Question about Bernina Sewing Machines
How do I clear cotton in bobbin case of Bernina 830E
Because machine is computerised unable to move bobbin wheel
  • Bernina Master
  • 1,860 Answers
Take the needle out of the needle holder
remove the needle plate, be careful not to damage the screws
take the bobbin out and use a small brush or a can of computer air to clean dust, use a pair of tweezers to pull the thread of the bobbin area if needed
Posted on Jun 03, 2015
SOURCE: Bernina 1130 not catching bobbin thread
there will be a adjustment in that you should select the stiching mode and in that give the straight mode the problem will be solved
Posted on Jun 05, 2008
SOURCE: Bobbin Case
I'm having a similar problem today. I took out the bobbin case and when I went to put it back in, the whole system locks up. I've tired cleaning, changing needle taking the metal plate and piece that holds bobbin case out and put it all back in after cleaning. Nothing. My symptom is I can't get a complete stitch, the needle goes down, the whole deal acts like it will work and as soon as the arm of the bobbin case gets to 8 o' clock on the gears, It jams and won't hardly move. I cannot pull the bobbin case out easily after this. Perhaps there is someone out there that can help us!
Posted on Jun 23, 2008
SOURCE: while sewing the bobbin case moves, wheel locks up, needle locks
Im not sure if this will help but thought I would pass it along. My Pfaff 6122 tells me to check bobbin for thread unrolling clockwise before you place it back in the machine. I had mine turned to un roll counter clockwise, this is wrong, the bobbin will fall out when you pull on the thread while you are holding it in your hand. You may just keep putting it in backwards. Hope this works for you. J.R.
Posted on Feb 05, 2009
RickE1
  • 202 Answers
SOURCE: Machine not working after bobbin installation
Hi, it may be possible that you put the bobbin in the case upside down and its turning the wrong way. Flip it over and try it. When looking at the bobbin in the case from the back and you pull the thread, it should turn clockwise.
Hope this helped as anything else may take a tech to diagnose.
Rick
Posted on Mar 25, 2009
zlana91
SOURCE: My bobbin case came out
I just had this same problem and although i could not find the answer online, I managed to fix it.
If you look at the bobbin case there are 3 different tabs sticking out.
First you need to have tab #1 under the main part of the machine, and #3 over top of the small twisted metal piece below the bottom fabric gripper.
The hard part is to get the second tab into the proper spot. I circled the piece that you need to move in red. If you move the little piece by pushing it with a flat screw driver, you can line up the bobbin case so that tab #2 is under the metal piece and the bobbin case will be properly set.
Don't give up! It wasn't easy to get it back but I did it, I'm sure you can too!
Posted on Sep 06, 2012
I have a bernina 801 sewing machine. I am unable to dis engage the wheel to reload the bobbin, it will not turn
Have you ever lubricated it? Sewing machines must be periodically cleaned and lubricated or they will get stuck and freeze up
Nov 20, 2014 | Bernina Sewing Machines
Why won't Bernina Record 830 Foot Pedal won't move the needle?
could be something wrong with the foot pedal or could be a problem with a connection inside the machine.
Jul 27, 2014 | Bernina Sewing Machines
The machine will not turn the spindle to wind cotton onto the bobbin.
What model Bernina is it? Most operate on a simple system where a rubber wheel on the bobbin winder comes into contact with the handwheel (under the cover) ... the handwheel is disengaged so the needle has no drive.......
Apr 13, 2014 | Bernina Sewing Machines
My Bernina Deco 340 does not pick the bobbin thread but keeps saying the top thread is broken
Check the needle timing. Go to bernina on the web and download the service manual for your model. The eye of the needle should be at the pick arm of the bobbin case Too early or late and it will miss the cotton.
May 30, 2013 | Sewing Machines
Loose top thread bernina 1008, tension problem but no solutions yet...
Are you sure you are getting the top thread between the tension discs? You should be able to tell the difference when you lower the pressed foot.
Jan 27, 2013 | Bernina 1008
Need bobbin case for bernina 850
I know where one is - I was using my machine a Bernina 850 when the cotton started to tangle I was so frustrated I threw the bobbin case in the canal and that is where it lies today. The canal is between Palmetto Crt and San Michelle Court Broadbeach Waters. It may be a little rusty now but you could always derust it. Good luck with your search
Oct 17, 2012 | Sewing Machines
My Bernina 1090 keeps breeaking the bottom thread. It sews about 10 inches and breaks. I take out the bobbin and rethread and it sews a while but still breaks. I have had it in for service 3 times and...
Assuming your bobbin tension is not too high, make sure the bobbin case is clean on the inside - use a cotton bud to clean it out. Are you using good quality Bernina bobbins - if not you're on a hiding to nothing ! It is possible that the bobbin case is deformed, but most likely your service man has set up the tensions too high ... look for someone else !
Jan 21, 2012 | Bernina Sewing Machines
Just bought my used Bernina 1010;it was sold to me
Heat the wheel with a hair dryer to loosen. If this does not help, you will need to visit an authorized Bernina dealer.
Jul 21, 2009 | Bernina Sewing Machines
Bernina 910 sewing machine extension table
Hi Phoebe,
What you have is the extension table for the 830 and the 830E Bernina models. What you need is part number 301 276 100. This table looks a little different as it has a small see-through window in the bobbin area and also, it has no clamp (it has push-in pins). Ebay or a site like SewItsForSale is your best bet. I doubt the dealer could get one but if they could, it'd be likely around $100.
Jan 17, 2009 | Sewing Machines
Sewing Machines Logo
66 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
