Question about Sewing Machines
Feed dogs below plate. Repair? Need manual as well. Thanks.
Everything else works
  • Karyn Davidson
    Karyn Davidson Apr 16, 2015
    Brother VX-1300 sewing machine
    Top Expert:
  • Sewing Machines Master
  • 10,875 Answers
Make model????????????????????????????
Posted on Apr 16, 2015
Testimonial: "To receive a reply so quickly, is fabulous!"
  •  johnny rebel
    johnny rebel Apr 16, 2015
    go here and click on download to get your manual,http://www.manualslib.com/manual/355780/...
  •  johnny rebel
    and here for the operation manual,they are different from each other,i dont have time to look for the dog problem but it should be adressed in these 2 manuals,johnnyhttp://www.manualslib.com/manual/500855/...
Feeddog singer stylist 776 how would the feeddog gt lowered
Consult the owner's manual. There should be instructions for how to darn with your machine. It would require either the feature that lowers/raises the feed dogs or a cover plate that attaches over the feed dogs.
If your machine came with the cover plate accessory, and the feed dogs are not rising to feed the fabric, then I suspect the machine has not been cleaned & oiled in quite some time and perhaps the feed dogs have seized. When you run the machine (remove the needle and presser foot), watch if the feed dogs actually drop below the needle plate, move toward the front of the machine, then rise above the needle plate and move toward the back of the machine. This is a repetitive motion that actually pulls the fabric through the machine. If this is not happening with your machine, it needs service.
Singer Stylist 776 Manual Page 8
Oct 30, 2016 | Singer Sewing Machines
Material won't move? How to adjust feed dog if that is the problem
Is the feed dog raised into sewing position and not dropped as for darning? Feed dogs need to be in the raised position in order to pull the fabric through the machine.
If the stitch length is set too short, it will cause the fabric to barely move thereby causing the machine to stitch in one place.
Raise your presser foot and gently rotate the handwheel and watch the feed dogs. Do they rise when coming to the front of the machine, move toward the back of the machine, drop down below the needle plate, and move forward to the front of the machine again? If so, the feed dogs are working properly.
If the feed dogs never rise, they are in the dropped position for darning or free motion quilting when you would move the fabric manually.
If, on the other hand, the feed dogs do not move at all, then they are seized and you should probably get your machine serviced.
Apr 09, 2016 | Sewing Machines
My feed dogs will not pull my material through.
Check to be sure you have not inadvertently dropped the feed dogs on your machine. Dropped feed dogs are used for 'darning' or 'free motion quilting.' Below is info from Troubleshooting Manual:
Fabric does not feed through the machine
The feed dogs are lowered. Use the feed dog position switch to raise the feed dogs. 81
The stitches are too close together. Lengthen the stitch length. 42
The wrong presser foot was used. Attach the correct presser foot. 179
The needle is bent or blunt. Replace the needle with a new one. 34
The thread is tangled. Use scissors, etc., to cut the tangled thread and remove it from the race, etc.
Apr 11, 2015 | Baby Lock Esante
How can i do free motikn quilting with my machine
On page 35 of your manual (see link below), there are instructions for darning. It looks like your machine needs to have the darning plate installed over the feed dogs before you can perform darning or free motion quilting. If you do not have the darning plate, then you will need to get one.
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=8&ved=0CFAQFjAH&url=http%3A%2F%2Fecx.images-amazon.com%2Fimages%2FI%2FB1dzfyluFLS.pdf&ei=jkMpVYmGFsWzoQTryICoCA&usg=AFQjCNEBTgKmXv2EyHiiw-px33CFogPHXA&bvm=bv.90491159,d.cGU
Mar 14, 2015 | Brother LS2125 SEWING MACHINE. D/B
Why is the needle not moving or feeding fabric but motor is running
the needle only sews,, it's the feed dogs in the needle plate area that feed the fabric thru the machine, if the feed dogs are in the up position then the machine will sew, if the machine is not sewing then the feed dogs need to be checked to see if the feed dog lever is up or down, look in the manual to see where the lever is and check it, if the lever up the then feed dogs will need to be checked to see if there is something's wrong with them at a sewing machine repair shop.
Jul 31, 2014 | Janome Sewing Machines
Feet not feeding and thread bunching up
the presser foot or what ever foot your sewing with does not feed the
fabric,, the feed dogs in the needle plate are what moves the fabric
to be sewed, the feet only hold the fabric against feed dog so the
machine can use the needle to sew the fabric.
if the fabric is not moving then the feed dogs have to be checked
can you see the feed dogs in the needle plate area are the up or
down?
do you have a manual for the machine?
a manual help to know where the feed dog lever is, I'm sending
you a link for a manual for the machine, so you can look for the feed
dog lever, if the feed dogs are up then there is something wrong
with the feed dogs & they need to be checked.
but if the feed dogs are down then look in the manual & see where
the feed dog lever is & put it in the up position & see if that brings
the feed dogs up to the sewing position, if the feed dogs do not
come up then the feed dogs need to be checked.
http://www.sewingpartsonline.com/instruction-manual-necchi-6015.aspx
Oct 16, 2012 | Necchi 6015 Mechanical Sewing Machine
Does 514 pressure foot move?
what is the name of the machine?
do you want a manual?
the feed dogs are what move the fabric thru the machine, the presser foot only hold the fabric against the feed dogs so the feed dogs can move the fabric
the feed dogs in the needle plate area should be up
May 28, 2012 | Sewing Machines
I own the singer advance 7442 and want to lower the feed dogs in order to use a quilting foot to machine quilt.However I don't have my manual and I need to know how to lower my feed dogs.Can you help me...
The 7442 does not have feed dogs which can be dropped. You need to use the "Darning Plate" which came with the accessories.
http://www.singerco.com/accessories/manuals.html
Nov 01, 2010 | Singer 7442 Mechanical Sewing Machine
I need help in adjusting the feed dogs, they messed up when I adjusted the timing for the needle and bobbin.
When the sewing machine is properly timed, all the parts work together in a seamless flow of coordination. The needle moves from it highest point down toward the needle plate. The feed dogs reach the farthest point toward the back of the sewing machine. The feed dogs drop under the needle plate. This is just before the needle point reaches the needle plate. The needle continues to move down dragging the upper thread under the needle plate. It proceeds toward its lowest point.
The needle begins its rise back up. A loop of thread forms along the back of the needle. A special cut out on the back of the needle to accommodate this loop is called the scarf. The sewing machine hook slides behind the needle. The point of the hook slides into the thread loop and pulls the thread around the bobbin. The bobbin thread and upper thread wrap together. The needle and hook proceed through their actions under the needle plate. The feed dogs move under the needle plate from back to front.
The needle proceeds to rise again up out of the bobbin area exiting the needle plate. At the same time the feed dogs rise up out from under the needle plate. They begin to move from front to back as the needle continues to rise.
The thread from the bobbin flows through a bobbin tensioner providing resistance to the thread as it is drawn up by the upper thread knot. The upper thread is also under tension. This comes from the upper tension, thread guides, tension spring, and sewing machine take up lever.
The thread from top and bobbin grow increasingly tighter until they form a locked stitch in the middle of the fabric. This process is repeated for every stitch.
How do you adjust sewing machine timing?
The needle, hook, and feed dogs must move in harmony. If they fail to do so, the machine will not perform as expected. When the hook is just slightly out of time with the needle, you will notice skipped stitches. This may begin on only one side of the zig zag stitch or intermittently. If the timing is just a bit more out of sync, stitch formation will become impossible.
If the feed dog timing is out of sync, the fabric will not move through the machine as expected. Threads may bunch up or the fabric may just not move.
As you can see, timing is everything.
click on this link directly
http://www.fixsewingmachines.com/How-to-Adjust-Sewing-Machine-Timing.html
This will help. Thanks please keepupdated.please do rate the solution positively .thank you for using fixya
Jan 29, 2010 | Sewing Machines
Sewing Machines Logo
29 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
