What's your question?aucma tv 21' picture display on asingle line horzontally
3 Suggested Answers
  • 13 Answers
SOURCE: Toshiba TV..Approximately 4in of horzontal lines
Capacitors going bad in Vertical. Model please.
Posted on Oct 24, 2009
caroldon
  • 17129 Answers
SOURCE: I have BPL 21 Studioline 1000W, problem is
The best way to check for loose connections is to tap lightly when the set is powered on , If there is change while tapping then it seems that there are DRY solder joints. Remove main plug, the covers - with caution of high voltage, check for dry joints, use a good soldering iron to solder all suspected points.
The fault is the FAILURE OF THE SOLDER IN THE VERTICAL IC OF THE TV.
Sometimes the fault occurs when the set warms up, if so you can simulate the heat using a hair dryer on the suspected areas, try with the power supply, distribution, Processor controller, driver controllers on the A/V related sections. Also the use a FREEZE-IT spray can simulate the components to cool and show up the fault.
Based on the above method you must be able to locate the area of fault and solder the sections. Sometimes large IC's- ones with more pins- tend to have drying in some pins and so cause faults related to the IC's protocol. Have a rough idea of looking into the areas to reduce the time of probing.
Posted on Jul 25, 2011
Kv-35xbr48 turns on fine nice picture then horizontal lines form distorting picture like interference also is the back hard to take off and put on needs a good vacum thanks for any suggestion
At first the picture is ok, and then distorted with horizontal lines i thinks. If the horzontal lines are parellel acros the screen, with an inch apart across the whole screen, your tv needs screen adjustments. Screen voltage may be high. look into the crt base also. Change it first. These also not resolve the problem, LOT may be faulty, with respect to screen focus pack. May need replacement. Try first setting screen voltage to a lower settings and observe.
Oct 14, 2010 | Sony KV-35XBR48 35" TV
Ther is a white horzontal line in the middle of my tv and i dont hear or see the screen
he white horizontal line with no picture is ususally caused by a failed Flyback transformer in CRT type TV's
repair cost about $200
please rate my help++++Thanks for using FIXYA
Jun 23, 2010 | Televison & Video
TV Screen picture reduced to one quarter in size.
You may have a bad capacitor. Do you have horzontal lines near the top? What is the model#? And what year? But ,yes indeed there is a bad cap inside your TV.
Nov 29, 2009 | Philips Televison & Video
Samsung Plano 21
Hai
 My "Samsung Plano Dnie Jr Tv " is Screen Problem.Tv Display is Fully Blackish color and display center is One White Line will be come.
Jun 28, 2008 | Televison & Video
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
Electro Med Services...
