Question about Panasonic Lands Phones
CAN'T IDENTIFY Panasonic HANDSET. THE BASE UNIT IS PNLC c1010
NEED TO CHANGE MESSAGE
  • Panasonic Master
  • 3,957 Answers
It has to be one of these. The charger number you referenced is used on all models covered in the manual.
http://service.us.panasonic.com/OPERMANPDF/KXTG4011-MUL.PDF
Posted on Apr 16, 2015
Have a Panasonic KX-TG1061C with 3 handsets. Handsets work perfectly. None of corded base unit buttons work.
to turn off night mode http://www.manualslib.com/manual/793900/Panasonic-Kx-Tg1061c.html?page=25
do not think night mode would cause your problem.
check dialing mode #120
TONE ?
When you unplugged the base unit did you pull out the ac adapter for about 30 seconds to reset the base unit ?
Jan 04, 2015 | Panasonic Lands Phones
How do I delete old messages on a Panasonic PNLC 1040?
The PLNC1040 is the part number for the handset charging base and not the model number of the unit.
What message are you making reference too, the caller id or the answering machine messages? For the answering machine, the model number is found at the bottom of the main base, for the caller id, the model number is found in the battery chamber of the handset. List that information and I will supply you with the information you want.
Nov 07, 2014 | Lands Phones
Panasonic phone says check tel line
Check cable conections from phone box on wall to base unit, make sure that the conectors are fully inserted. If possible plug a different phone into box to make sure that line is working. Hope this helps
Jun 08, 2017 | Lands Phones
I changed oil and message is still there
You must reset the oil change due message, refer to your owners manual for instructions on how to do this. If you don't have the owners manual you can download one free here
Aug 06, 2012 | 1999 Ford Windstar
Need to change voice message HOW
access your voicemail, and choose the persoal options option, and you can then change your voicemail message, or choose a standard message with your number. good luck.
Nov 20, 2011 | Lands Phones
The line 2 ringer is off (it displayes message "ringer off line 2" on the number 2 remote phone panasonic kx-tg6700 & I cannot figure out how to turn it back on
Please try this first (Reset the phone which requires the ringer to operate again with the main base) Some Panasonic cordless phones come with up to five handsets each will need to be properly adjusted. You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phone
Jan 20, 2011 | Panasonic Lands Phones
Some Panasonic cordless phones come with up to five handsets each will need to be properly adjusted. You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phones.
Jan 20, 2011 | Panasonic KX-TG6700 Phone
System error #1 Panasonic kxtg2770
1)On handset, press MENU, 0, 0, 1.
Handset display shows as follows.
*Skip this step when handset already shows as above.
2) On base unit, press LOCATOR for 3 sec until CHARGE LED flashes.
3) On handset, press OK button. Then wait until the handset display changes as follows.
If you receive an error message indicating the maximum number of handsets have been registered, you will need to deregister the handset from the base unit, then try to register again.
*If this does not work, your unit is defective. Please send your unit for service.
Panasonic Services Company Customer Servicenter
Suite B 4900 George McVay Drive
McAllen, TX 7850
McAllen, TX 7850
1) Press FUNCTION on handset. Then, using the Navigator key, press Down (V) 4 times, Right (>) 1 time, Down (V) 7 times, Right (>) 2 times.
2) On base unit, press MUTE. (MUTE LED flashes.)
Dec 04, 2010 | Panasonic KX-TG2770 Phone System w/...
Change the logo message on a sharp xe-a21s
i need to program the crv on the machine. can some body help me?
Feb 02, 2010 | Sharp XE-A402 Electronic Cash Register
Lands Phones Logo
113 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
