwith the instruction :
    Wireless LAN Minicard removal Caution! Observe all precautions when removing and replacing components.
    Before you begin: Remove the battery2_bing.gif.
    1. Loosen the two captive P1 Phillips-head screws that secure the memory/wireless LAN Minicard cover to the bottom of the notebook.
    2. Use your finger or a flat-bladed tool to lift the edge of the memory/wireless LAN Minicard cover and remove it.
    3. Carefully disconnect the wireless antenna cables from the wireless LAN Minicard with a small needlenose pliers or tweezers.
      Remove the two 3 mm P1 Phillips-head screws that secure the wireless LAN Minicard to the system board and allow it to release to the spring tension position.
    4. Grasp the wireless LAN Minicard by the edges and pull gently to remove it.
    5. Place the wireless LAN Minicard in a static dissipative bag.
    Before you begin: Remove the battery.
    3. Remove the 8 mm P1 Phillips-head screw in the memory/wireless LAN Minicard compartment that secures the keyboard to the base enclosure.
    4. Remove the two 8 mm P1 Phillips-head screws that secure the keyboard to the base enclosure.
    5. Turn the notebook right side up and open the display panel fully.
    6. Use a flat-bladed tool or your finger to lift the top edge of the keyboard and slide the keyboard toward the rear of the notebook.
    7. Using minimal force, push the locking bar toward the rear of the notebook to unlock the keyboard ZIF connector on the system board.
    8. Remove the keyboard ribbon cable from the ZIF connector and remove the keyboard.
    Keyboard replacement
    1. Place the keyboard right side up on the top cover and insert the keyboard ribbon cable into the keyboard ZIF connector on the system board.
    2. Push the locking bar toward the front of the notebook to lock the keyboard ZIF connector on the system board.
    3. Toe the tabs on the bottom edge of the keyboard into the top cover.
    4. Press the keyboard flat.
    5. Close the display panel and turn the notebook upside down.
    6. Replace the 8 mm P1 Phillips-head screw in the memory/wireless LAN Minicard compartment that secures the keyboard to the base enclosure.
    7. Replace the two 8 mm P1 Phillips-head screws that secure the keyboard to the base enclosure.
    8. Toe the memory/wireless LAN Minicard cover into the base enclosure.
    9. Tighten the two captive P1 Phillips-head screws.
    Dec 09, 2009 | HP Pavilion dv7-1240us Notebook
    Replacement foil for a Philips HP6453
    If you're in Australia usually anyone who is a Breville or a Kambrook Service Center can help you. Their Service Centers are listed here http://www.kambrook.com.au/service_agentsearch.asp?type=parts
    Otherwise, go to http://www.philips.com/global/index.page select your country and contact their Customer Service.
    Apr 10, 2009 | Philips Philishave Satin-ice 2-in-1 HP...
    Regrigerator shows error code 1F
    Hello tr-6
    Welcome
    You Wrote,
    LFX25960ST LG FRENCH DOOR REFRIGERATOR DATE OF PURCHASE 7-7-07 DELIVERED 7-13-07 ICE MAKER REPLACED ABOUT THIS TIME LAST YEAR AFTER TWO MONTH WAIT. NOT PLEASED WITH PERFORMANCE OR SERVICE TO DATE. REQUEST THIS PROBLEM BE COVERED BY WARRANTY.
    Below is the service manual And the explanation for your error.
    Thank You for using our site.
    Huuum
    Please remember to leave a solved rating.
    Error Detection Category
    ERROR CODE : IF
    Abnormality of
    BLDC FAN Motor
    for Ice Making
    Error Generation Factors
    It is caused when F/B
    signal isn’t over 115
    seconds during BLDC
    FAN motor operating
    Remark
    Poor BLDC Motor
    connection, DRIVE IC, and
    TR
    Resource reference located here:
    http://136.166.4.200/contents/Fridge/LFX25960/LFX25960_Service_Manual.pdf
    Huuum
    Oct 12, 2008 | LG LFX25960ST Stainless Steel French Door...
    Refrigerators Logo
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
