Question about IBM Computers & Internet
Backup using Tape LTO06 TS32000 IBM Library
When a make backup using tape LTO06 TS32000 IBM Library, i have that errors: He: Drive Broken needs repairs F3 01. What is happened with tape?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 122 Answers
Tapes do brake, at the end of the day they are mechanical devices.
Just throw it away and buy another one.
But it can be reformatted or checked using IBM utilities from the atape drivers in case you still want it (ITDT or tapeutil)
http://www-01.ibm.com/support/docview.wss?uid=ssg1S4000662.
Posted on May 07, 2015
Kidyubyub
  • 143 Answers
SOURCE: Tape eject from drive
Hi. This is from Dells site regarding automatic ejection of tape once inserted:
The PowerVault 110T DLT VS160 Tape drive reads and writes DLTtape VS1 cartridges. The PowerVault 110T DLT VS160 Tape drive can read - but not write - DLTtape™ IV cartridges written using the DLT1/VS80 format. NOTE: The PowerVault 110T DLT VS160 Tape drive automatically ejects any other cartridge types and any cartridges whose format it cannot read. Make sure all cartridges that you want to use for writing are DLTtape VS1 cartridges.
Perhaps your cartridge is improperly formatted or is of the incorrect type?
Posted on May 23, 2008
SOURCE: Error on IBM 3581 tape library.
Error 5 might be the drive motor might be faulty.
Posted on Oct 15, 2008
SOURCE: medium changer did not show
Check that the unit is set to random mode instead of sequential mode
(FYI Sequential mode treats the whole machine as a single big tape, while random lets the software say what tape is going to be used.)
Posted on Nov 05, 2008
  • 16 Answers
SOURCE: Tape stuck in drive
The best way that I have solved this is by using the move commands from the drive, and move it from drive to any free tape slot. Also if that does not work, put a few tapes in the drive and perform the random moves test in diagnostics, that will fool the drive to move the tape.
Posted on Jul 20, 2009
MrTyke
  • 95 Answers
SOURCE: I have IBM ULT3580 HH4 backup tape drive want to
Have a look at the IBM Tape compatiability chart
Posted on Nov 30, 2009
IBM TS 3100 drive broken
how to repair Tape drive broken ts3100 ibm
Jul 04, 2012 | IBM System Storage TS3100 Tape Library...
I was trying to backup my server while exchanging DLT tapes, the tape in use light stayed on and the serve would then alternate to four flashing lights and then back to flashing "Tape In Use...
Try the following action to resovle your issue:
1. Run the Drive Assessment Test in HP StorageWorks Library and Tape Tools.
CAUTION: Running the Drive Assessment Test overwrites the tape. If it is not possible to
overwrite the tape, run the logs-based Device Analysis Test instead.
2. Check the backup logs.
3. Verify that a supported configuration is being used.
4. Check for media damage:
o Incorrect label placement
o Broken, missing, or loose leader pin
o Damaged cartridge seam
o Usage in incorrect environment
5. Check for software issues:
a. Check the backup software.
b. Check that virus scanning software is not scheduled to run at the same time as the back-up.
6. Verify that a tape can be formatted.
Tape Error LED is flashing:
1. Reload the suspect tape. If the Tape Error LED stops flashing, the problem has cleared.
2. Load a new or known good tape. If the Tape Error LED stops flashing, the problem has cleared.
3. Reload the suspect tape. If the Tape Error LED flashes, discard the suspect media as faulty.
From my experience, most of the time it is a bad tape, using a new tape usually solves the problem. If after inserting a new tape and the problem exist, you may need to update your firmware/backup software.
Good Luck
C2Solutions
Jan 13, 2011 | HP Compaq ProLiant ML350 G3 Server
We are having an issue with our backups. The system event log says there is an error 7 and lists the tape drive as having a bad block. However the quantum diagnostic tool shows the drive to be healthy. ...
Event ID-7 is a "Bad Block" on the Tape being using. By design, when a Bad Block is encounter, the Tape Drive "Seizes the Tape" and goes offline. It can sometimes be difficult to get the Tape Drive to release the Tape. Refer to the Users Manual for instrcutions on how to Reset the Tape Drive. Sometimes applying the Firmware Update willl reset the Tape Drive and Eject the Tape.
Do not assume the Tape is Bad, but do not re-use until tested. The Tape may be Bad, the Tape Drive may simply need Cleaning or the Tape Drive may be Worn or Damaged. If you are using 3rd Party Backup Software, such as Backup Exec or Yosemite, you wan want to check the Removable Storage Servcie to see if it is set to Manual or Automatic. Any Tape Devices would need to be first Deleted in the Library Section of Removable Storage, then Sop and Disable Removable Storage. Since Removable Storage is in effect NTBACKUP, this Service can interfere with the Operation of your Backup Software and generate "Bad Block" Errors.
To Test the Tape with your Quantum Tape Drive, use a tool called XTALK ( xTalk-6.4.1.1_Quantum_Setup.exe ) that is found on Quantums Website http://www.quantum.com/ServiceandSupport/Index.aspx
You may run a write_read_full Test on the Tape. Be sure to Clean the Tape Drive first. If it fails the Tape, try it with a 2nd Tape, If it fails again, suspect the Tape Drive.
OldCountry73436
Oct 04, 2010 | Quantum DLT-V4 DLT Tape Drive
I want to know about IBM TS3200 tape library. In that which library is mapping with which tape drive?
trial and learn...
place only one tape drive in a deck and tell it to do a backup till it doesnt give an error. then move to the next drive.
Jun 10, 2010 | IBM TS3200 LTO4 TAPE LIB W/ SCSI (3573L4H)...
DDS-5 not compatible with windows 2008
I am pretty sure that the driver should be compatible with win08.
If you are using backup exec then try switching to use symantec drivers for your tape drive (setting withing BUEX)
If it is just the tape that cant be read or identified and was backed up using windows backup then try restoring the backup on a 2003 server and then copying the data across the network.
May 10, 2009 | HP 364446-001 Storageworks DAT 72x6 DDS-5...
I am unable to get IBM UlTrium TD4 SCSI device drivers for windows 2000 server
if you "have not" using Backup Software (e.g. Symantec Backup Exec, CA), you can try this IBM LTO-4 driver for Win2K.
IBM LTO-4 Device Driver for Windows 2000
Ned Huang
Tandberg Data Taiwan
Technical Support.
Oct 15, 2008 | Computers & Internet
Medium changer did not show
Aug 07, 2008 | Quantum ValueLoader SDLT 320 Super DLT...
Quantum ATL SuperLoader
If you cannot physically load a tape into the drive it is a hardware problem and the drive requires service. It is not a software problem.
Of course, the library could already have the maximum tapes it can hold. If this is the case then eject a tape from the library to make room for the tape you want to add.
I hope this helps.
Apr 17, 2008 | Quantum ValueLoader SDLT 320 Super DLT...
Error 5 states that there is a problem with the drive and not the library, either the tape path or read/write head. Replaced drive - works fine
Apr 01, 2008 | IBM 3581 Ultrium Ultrium Tape Drive
Computers & Internet Logo
763 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
