Question about Canon MX472 Wireless Inkjet Printer
Trying to print from my PC. Error message reads printer is offline. How do I fix this?
  • 13 Answers
SOURCE: Printer offline
Go into control panel/ printers and faxes and see if you have more than one copy of the printer in there. (it may have installed more than once) make the last copy of the 780 the default printer then it should be ok.
Posted on Oct 02, 2007
SOURCE: canon pixmaip3000 states printer offline & does not print, flishing power lights green & orange
I have canon PIXMA ip3000. After power cut at night printer doen not print. I re installed the drivers but no result. When try to print message appears printer is offline. POwer button is flashing shorthly green after orange lights. Error code 5100.
Please advice what can I do urgently.
Posted on Mar 12, 2008
IB4G2008
  • 3587 Answers
SOURCE: printer offline
go through control panel, printers, and select your printer..right click on it..bring it back online..
Posted on May 10, 2008
SOURCE: offline problem...won't print
Go to start>settings>control panel>administrative tools>services.
Scroll down the list to "print spooler." Right click on this and choose the "restart" option.
This should fix the problem and print any stuck print jobs.
Posted on Feb 07, 2009
aicaxz
  • 511 Answers
SOURCE: i was trying to print using a PIXMA iP1300 but it
Printer offline : make online in printer properties.Printer offline when start to print : head problem. Replace head.
Posted on Jun 12, 2009
HOW TO FIX...PRINTER IS OFFLINE BUT IT IS ON...WE ARE UNABLE TO PRINT.
If you are getting a status message as the printer is offline on your pc,and afterward you can't ready to print the reports.
Steps to Resolve the Printer Offline Issue:
Step 1:
At first, you need to check your network through the HP Scan Doctor which encourages you to discover and fix the printing issues.
Steps To Run the HP Scan Doctor
    •Open the HP Scan Doctor tool by double tapping the symbol.
    •Start- - >Select your printer- - > Fix Printing
    •Then the list of issues displayed on the screen as result.
    •If the tool shows the white checkmarks at that point there is no issue.
    •If the tool shows the white wrench then the issues are found and repaired
    •If the tool shows the yellow shout point then the issues are found however that can't be solved or skipped.
    •If the device shows the red stamp then you have to take after the on-screen guidelines to determine the issues.
    Step 2:
      Set Your Printer as Default Printer
      •Search your gadget on your PC and select your printer and uncheck the Pause Printing and Use Printer Offline
    •If you can capable print implies your printer is online.
    Officejet 4650 keeps going offline then proceeds with following step Step 3:
    Check Whether You Connect With Correct Port
      •Go to printer- - > Printer Properties - >Port
      •For USB association utilize USB or DOT4
      •For Network Connection use WSD, organize, Standard TCP/IP Port Step 4:
      •Update the printer firmware which may resolve your issues
      Step 5:
      •Manually connect the wired or wireless connection
      Step 6:
        •For network connection just you have to add the second printer to your Windows.
        •Select your printer - > Properties - >Add Port - > Standard TCP/IP Port - > Next port
        •Now you can ready to print implies stop the troubleshooting. Still get the same issue mean you need to connect the printer customer support via +1-800-836-3987
Jan 08, 2016 | Office Equipment & Supplies
I can't get my printer to work
You need to elaborate the issue.
What message is it giving you when you are trying to print
Is it a wired printer or wireless
when was the last time you were able to print
is it giving you any error message while printing?
Is it showing printer online or offline
Feb 05, 2011 | Epson Office Equipment & Supplies
My HP Officejet 6210 All-in-One printer goes offline whenever I don't use it for about 15-20 minutes, and when I put it back online, nothing happens. Looking at the printer from the control panel, I see...
HP Printers have common behavior of going into sleep mode if not used for a while. If this happens every-time the printer goes to sleep mode and you find printing issue, try this simple step below
Disconnect the power cable from back of printer
While holding the # and 3 button, connect the power cord to printer.
*Note this is partial reset and doing so you may loose fax logs and other fax related setting you have setup on printer.
Click the link below to know how to resolve the print job stuck in queue issue.
Link
Oct 23, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Lexmark1200 series printer not getting the message to print, does not say there is an error
Check that it is set to be the default printer. then check the aplication you are trying to print from that it has not set the printer to be offline. Sometimes IE or firefox ( I cant remember which) will say to print offline for some stupid reason.
Mar 09, 2010 | Lexmark X1270 All-In-One InkJet Printer
Trying to print 'offline'. Computer recognises it is offline but will not print. Error message says 'Printer is offline' which is as it should be. Printer is HP photosmart C4580.
So, if you want to print, the printer must be online. Offline method doesn't work to print. When the computer sayst that the printer is offline, it means ypur printer is turned off or you don't connected the printer to PC.
As in conclusion, if you want to print set the printer online.
Oct 05, 2009 | HP Photosmart C4580 All-in-One InkJet...
I was trying to print using a PIXMA iP1300 but it doesn't allow printing withe a message box appearing "printer is offline".can you help me please
Jun 12, 2009 | Canon PIXMA iP1300 Printer
False "printer is offline" message
Try to cheeck the port from ur printer to ur cp is been connected.
May 19, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon pixmaip3000 states printer offline & does not print, flishing power lights green & orange
Mar 10, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Canon MX472 Wireless Inkjet Printer Logo
old marine
old marine
