Question about Building Materials
I have turned to unlock position but hook will not open.
  • 2,131 Answers
More info. Don't understand the question. What make and model. Post a photo of issue if u can
Posted on Apr 17, 2015
Oven latch will not open
Sometimes the latch arm is bent causing the latch release not to clear the hook on the door. If the arm goes under the front it is probably bent. Carefully pull the arm back toward the locked position and try to bend it back a small amount and see if the door will open after moving the arm back to the open position. If that fails sometimes you can insert a bent coat hanger between the door and the latch hook and move the latch enough to unlock the door. I hope this helps
Nov 28, 2013 | Ovens
2007 toyota matrix hatchback door won't reset
Read manual. It should direct you to location where you can manualy unlock hatch. Look for little trap door. It should be located very near lock.
Hope this would help
Jan 10, 2013 | Cars & Trucks
How to program my new control remote to my Honda passport 2000
Try this please!
'98 - '02 Isuzu Rodeo and Trooper and Honda Passport(with factory keyless entry) Instructions for programming. 1. Get in car and make sure all doors are unlocked. 2. Open driver's door and leave open. 3. Put key in ignition. 4. Turn key to 'on position' (dash lights on, but do not start) and back to 'off position' 3 times in 5 seconds or less. (you must turn the key very fast) 5. Close and open driver's door 2 times in 5 seconds or less. 6. Turn key to 'on position' and back to 'off position' 5 times in 5 seconds or less. (turn key very fast) 7. Close and open driver's door the doors should lock and unlock twice after this happens push the lock or unlock button on the remote, doors will lock and unlock. Push the lock or unlock button a second time and doors will lock and unlock again. You are finished! The above sequence erases all previous codes and adds the new code as #1. If you are adding a second remote, you should follow the same sequence with the exception of step 6; instead of turning the key to the 'on position' and back to the 'off position' 5 times in 5 seconds or less, do it 3 times in 5 seconds or less and then continue to step 7. ***Remember to turn the key to the on and off position very fast. This works! Follow directions EXACTLY. I had to try 3-4 times before getting it to work. I failed to go exactly by the instructions the first few times.
Jan 03, 2013 | Cars & Trucks
Unlock scooter seat
Try some lock cleaner\ lubricant, use liberally, press down gently on the seat locking latch. If that doesn't work try shocking the mechanism with my favorite tool, a rubber mallet. If the key turns that part of the mechanism works. Put the key in to the release position. Go to where the latch is, use a bright light, see if the latch is engaged, Usually this kind of lock uses a hook latch. The hook is literally apart of the key barrel so if the barrel moves the latch hast to be moving too. Check the chair itself that its not stuck. WARNING Lubricate with pure silicon spray only it wont stain your chair. Lub all rotating joints and see if you can move it.
Hope this helps
Jun 21, 2012 | Health & Beauty
Unlock seat yamahy vity 2009
This is the answer as per the owners manual. Place the scooter on the centre stand.Insert the key into the main switch, and then turn it anticlockwise to the first OPEN position. If the main switch is in the LOCK position, turn the key anticlockwise to the second OPEN position. Do not push inward when turning the key from OFF to OPEN or from LOCK to OPEN. Lift the seat up from the back end. As this system is electronic, obviously you have to have the battery connected and charged up, otherwise you cannot open it without specialised knowledge. Hope this helps.
Dec 07, 2011 | 2009 Yamaha Vity
My monitor went into osd lockdown when i was trying to hook up to my tv how do I unlock it
A)Plug in the monitor, and power it up. Hold down the power button until you get a message saying “OSD Unlocked”. If the problem persists after OSD is unlocked, unplug the monitor from the wall, wait 20 seconds, and try again.
B)Turn on the monitor, and hold down the Menu button for 10-20 seconds. This should unlock the OSD.
C)Turn off your monitor. Press the Menu button, and turn on the monitor. Wait 10-20 seconds. This should unlock the OSD.
D)The Menu button could be stuck in a pressed down position. To get it “unstuck,” you’ll usually need to open up the monitor. This could be tricky unless you know what you’re doing. Unfortunately there are too many models of monitor for me to provide detailed instructions. If you have a warranty this is where you want to contact the manufacturer.
Mar 08, 2010 | Computers & Internet
Dome light won't come on when door is opened (switch in center or 2 position). Dome light does work when switch pushed to position 1.
Center is the off position. Position 2 is "on when doors are open", Position 1 is "on all the time". The switch (relay) that turns it on when the door opens is likely bad. Play with the button ont he door frame to see if this problem is there.
Also, check if the light comes on when you unlock the car when the swich is in position 1. If light does come on when unlocking, you have a bad switch on the door frame (turns light on when you open the door when the doors were already unlocked). If you don't get light, the switch by the dome light might be bad.
Good luck.
Nov 20, 2009 | 2004 Nissan Titan
1994 BMW 740il - Doors will not unlock, battery is dead
try this, put the key in the drivers side door then turn the key to open position as th same time lift up the door handle . if this does not work then jack up the car , and with jumper cables hooked them to the starter--red to solinod of starter and the ground to any good ground.then hook the other end to another vehicle.keep in mind all the safety precautions!Then try the door with the key in normal operation.Your battwery is dead.!
Aug 19, 2009 | 1994 BMW 7 Series
Oven
The lock spring unhook back cover must open / gas must be shut down. before open back cover., spring might cut spring hook corroded possibility door door lock malfunction.
Jan 03, 2008 | Hotpoint RGB745 Gas Kitchen Range
Inspiron 1100 monitor
Any of the system LEDs come on when you turn it on? Can you hear the hard drive spin up? What was the original problem that lead you to clean the laptop fan? Please post the answers and any other pertinent information and we?ll start up.
Mar 07, 2007 | Dell Inspiron 1100 Notebook
Building Materials Logo
50 people viewed this question
Top Building Materials Experts
hpgwva
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
