Question about Printronix P5000 Printer
Hardware twsting msg ??
I got error msg of hardware testing
    Sergeant:
    Habit-Forming:
  • Printronix Expert
  • 124 Answers
Your Main Board (called a CMX) has failed. You can google
"PRINTRONIX 157450-991 PWB,CMX,V 5.5 40MHZ,EXCHANGE,P5000 "
For the part, but the part will require software either pre-loaded or you will have to get the file to load, ask about that before you purchase this or it will not work when you get it.
Posted on Jun 25, 2015
Error code 0142 message error code 2000-0142
My computer did boot up to the desktop, but was completely unresponsive from there when trying to open anything. I ran a system diagnostics and got this error with the status byte of 70. I rebooted into Safe Mode and was then able to open files. I backed up my stuff to a flash drive and then ran Error-Checking in the HD Properties which runs the CHKDSK function the next time the computer is rebooted. That found 2 bad file clusters and repaired them. One was a file called Windows.edb, which does the hard drive search indexing for Windows and was most likely my problem with the lockups. The other was a Napinsp.dll file. After these were fixed and the computer was rebooted, everything worked normally.
This HD is only 9 months old, but if this happens again, I'll replace it again.
Apr 21, 2012 | Dell Inspiron 6400 Notebook
Fatal Error: Msg display - "No
vga driver or directx 9 not installed or curropt
Aug 11, 2011 | Computers & Internet
When I started my DELL Inspiron 1525 running Win 7 Ultimate, I got a white-on-black screen which questioned the voltage from power adapter. Diagnostic program run.. Stopped with the following msg: Error...
2000-0142 and 2000-0146 are hard drive SMART errors, indicating the HDD will fail.
To boot message about the AC adapter was a BIOS level message that normally appears when a Auto/air ac adapter or other 65 watt ac adapter is used to power the system.
Jul 16, 2011 | Dell Inspiron 1525 Laptop
When I try to load my recovery cd on an old toshiba tecra 9100 I get an error message about 30% of the way through the recovery . The error msg is ' Error- extraction failed'. Is this a hardware...
Sounds like software problem. Error on extracting the file from the recovery cd to the hard drive. But to make sure, run a diagnostic test for the hard drive if the recovery cd includes that option, if not, try another recovery cd.
Hope this helps.
Jun 11, 2011 | Toshiba Computers & Internet
How to fix a error code 0142 msg 2ooo-o142 msg unit:prive self test failed.stuaus for a dell labtop
Ok well I have a Dell Inspion 1525 and I have been having problems with it the last little while so I ran a diagnoses tests and I got this:
Error: 0142
Msg: Error code 2000-0142
Msg. Hard drive 1- self test unsuccessful status: 79
Just wondering what exactly it is, and how to fix the problem?
Or if I have to reformat my whole computer
  • 1 year ago
Mar 22, 2010 | Computers & Internet
Error Code: 1000-0146; MSG: Unit 0:DST Log contains previous erro
Code 0146 is hard drive read/write failure.
Replace the hard disk drive
Jan 27, 2010 | Dell Inspiron 6000 Notebook
DST log contains previous errors.DST short test failed
Error Code: 0146
MSG Code: 2000-0146
MSG: 1:DST Log contains previous errors
Dec 22, 2009 | Dell Latitude D600 Notebook
Graphics card failure
the error: (Under this test, results show Error code 5300: 0119, which different comments for different parameters) Msg: Detected a failure while writing and reading video memory. (e.g.) Video mode: Dh (320 x 200 16) Address A002Ch, expected to read Oh, but read 1Dh instead *
indicates the video card has failed and need to be replaced.
Apr 14, 2009 | Dell Inspiron 8500 Notebook
D610 DST Short Status Test Fail
It appears your hard disk has died and it may not be possible for you to retrieve your data.
Remove your hard drive from the laptop and insert it into an USB harddrive adapter, (they are not expensive and you can use it later as a external hard drive). Then plug it into the USB port of a working computer. The computer should/may see it as an external drive, if you are lucky you will be able to copy your data, if not, you are out of luck.
There are companies that can recover data from faulty hard drives, but it will cost you an arm and a leg for their service.
Feb 17, 2009 | Dell Latitude D610 Notebook
Printronix P5000 Printer Logo
71 people viewed this question
Top Printronix Office Equipment & Supplies Experts
Cliff
Nick
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
