Question about Hyundai 2010 Accent
What could be the problem? Could it be the shock sensor?
The timing belt of my accent 2010 cut and bend 8 out of the 16 valves, after replacing the valves it does not shock for it to start
    Top Expert:
  • Hyundai Master
  • 10,875 Answers
Call a mechanic
Posted on Apr 16, 2015
Why any time my v belt cut i must replace some of my valve
It sounds like you are talking about the Valve timing belt, which is not a v belt but a toothed timing belt. The belt needs to be replaced according to the MFG maintenance schedule. Some engines, probably yours is called an interference engine, wich means that if the Valve timing is out of MFG specifications due to breakage of the Timing belt, the valves will be hit by the piston and bend the valves. If you are a DIYer, I strongly recommend you purchase a Repair manual from your auto parts store. or you can try filepeep.com if they have it, or manualslib.com. You can also borrow from your local library.
May 05, 2015 | Mitsubishi Colt Cars & Trucks
What is the cause of toyota corolla bend valve?
usually the timing belt or chain wears and causes the piston to bend the valves
May 13, 2014 | 2010 Toyota Corolla
I just wanted to know if this model has a timing belt or timing chain.
Timing belt on this vehicle. Replace at 120K miles. You may bend a valve if the belt breaks on you. Very expensive then.
Aug 30, 2011 | 2000 Hyundai Accent
TIMMING BELT
if the timing belt breaks it will bend the valves
Jun 24, 2010 | 2007 Hyundai Accent GS Hatchback
Timing belt broke on hyundai accent how do i replace it and the timing marks
1st you may want make sure that's not an interference engine. if it is then chances are the valves are bend in the head. changing the timing belt probably won't help then. If its not an interference head, then you would need a timing mark diagram which can be found online. be very careful that all marks are aligned. when finshed installing the timing belt, rotate engine by hand twice and re-align marks before putting the rest back together! hyundai should be able to tell u if the engine runs interference or not.
Mar 29, 2010 | Hyundai Motor 1995 Accent
After how many km must the timing belt be changed
The recommended replacement interval for timing belt on 2006-2010 Hyundai Accent 1.6L is 60,000 miles or 96,000 kilometers.
Feb 09, 2010 | 2006 Hyundai Accent
Timing belt snapped
hi from uk the cambelt timing marks for accent 1.3/1.5 petrol are as follows= the cam cog has a hole drilling between the outer toothed and the central securing bolt this hole at TDC number 1 cyl is at top central and lines up with a V cut in the cyl head at rear of cog ? the crank cog at TDC number 1 cyl is a pop mark on both the cog and on thefront face of engine quite noticable ! these line up and are at approx 12 -30 pm when viewed fit new belt from crankcog in anticlockwise ie crank then cam then tensioner HOWEVER! if you are considering just replacing belt and tensioner ? be warned this engine is an interferance engine that is to say if belt fails whilst driving there may/will most probably be damage to the valves (bent) due to contact with pistons so would advise caution and suggest compression test all cyls after fitting new belt and tensioner and before rebuild completely once valves have bent they will not contact pistons again but you will have serious missfire/s and probably back fire up inlet manifold coupled with failing to start if engine is high milage ? consider removal of cyl head and check? de coke and replace damaged or best all valves then engine will have improved performance and more milesin future hope this helps
Nov 28, 2009 | 2001 Hyundai Accent
Is it pretty easy to replace the timing belt on my 2007Accent?
Timing belt replacement is NOT easy and not for the average do it yourselfer. Installing the belt incorrectly can cause severe engine damage by bending the valves, breaking pistons etc. Take this one to a professional.
Oct 17, 2009 | 2007 Hyundai Accent GS Hatchback
My car is not firing right,
when your engine breaks a timing belt it bends one or more valves in the engine cylinder head, that is the problem, u have bent valves.
Apr 09, 2009 | 2000 Hyundai Accent
Hyundai 2010 Accent Logo
56 people viewed this question
Top Hyundai Audio Players & Recorders Experts
Lawrence Oravetz
Steven Mitchell
Steven Mitchell
Are you a Hyundai Audio Player and Recorder Expert? Answer questions, earn points and help others
