Question about EPoX EP-8KRAI-X Motherboard
EP-8KRAI motherboard does not see WD2500AAKX SATA HDD
BIOS VIA SATA utility scans devices "Hardware Initiate Failed, Please Check Device!!! The BIOS does not be installed. Press to continue!"
  • 1,602 Answers
Check the cable
make sure the hd is getting power
try another sata connection by swapping the cable from dvd device
make sure you set the drive select some drives require it
do not use cable select
make sure the battery back up has 3 volts
you could try shorting out the bios to reset the motherboard - there should be a jumper on the board, turn power off, the jumper or connect the two pin so the short out, than turn on machine, just for few seconds and turn off, remove the jumper.
xxxxxxxxxxxxxxxxxx important xxxxxxxxxxxxxxxxxx
before or when booting the system push F10 to access bois
setup all devices, dvd, video card, if that dont work you can try F1 or F2 when you start the system
when you exit the bios make sure to save it i think F10 save and reboot. so save new changes and device ID.
Posted on Apr 17, 2015
Install a 2nd hdd (sata) on dell optiplex 360 not working
Can the disk viewed in disk management?
Right Click 'My Computer'-->Manage-->storage-->Disk Management
Disk 0 usually for windos partition (your 80GB HD)
If Disk 1 (your TB HDD) show unallocated, you need to format it to NTFS.
Right Click and select 'Format'.
!!!!Make sure it is your TB HDD!!!!!!!
Jun 08, 2012 | Dell OptiPlex 360 Desktop Computer
I got a new SATA 500gb HDD but the motherboard wont detect it.
Access to your Bios Setup & configure the Bios settings.
Features Setup Page : This page sets up some parameters for peripheral devices connected to the system.
CMOS SETUP UTILITY - Copyright (C) 1985-2003, American Megatrends, Inc.
Features Setup
OnBoard Floppy Controller : Enabled
Serial Port1 Address 3F8/IRQ4 : Enabled
OnBoard IR Port : Disabled
Parallel Port Address : 378
Parrllel Port Mode : ECP
ECP Mode DMA Chnnel : DMA3
Parallel Port IRQ : IRQ7
OnBoard PCI IDE Controller : Both
OnBoard SATA-IDE
: Enabled *(Make sure This is enabled)
Audio Device : Enabled
Modem Device : Auto
Ethernet Device : Enabled
If you have got a SATA III HDD, ie if it is a Western Digital Sata III you need to configure the jumpers to work with your older Sata interface port.(Only Sata 1 & 2 ports on your Mainboard Socket 478). As for Seagate Sata III HDD, the configuration is automatic.
If your 500GD HDD is not detected, try updating the BIOS!
A word of caution "Updating the Bios is not for the Novice" Do it at your own risk. Failure in updating the Bios may render your Mainboard useless.
Hope it helps.
May 14, 2011 | PC Chips M955G Motherboard
Hardware initiate failed please check device.. system cant detect myh sata HDD.. need help
Hi. Thanks for your question.
Troubleshooting this problem will take few steps to complete.
  1. Please try and switch your HDD Sata cable from one port on motherboard to another available. If there is no available slot just try and disconnect your DVD drive for now and plug it into that slot.
  2. If no luck with first method you need to make sure that your Hard Drive is still operational. Take it to your friend or anyone who would let you try it in their PC.
  3. Make sure you use known good cable all the time. Buying new cable would be the best, or using available one for testing/now (dvd drive one?)
After you completed them test you should be able to tell if your cable is ok is port on motherboard ok and is it the hard drive that failed.
I hope you will get your computer working soon. Please do not hesitate to ask more questions if this is needed. Thank You for using FixYa
Dec 15, 2010 | ASUS P4V8X-X Motherboard
Controller MSI K8N Neo4 does not work
SHUT DOWN COMPUTER AND CLEAR CMOS BY RESETTING JUMPER ON MOTHERBOARD AND THEN RETURN JUMPER TO NORMAL POSITION OR USE RESET BUTTON. UNPLUG ALL HDD SATA CONNECTORS FROM HDD. BOOT COMPUTER TO BIOS. MAKE SURE ENABLE ALL SATA IS ENABLED, PRESS F10 AND EXIT.YOU WANT TO SHUT DOWN AGAIN. NOW REATTACH SATA HDD AND CONNECTORS AND BOOT TO BIOS AGAIN. NOW HIT F10 AND LET COMPUTER RESTART AND LOAD INTO THE OS. LOGON AND CHECK DEVICE MANAGER..SHOULD BE THERE. IF NOT CHECK MOTHER BOARD WEB SITE FOR BIOS UPDATE. IF BIOS UPDATE DOESN'T DO THE TRICK, SHUT DOWN AND DISCONNECT THE IDE DRIVE, UNLESS IT CONTAINS YOUR OS. TRY BOOTING TO BIOS AND CHANGE ORDER OF 1ST BOOT OPTIONS, HIT F10 AND EXIT AND ALLOW COMPUTER TO BOOT TO OS, THEN LOGON, GO TO DEVICE MANAGER AND REMOVE IDE AND RESTART, ONLY IF THIS HDD DOES NOT CONTAIN OS. YOU SHOULD BE FINE AFTER THIS, OR INSTALL YOUR OS ON THE SATA HDD.
Apr 09, 2010 | MSI K8N Neo4 Platinum nForce4 ultra K8...
Bios not detecting 320gb sata drive
Double check the jumper configuration, You might also want to check the cables and ports incase that's the problem because a properly jumpered SATA drive shouldn't have any compatibility issues. Also check if *********** board supports the SATA ? Let me know if this works..thanks. Mike
Mar 04, 2010 | PC Chips M955G Motherboard
Doesn't recognize SATA hard drives. BIOS option
Need to install latest bios update go to there website also if you are trying to boot up with usb installed take it out. BIOS ID:15
  1. Fixed the issue where SATA HDD boot up will fail if USB storage device is installed.
  2. Fixed the issue where SATA HDD boot up will fail if "USB keyboard/mouse" setting as "BIOS" section.
  3. Enhance the compatibility of SATA device on WIN98SE/ME.
  4. BIOS compile date: 06/07/2004
Nov 28, 2009 | Abit KV7-V Motherboard
I need drivers to my motherboard EP 8KRAI-X
Drivers for this motherboard can be found at the following website:
http://www.epox.com/USA/downloads.asp?class=DRIVERS&item=EP-8KRAI-X
Mar 12, 2009 | EPoX EP-8KRAI-X Motherboard
I have a new 8ogb sataII Exelstor hardisk which i
Windows XP does -not- have native SATA support and therefore will not recognize a SATA drive without first installing 3rd party drivers.
To go around this problem without installing drivers check your BIOS. There might be something in there where the bios will emulate an IDE controller.
If not, you'll need a floppy and the sata drivers. A flash drive will also do if the motherboard bios supports legacy USB. To find the drivers, simply go to the motherboards manufacturers website.
Mar 03, 2009 | EPoX EP-8KRAI-X Motherboard
My hdd sata is not detected by motherboar.
brohter you should chek you r hardisk and then check ram GOD WILLING YOUR PROBLEM WILL BE RIGHT IM RIAZ AHMED BROHI FROM PAKISTAN PLEASE EMAIL riazbrohi@gmail.com
Jan 24, 2009 | MSI K8MM-V Motherboard
SATA problem
Your bios is corrupted & needs to be flashed.
You will need to download the bios flash utility & a bios file.
creat a floppy disk with these to files that you can download from here. Click the link below.
http://support.asus.com/download/download.aspx?modelname=P4V8X-X&SLanguage=en-us
If you are not comfortable with flashing your bios you can order one from Asus by calling 510-739-3777 CA. Please have your model Number ready & S/N located on a white sticker on the pink serial port.
Good Luck!
Mike
Mar 19, 2008 | ASUS P4V8X-X Motherboard
EPoX EP-8KRAI-X Motherboard Logo
81 people viewed this question
Top EPoX Computers & Internet Experts
Steven Burn
Steven Burn
David
David
Are you an EPoX Computer and Internet Expert? Answer questions, earn points and help others
