Question about Refrigerators
Not making ice. Made sure it is shut properly
    Top Expert:
  • Refrigerators Master
  • 10,875 Answers
Read your manual
Posted on Apr 16, 2015
My icemaker on LG refrigerator is making very few ice cubes
If the ice maker is producing ice poorly, making small cubes or too few cubes then it means your ice maker is probably have a clogged water line, a defective water-inlet valve, or a defective ice maker mold thermostat that is not cycling properly.
First, check the water line that's attached to the back of the refrigerator. Make sure it is having a good water flow. If the flow is poor, that means you will have to, repair, clean, or replace the tubing or the shut-off valve that supplies the water in the ice maker.
Second, check the water-inlet valve. You will need to replace the water inlet valve if it has failed.
Third, check the freezer temperature. It should be 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
Lastly, check the ice maker mold thermostat. Make sure that it's cycling properly.
The above is what you need to check on........
I hope this helps....
Take care.
Mar 08, 2011 | Delfield Reach-In 6025X-LG Refrigerator
My icemaker for the LG French Door/Bottom Freezer Model # 25770SW is making very little ice.
Take care.
Mar 08, 2011 | Refrigerators
My ice maker quit making ice on my amana bottom freezer
Hi, If your ice maker has stopped making ice then you need to check these things.
The lever that controls the ice maker has been pushed up which turns it off. If you have a red lever, pull it down to the wire and if you just have a wire then just pull down the wire to start your ice maker up.
Make sure the freezer temperature is below 10 degrees F If the freezer is too warm ice production will be poor because the ice maker will not cycle properly.
The ice maker fill tube may have ice formed in it, blocking it. Use a hair dryer to melt the ice. Watch out for the plastic parts, so that you do not melt the plastic. Also check the water inlet valve and the shut off valve, to make sure it is not plugged with debris. The openings in those valves are very small.
Check the gears in the ice makers to see if they are broken or stripped. Also look to see if the ice rake is broken. All parts in the ice maker are replaceable individually, If you find broken parts replace them.
Take care
Jul 23, 2010 | Amana ABB1927DE Bottom Freezer...
I have a Hoshizaki Model KM500MAE that keeps freezing up. What can I do to stop this problem
several things cause freeze ups.
If you have water filters on the water system, be sure they are not restricting the water flow. water flow pressure should not go below 20 psi.
The bin stat may not be shutting off the unit properly. It should shut off machine within 10 seconds of ice making contact.
Make sure the float switch is not dirty. Be careful when cleaning. Fragile
Make sure water pump runs the entire time it is in the freeze cycle.
Be sure the evaps are clean. Ice cubes will hang on if not clean.
Water solenoid has a screen where the water line screws on to it. Turn off water and check screen to be sure it is clean. This can restrict water flow.
Make sure water valve closes all the way. Turn machine off and see if water is still running. Valve may be leaking water thru.
Dip switches on the board, #1 and #2. Turn them both on and it will change the defrost time to 3 minutes. If both are off, they are set on 1 minute.
Hope this solves your problem. Let me know
Apr 07, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Ice is forming around the ice maker where the ice dispenses through the opening in the door. I have taken out the ice drawer and washed it so that there is no more ice. I have also eliminated the ice...
Check and make sure that the flap that lets the ice out is shutting properly. When warm air enters the freezer door, it condensates then water freezes forming your ice. If this is your problem, they make a kit that replaces it. Good luck...
Nov 17, 2009 | Refrigerators
Tube feeding ice maker comes off
Good day,
Common problem. Remove ice maker, and make sure tube fits all the way to the rear and seats properly.
Then reinstall ice maker and telescope front part of file tube until it fits into ice ice maker properly. (retaining clip in place).
For the cost, a new fill tube makes sense. Also.........
If the water valve leaks slightly after shutting off during a fill cycle, a plug of ice will build up inside the the fill tube, pushing it off on the next fill cycle. Requires installing a new water valve.
Nov 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ours kitchenaid icemaker has stopped making ice. It makes a few very slowley. It has clogged up in the box a few times and we have taken it out and cleaned it out of the frozen pieces. Do we need a part?
hello. i can assist you.
If the ice maker is producing ice poorly--making small cubes or too few cubes--you probably have a clogged water line, a defective water-inlet valve, or a defective ice maker mold thermostat that isn't cycling properly. Check these:
  • The water line that's attached to the back of the refrigerator. Make sure you have good water flow. If the flow is poor, repair, clean, or replace the tubing or the shut-off valve that supplies the water.
  • The water-inlet valve. Replace it if it has failed.
  • Check the freezer temperature. If should be 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker mold thermostat. Make sure that it's cycling properly.
Jul 02, 2009 | KitchenAid 22.0 cu. ft. Side-By-Side...
Ice maker is afflicted
Hello there. Sorry for your trouble. Your problem is common. I will try to help u. here is some information to get you started:
Get back and let me know if this helped and what is still a problem.
May 21, 2009 | Refrigerators
Whirlpool ice dispenser not working, but water is
There are three common problems with icemakers:
There's no ice
Small or too few ice cubes
Specks in the cubes
Note: If your repair problem isn't listed, click here to email the RepairGuru. He will give you the help you need.
There's no ice If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Small or too few ice cubes If the ice maker is producing ice poorly--making small cubes or too few cubes--you probably have a clogged water line, a defective water-inlet valve, or a defective ice maker mold thermostat that isn't cycling properly. Check these:
Specks in the cubes If you find black or gray specks in your ice cubes, have a look at the ice cube tray. If the protective coating is peeling away, the most economical solution is to completely replace the ice maker.
Apr 01, 2009 | Whirlpool GS6NBEXR Side by Side...
Ice maker will not work
Apr 01, 2009 | Frigidaire Optional Icemaker Kit
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
