How to connect the Speaker - Audio Players & Recorders
    Top Expert:
  • 10,875 Answers
Main and common on top is front main and common on bottom are rear speakers
Posted on Apr 16, 2015
My panasonic says f61 when i switch it on wat do i do
An F61 error occurs on a Panasonic home theater system when the speaker cable wire connections are wrong. This situation is likely to happen if you just purchased your unit or moved the system and try to reconnect the speakers again. Polarity is key in a successful setup. The positive and negative ends of the cable wires must match the input of the main unit. Retrace your speaker wire connections to clear error F61.
Step 1 Attach the speaker labels to the speaker wires for easier identification, if they're not already labeled. At minimum, labels for front left (L), front right (R) and center speakers should be included in the packaging contents that came with your system.
Step 2 Verify that the white ends of each speaker cable are connected to the corresponding "+" positive inputs for each speaker.
Step 3 Verify that the blue ends of each speaker cable are connected to the corresponding "-" negative inputs for each speaker.
Step 4 Push the plastic ends of the speaker wires on each speaker to verify that each is locked into place.
Step 5 Connect the remaining end of the "Front (L)" speaker wire to the white terminal/connector on the main unit.
Step 6 Connect the remaining end of the "Front (R)" speaker wire to the red terminal/connector on the main unit.
Step 7 Connect the remaining end of the "Center" speaker wire to the green terminal/connector on the main unit.
Step 8 Connect the remaining end of the "Subwoofer" wire to the purple terminal/connector on the main unit.
Step 9 Connect the remaining ends of the "Surround (R)" and "Surround (L)" speakers to the wireless system.
Sep 11, 2016 | Panasonic Audio Players & Recorders
10 years and first problem to repair. When you turn on and select DVD or any other selection a very loud cracking noise comes through right speaker only. So loud (with volume tuned off too) that I fear...
I think your receiver is damaged.
Try this.
Mark the speaker wires on the back of the receiver. label the speaker connected to the left channel "Left" and the speaker connected the the right channel "Right"
Also pay attention to the polarity (positive an negative) making some type of marking on your speaker wire so you can reconnect them correctly.
Disconnect both left and right speakers.
Connect the speaker wire that is labeled "Right" to the receiver's left speaker connections only then turn your receiver on.
IF the loud noise comes back, this speaker is damaged. I am guessing that the speaker is fine.
Now connect the speaker that was labeled "Left" to the receiver's right speaker connections and turn the receiver on.
IF the loud noise comes back like it did before but now playing through the "good" speaker there is a problem with your receiver.
If so, your receiver is 10 years old. Isn't it time for an upgrade? Try ebay for good used equipment deals.
May 01, 2014 | Onkyo TX-DS787 Receiver
To connect speaker wires to unit there are blue wires and black wires. where do I attach them to the unit
hi,
connecting right speaker.
1.connet the speaker cord with the plug to the speaker high freq right (R) terminal
2. connect the speaker cord with white strip to the speaker low freq right (L) + terminal and its black cord to the -- terminal
do the same for connecting the left speaker to the speaker high freq left (L) and speaker low freq left (L) terminals
ok
Jan 05, 2011 | Aiwa Z-L700 Shelf System
How it can be connected to a stereo amp
hi,
if ur amplifier have a pre out, then u can connect that to ur L/R input of ur sub woofer.
if not the only way is, connect ur amplifiers speaker output to sub woofers speaker input and then connect ur speaker to sub woofer speaker output terminal. remember don't inter change positive and negative wires.
if ur amplifier have speaker A,B connection then it is very easy. connect the speaker A to ur left and right speaker. then connect speaker B to ur sub woofer's left and right speaker input. be sure to make that speaker A and B switch is in on position. the power on both and check it. ( use good quality speaker cable to connect the sub woofer)
your sub woofer is designed to work , both at low level and high level input.
ok
Dec 17, 2010 | Yamaha YST-SW215 Subwoofer
I been having a problem with my JBL TLX CSS-SUB1, I don't have the manual. Connecting speaker wires from the JBL TLX CSS-SUB1 to the a Digital Audio/Video Control Center ( it's a reciever) I confused,...
The connection on the receiver would be the sub woofer out. Not a sub woofer out LFE, a sub woofer out with speaker wire connection. From there you plug it in to the top section of the available terminals on the sub you are referring to (speaker level input). One in positive and the other in negative matching what you did on the receiver with correct ends. The speaker connections underneath the top connections is for additional speakers like surrounds to be able to be connected directly to the sub woofer speaker level out for sound. This of course would be for an older receiver connection. I do not think it is possible to convert this connection to an LFE and have it work properly. If the receiver does not have sub woofer speaker connection and only a RCA out then you can try to connect both rear speaker connections from the receiver to the speaker level inputs on the sub and then connect your rear speakers to the speaker level output on the sub to power them. This is an active sub woofer but for some reason they made it connect as if it was passive. I am not sure if this sub is designed for really low frequencies required for movie or if it is better for music.
Nov 01, 2010 | Audio Players & Recorders
How to connect small case mounted system warning speaker
Either ground (probably the one next to the "speaker) and the Speaker. ignore the other two. Ground to neg and Speaker to Pos.
Mar 14, 2010 | ASUS M4A785TD-V EVO Motherboard
Changing the omes of a 4 10'' bass cabinet
i guess ur talking about four nos of  4ohms 10" speakers. two speakers of four ohms connected in series gives 8 ohms, but if u use parallel connection u will get half of individual ohms i.e 2 ohms. so connect two speakers in series and another two speakers in series. parallel the two serial speakers and voila... u get a 4ohms speaker with double the wattage.
parallel connection - connect +ve to +ve and -ve to -ve.
series connection - connect -ve of one speaker to +ve of another speaker so that u have +ve input to one speaker and ground(-ve) on the second speaker.
So, two separate series speaker then parallel the two series speakers.
Mar 12, 2010 | Audio Players & Recorders
One of my speakers got disconnected and I don't know where to plug it in.
Typically, the LEFT speaker connects only to the RIGHT speaker.
The RIGHT speaker connects to the LEFT speaker.
The RIGHT speaker connects to the AC power-supply.
The RIGHT speaker connects to the "green" port (not the nearby "blue" nor "pink" connectors) on the "back" of your computer.
Check the connections.
Oct 29, 2009 | Dell Audio Players & Recorders
I have had a set of Polk Audio SDA1 speakers that I had attached to an old but great Pioneer SPEC-1 pre-amp and SPEC-2 power amp. The old speakers had one connection for the right speaker positive and...
bi-wiring requires the removal of the copper jumpers between the hi and low speaker terminals. you can use two wire pairs twisted together at amp out connections and the four separate ends at each speaker, but the quality of sound will not be as good as buying quality bi-wire cables. But a pair of quality single set of wires at each speaker would be fine, but put jumpers back on and attach to the top terminals, they are designed that way. bi-wiring does allow the crossover to put out a little better sound. Hooking up four sets of wires to the a and b speaker terminals sounds bad. i have had alot of trouble with my rti10's and learned the hard way that it is best to pay more for wires with quality terminations.
Jun 21, 2009 | Polk Audio RTi A7 Main / Stereo Speaker
Center speaker no longer works
Wiggle the connection that the center one is plugged to. It starts static or playing then the internal connection is broke loose from the solder joint.
Plug another speaker to that connection. If it plays then the speaker is blown.
Feb 17, 2009 | Insignia IS-LCDTV32 32 in. Television
216 people viewed this question
 Grubhead
Grubhead
