Question about Kitchen Appliances - Others
It do not get hot - Kitchen Appliances - Others
    Top Expert:
  • 10,875 Answers
The heater is no good,buy a new fryer
Posted on Apr 16, 2015
I LIKE TO BUY SOME HOT HIGHLANDER HERBAL ROOTS WINE IT IS A PRODUCT OF POLAND ANY IDEA WHERE I CAN BUY IT
NV Hot Highlander Herb Roots Poland Red search ... - Wine Searcher
www.wine-searcher.com/find/hot+highlander+herb+roots+poland+red/0
Showing 'Hot Highlander Herb Roots Poland Red' search results. Compare prices for this wine, at 17000+ online wine stores.
NV Search Hot Highlander Herb Roots Poland Red wines
www.wine-searcher.com/find/hot+highlander+herb+roots+poland+red/0/-/-/x
Search results for 'Hot Highlander Herb Roots Poland Red'. Wine prices & availability at all online stores.
Hot Highlander `Herbal Roots` - GraysWine
www.grayswine.com.au/.../highlander.../wine/hot-highlander-herbal-roots-wine-6-x-1... Hot Highlander `Herbal Roots` Wine (6 x 1L), Poland. ... Produced from a traditional recipe, Hot Highlander - Herbal Roots contains extracts from herbs, roots ...
Hot Highlander `Herbal Roots` Wine - GraysOnline
www.graysonline.com > Auction Product : highlander-118025470 Hot Highlander `Herbal Roots` Wine (6 x 1L), Poland. Description: Hot Highlander has been a well - known and well - loved beverage for centuries, due to its ... HOT HIGHLANDER HERBAL ROOTS WINE, POLAND Google Search
Jun 25, 2017 | Furniture
Tip
A New Hot tub cover will lower your Hot Tub Costs
A New hot tub cover will help you run your hot tub at a more efficient level. Lower your energy costs as the new hot tub cover will insulate better. The question is when do you need a new hot tub cover.
The best ways to know if you need a new spa cover or hot tub cover are the following:
  1. The hot tub cover weighs over 100 pounds.
  2. You need more then one person to remove the hot tub cover.
  3. The hot tub cover is ripped and torn past repair.
  4. Faded cracked and just aesthetically ugly.
  5. The seam in the middle is ripped past repair.
Can you fix your hot tub cover? Some things you can fix like rips and tears. You can take the cover to a local seamstress to repair. You can not fix a saturated hot tub cover, it needs to be replaced at that point. New Hot Tub Cover for the Fall and Winter
on Sep 05, 2015 | Home
Hot water not running to machine just the cold water
Try switching the hot and cold hoses. See if the hot water works. Sometimes the gate gets frozen, other times the hot is so slow it seems to not be working, similar to when it takes a long time to get hot water in the sink.
Apr 19, 2017 | Washing Machines
Morgan hot tub
I found the drain snakes very helpful to unclog a drain even it is a bathtub. Dran snake found both hand cranked and power cranked. for home use, the hand crank is enough but for professional plumbing power cranked drank snake is best.
Learn more from here -
https://www.toolsfreak.com/best-drain-snake/
Jun 30, 2014 | Pool & Spa
HOT and COLD blending
my last two washing machines, totally different brands and types, did the exact same thing. It must be a new way of setting them up, I don't understand either. I can't get straight hot water. My new one does seem hotter than the old one I had which was very distinctly hot then cold then hot then cold even on hot hot water.
Nov 09, 2013 | Maytag Washing Machines
Do you have a connection guide for each screw (N, COMMON, A1...) ?
Screw terminals are color-coded on each switch. They vary by device.
Green screw always ground
Silver screw always neutral > except some 4 ways switches
Brass screw is hot > can be hot from breaker or hot wire going to load > or in 3-way switch can be hot traveler wires from other 3-way switch
Dark screw is hot > can be hot from breaker > or in 3-way switch is hot going to load
Single-pole switch:
2 brass screws > hot and load wires connect to either screw
3-way switch:
2 brass screws connect to travelers
dark screw goes to hot from breaker and hot to load
Switch-plug combo and pilot light switches:
silver screw to neutral, brass screw goes to load
Double switch:
brass screws each go to load
Receptacles:
brass screw goes to hot from breaker and to hot going to next receptacle
silver screw goes to neutral and to neutral going to next receptacle.
Dec 08, 2010 | Electrical Supplies
Cold water runs hot even when hot water valve is turned off.
check to see if the cold tap is connected to the cold valve on the machine and the hot tap to the hot valve. on the machine it will have cold or c for the cold valve and hot or h for the hot valve. please reply if you need further help.
May 19, 2010 | Washing Machines
Hot water not really hot
I have never heard of this before, and have always piped dishwashers off the hot water line. Not to say it could not be done the other way, I would refer to the instructions that came with the dishwasher, and if they say to connect to the hot water line, to have the technician come back and fix it. If it says to connect to cold water line, then manufacturers know best.....Hope this helps
Dec 29, 2008 | GE WPRB9220D Top Load Washer
KENMORE HE5T NO Hot Water
Check the hot water line going to washer have hot water?If donot have trace the line from Hot water tank going to washer if yuo rfound it open the valve. hold the pipe you can feel the hotness.attache to machine.
Dec 27, 2007 | Kenmore Elite 45986 Front Load Washer
Kitchen Appliances - Others Logo
155 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
