Problem? * The signal from componenant input,RGB,@ 1080i + 720p,doesn't work at all when outputting at component output or HDMI. 100% failure.
Phillips DVDR3570H/75.Just want to record an HD analogue picture & sound using component input or pass it into the TV thru the DVDR if not recording.HDMI or Component leads out should work? They don't work at all processing the component input for outputting on component or HDMI outputs.Is this a hopless case?
    Top Expert:
  • 10,875 Answers
You cant record an hd picture and sound through component input rgb,for 1 you arent inputting hd,you are inputting analog,you cant up convert,
Posted on Apr 16, 2015
  • Francis Kosmalski
    Francis Kosmalski Apr 16, 2015
    Thanks Johnny. Good helpful answer. It just begs one big question in my mind. I do not understand why it is possible to output component picture + analogue from a satellite TV box; directly from the the output & into the TV component video & audio of the TV---> leading to a great 1080I or 720p displayed on the TV.? Another question related is: how come I can input a composite picture on another blue ray/DVD recorder: then record it upscaled to HD. thru the HDMI output into the TV.? I appreciate your feedback.
  •  johnny rebel
    johnny rebel Apr 16, 2015
    satellite formats are as close to hd as you can get,component input is not hd,you may be able to record up converted sattelite images,but,you cannot up convert analog to hd
I have an older 2004 or so philips hdtv projection tv with the built in tv stand. i want to connect my HD cable box but there are no hdmi ports. and i buy a wire with the VGA on one end and hdmi on the...
Get a component video cable (blue, green, red) and a separate RCA audio cable (white and red) if your cable box has a component video output and the TV has a component video input.
If your cable box doesn't have the component output, you will need a converter to go from the HDMI to component video. Something like this: http://www.hdtvsupply.com/hdmi-to-component.html . There are other converters available if your TV has some other inputs available.
A cable that has an HDMI M on one end and a VGA M on the other will not work. HDMI signals from the set top box are a digital signal. The VGA port on the TV is set to read an RGB analog signal. (Similarly a component to VGA cable would not work since the RGB and PbPrY are not compatible.)
I hope this helps.
Sep 02, 2011 | Philips 60PP9363 60" Rear Projection...
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Feb 28, 2011 | RCA Televison & Video
How do i get 1080i, my tv shows im only in 480i. i think i might have it hooked up incorrect. my other tv of another brand is much newer so all i did was connect the hdmi cable from the tv to the cable box...
Hello
Your TV will display all High Definition signals as 1080i True HDTV™ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
YPbPr(480i/480p/1080i)
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
InputDTV
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Ok.
Feb 05, 2011 | Mitsubishi WS-73909 73" Rear Projection...
I Have A Vizio 32LCD and my problem is i am trying to get the PS3 to play with the HDMI I have a HDMI cabel hooked up to the hdmi input on the back of the set and it is hooked up to to the HDMI input on...
1. Check the resolution supported by your TV.
2. Select (Display Settings) under (Settings) in the home menu.
3. Select [Video Output Settings].
4. Select the connector type on your TV.
D2: 480p / 480i
D1: 480i
5. Change video output settings.
6. Set the resolution.
7. Set the TV type.
8. Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
9. Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
4yr old Mitsubishi DL 52525, HDMI input vide problem
Are you sure its the TV and not the source? Are you sure its only the HDMI port on the TV? The only reason why you must HDMI is to get 1080p and your TV doesn't support 1080p. Its supports up to 1080i. Your TV has a native resolution of 720p which means it can accept a 720p image and not need to scale it, so the picture will look the best at 720p but will support 1080i. I would use component cables to connect your sources and set them to output 720p.
Mar 20, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi 55 in. 1080 series
If I remember correctly, this TV has a couple of constraints that will cramp your style:
1. It supports 480i, 480p and 1080i. NO 720P
2. It has component video inputs, but NO HDMI. (as you stated)
There is no easy solution here, because I've never found an upconverting DVD player that would upconvert anything past 480p using the analog component outputs...
So..
Perhaps you can find an Upconverting BLU-RAY disk player that may allow older DVDs to be upconverted to 1080i via the component outputs.
MOST Blu-Ray players allow 1080i output via the analog connections on Blu-Ray discs, so perhaps there is your solution.
Mar 09, 2009 | Mitsubishi WS-55311 55" Rear Projection...
TV Picture is green
is your RGB cables are the same output from your tv...are you connecting from where dvd cable box sattelite box, if you are connecting from a box exs output of cable box is what colour are you using? for your your output to your tv and what input are you using of your tv set.[input 1is it video input 1,] or comp? let me know...
Jan 10, 2009 | Televison & Video
Screen flicker when watching 1080i
Component video has a max resolution of 720p. in order to use 1080i or p you have to use hdmi or dvi connections. That is why you get the flicker.
Dec 08, 2007 | Onkyo TX-SR304 Receiver
This TV won't support 1080!
Low or poor signal from the cable company. Try another signal source such as a DVD play.
May 12, 2007 | Hyundai Q320 32 in. LCD Television
Televison & Video Logo
131 people viewed this question
Top Televison & Video Experts
Electro Med Services...
