Question about Homedics Fb-200 Foot Massager, Hydro Therapy Spa
I just purchased a Homedics FB 200 Jet Spa Elite. It cut off after 2 mins of me plugging it in and wont turn back on.
It worked fine the last time I used it, now it will not make bubbles. What should I do?
Review- Deluxe Bubble Bliss Foot Spa by Hometics ...
? 5:14
https://www.youtube.com/watch?v=LUBHAmA0y3A
Apr 17, 2014 - Uploaded by Calla
I love this bubble spa, its great for anyone who is on their feet all day, Its ... my machine quit working for the bubbles ... My mom bought one yesterday, but it does not bubble. ... make them a little larger so you could submerge your whole foot in ... I'm curious if you've ever used essential oils during your foot ...
The Next Best Thing to a Jacuzzi - Epinions.com
www.epinions.com/.../HoMedics_Bubble_Spa...2/.../130896793220
Jan 29, 2016 | Homedics Fb-50 Bubble Bliss Deluxe Foot...
It just cut out after 5 mins use -why? How do I fix it? Its brand new!
take it back to where you bought it from.... maybe you still have the warranty?
Feb 11, 2015 | Homedics Fb-50 Bubble Bliss Deluxe Foot...
Any problems with a brand-new item, should always go back from where you purchased it.
How can I fix the heating element?
Here's this product instruction manual, it may help you:
http://www.homedics.com/media/documents/homedics/instructionbooks/FB-50_IB.pdf
You can also go to their website at: http://www.homedics.com/bubble-blisstm-deluxe-foot-spa.html and try to contact their support
Mar 01, 2013 | Homedics Fb-50 Bubble Bliss Deluxe Foot...
Why wont my chainsaw tick over, it revs up but not tick over. also, cannot start it after 2-3 mins of usage, why?
Check the air cleaner and muffler for plugging. Try turning the idle speed screw (not the L jet screw) CW one full turn. Does it now idle? If the chain keeps turning at idle, back off the speed screw until the chain stops after revving the engine. When the engine won't start, remove the spark plug and check for blue, snappy spark. If the plug insulator is black, try a new correct type plug. If sparks ok, then squirt some fuel mix into the plug hole, replace the plug and try to start. If you get a pop or two, then fuel delivery is a likely problem. If it again runs, the plug may have been the problem. Otherwise, check the fuel filter, fuel line, and carburetor for any loose fasteners. Finally, run the engine at full throttle--it should 4-stroke with no load, but immediately 2-stroke when cutting. Adjust the H jet needle to achieve this. hope this helps!
May 19, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
96 dr200 sittig up for 2 yrs. starving for fuel
Get some carb cleaner. Remove and clean the Nozzle, choke and main jet. Remove the pilot jet and air jet but count the number of turns to remove each one and put them back the same number of turns. Don't mess with the needle or clip or the pilot screw and plug at this time. Clean the carb thoroughly. Don't get carb cleaner on the diaphragm. If able, submerge the carb in cleaner overnight.
Let me know what happens by posting a comment.
Jun 27, 2009 | 2001 Suzuki DR 200 SE
Need parts for HoMedics BMAT-2 Bubble Spa
I'm missing the hose and now desperatly want to use Homedics BMat bubble Spa which is now currenlty not in stock. Can you sell the hose to me. 4189kv4r6yl._ss400_.jpg
Feb 25, 2009 | Home
I just bought Homedics SS-4500 Sound Spa Classic and there was no instruction manual in it. Is there one I can download? I don't know how to change the time that is preset or set the alarm? Thank you.
http://media.homedics.com/IBs/SS-4500_IB.pdf
Also note if projection does not work correctly, Ken posted an elegant solution: holding down hour and minute unplug and plug back in (still holding down hour and minute). Made mine work!
Dec 23, 2008 | Homedics Sound Spa Classic Clock Radio
Homedics Fb-200 Foot Massager, Hydro Therapy Spa Logo
48 people viewed this question
Top Homedics Health & Beauty Experts
Ankit Chandel
Ankit Chandel
Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
