Question about Acer XD1150 DLP Projector
My acer projector fails to power on
No power on red light
Red power, blinking red temp
if the Lamp error and Temperature error lights are flashing red this means that there are two separate errors.
  • A flashing lamp light means the lamp failed to ignite. It could be a lamp driver problem or lamp failure. Replace the lamp to resolve the issue. If the issue is not resolved, then service the projector.
  • A flashing Temperature light signals a fan error. Turn the projector off and allow it to cool down. If the light is still flashing after the projector is turned back on, service the projector.
Goodluck..
Feb 25, 2008 | Hitachi CP-X250 Multimedia Projector
A flashing red light came on my acer projector pd120d but it did not stay on it displayed the power, temp and lamp
Projector bulbs generate alot of heat. Make sure the vents are not blocked or dirty. Check the fan to make sure it is operating properly. Hope this helps.
Jan 06, 2014 | Acer PD120D Multimedia Projector
Replaced bulb yesterday worked fine. Today light will not turn on. projector turns on both lights green for 10 seconds, then power goes red and status blinks green for about 5 seconds, then status light...
green green is power on, normal
then it tries to light the lamp, but it can't so the protection circuit comes activated.
you get red and green blinking
Then it goes to standby, red and off.
so something has happened to the lamp, or lamp ballast power supply.
Take the lamp out and check if all is OK with the 2 terminals in the connector, and the leads to the lamp are intact.
Failing that, I would suspect the ballast lamp power unit
Mar 25, 2011 | Mitsubishi HC1600 Projector
My projector's power light is red, but when I click power it won't turn to green (on)
The likeliest problem here may be a burned out or failed projector bulb. Most projectors will fail to power up at all when if the bulb is out. The HD20 user manual does not specify a red light as an error indication option however, generally amber.
User manual .pdf is located here (takes a bit to download for it's size), Projector Status Indicator instructions are located on page 40.
Here on the product page itself, an email to Optima support may be warranted given the red instead of amber error light.
If you had any messages recently indicating your bulb life was nearing it's end, again, this would be my first guess. Certain models of projectors do have a tendency of blowing through bulbs even before any warning message comes up. I had an experience with a certain brand/model that for the last 3 replacements has given only about 1/4 of the stated bulb life, so unfortunately it does happen.
Mar 05, 2011 | Optoma HD20 DLP Projector
Dear Support, We have HITACHI LCD CP-RX80 projector it's power and Lamp light blow red colour
Hi
sounds like the bulb has failed.
Recheck the connections of the bulb in its holder but failing that you will need to buy a new bulb.
Please dont forget to vote this answer was helpful.
Many thanks
Mar 01, 2011 | Hitachi CPRX80 LCD Projector Projector
Power light red ,internet light red no other
Most of the time a red internet light means that the box can't find the internet / can't find it ISP / can't get on the DSL what ever.
Might be the modem, might be the power adapter.
Nov 25, 2009 | NetGear DG834 Router
Red light blinking in nec lt 260
how many times? that will tell you what's wrong:
1x- lamp cover (close lamp cover)
2x- temperature problem (too hot. clean out and cool down)
3x- power problem (check power)
4x- fan problem (one or more fans not running)
6x- lamp fails to light (lamp or ballast problem)
Sep 02, 2009 | NEC LT 260 Multimedia Projector
Acer XD1150 DLP Projector Logo
80 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
