Question about Microsoft Surface RT
Surface rt was useing when the screen just went black
Was online then screen went black it , can hear it chime when touch corners of screen . on screen key board will show up , but it dont do anything tried the power button and screen will be white
Why is my icraig tablet model# cmp801 not booting up after doing a system reset? The icraig screen comes on but then a black screen after that!
you can give it voice commands by pressing the mic top left corner I told mine to reset and it did it. let it charge up good then turn it on and look for the tiny microphone. say reset and let it do its thang
Dec 24, 2016 | Tablets & eReaders
My dragon touch 7 inch tablet doesnt start up. the screen goes directly to white and it wont go from there
There are a couple things that could cause that. Does it still have sound? If you can hear the sound continue, it is likely caused by either damage underneath the screen, moisture inside it, heat/sun damage, etc.
Jul 22, 2016 | TabletExpress Dragon Touch 7 Black Dual...
Screen is black but is powered on
try factory RESET but first save you info on memory card.
Jan 12, 2016 | Samsung Galaxy Tab 2 7in. WiFi Tablet, 8GB
I have a irulu 7"tablet that I was on ebay placing a bid & it just went black it's still on & can hear when a email goes thru but can't see anything black screen &am
You may have a screen saver running in background which you need to disable in general display settings.try holding the power button for at least ten seconds then try and restart the tablet after you have done that.
Jan 28, 2015 | Irulu 2014 7 inch Android Tablet PC, 4.2...
Why is my screen just black??
If screen was not phisicaly damaged, - "No Video"
could be bad on-board memory or GPU or both.
Jul 31, 2014 | Nextbook Premium 7 Capacitive Touch...
My granddaughters nextbook 8inch will not display anything the on the screen it is just blank
If it wont show anything then there may be a problem with the launcher( the program that loads all of your apps and widgets). If you cant get to the settings then consider having a tech professional look at it and dont touch anything if you have no clue what it does i've learned that the hard way.
Jun 29, 2014 | Nextbook Premium 8 Se Android
Unlock
The Lock symbol needs to moved to the right to the unlock symbol by your finger.
This will then load the desktop and activate the touch screen.
Support Troubleshooting Guide
Apr 18, 2014 | Kocaso M730W 1.2GHz 4GB 7 Capacitive...
Brand New Acer 5738PG6306 (touch screen) Notebook - BLANK SCREEN
If you can return it to the retailer, that would be my first option. Sounds like a bad backlight.
Feb 22, 2010 | Acer Aspire AS5738PG6306 (LXPK802046)...
Pen touch screen problem
Can you tell me if you can use the screen rotation on the left screen bezel and do you have all other pen capability, just checking to see if the drivers are right
Jan 04, 2008 | Compaq tc1100 Tablet PC
Microsoft Surface RT Logo
Top Microsoft Tablets & eReaders Experts
thetraveler
Level 1 Expert
Les Morrison
Les Morrison
Ruben Caraballo
Ruben Caraballo
Are you a Microsoft Tablet and eReader Expert? Answer questions, earn points and help others
