Question about Kyocera FS-6025MFP Laser Multifunction Printer - Monochrome - Plain Pa
When I set up the brand new machine then the system error code appeared F242?
I try to execute out that system error F242 but the problem is still not solved .Any solution..please advice.
  • 523 Answers
Updating machine firmware will take care of this error.
Posted on Apr 25, 2015
Ricoh 2018D error code sc 552
Do following steps
1. Yellow cancel
2. 107
3. Hold down red clear/cancel
Machine will beep.
Select 1 - copier sp
Type 5# 810# (fuser sc reset)
Select execute and restart the machine.
If code re-appears you have a faulty fuser lamp or thermostat.
If machine works for a while or at least tries to warm up, you have a faulty thermistor.
Feb 06, 2018 | Ricoh Office Equipment & Supplies
Reset code for sc546 on ricoh copier
1. Yellow cancel
2. 107 (on blue keypad)
3. Red cancel (press and hold down until machine beeps)
4. Menu will appear on screen - select System/Copy SP
5. 7807# (on blue keypad)
6. Select execute on screen
7. Select exit on screen
8. Switch machine off and on again.
If the error re-appears then you have a failing part and will need to replace it. Common parts to replace are Hot Roller, Thermister or Thermostat.
Jul 15, 2016 | Ricoh Office Equipment & Supplies
E000602-0004
E602-0004
An error occurs by checking the Control Table of "Image storage area" when the machine is "ON"
I would try the following, under service mode goto:
Copier->Function->System
Set Chk-Type to 1
Execute HD-Clear
Set Chk-Type to 2
Execute HD-Clear
Power the copier off then on again.
Also make sure you are running system software v31.04 or later.
Jan 20, 2015 | Canon imageRUNNER 6000 Copier
Date and time error in new laptop
Hello Bhavathrini, have you tried changing it manually? What operating system are you using, exactly?
If you say that the laptop keeps showing errors and does not execute any tasks, your operating system could be a victim of viruses. You should try and update your antivirus solution, or get one if you don't already have one.
Best of luck!
Nov 30, 2013 | Lenovo ThinkPad R51e Notebook
I have a problem Taskalfa 250ci eror code c0640 I think at Hdd problem. But I don't know how to hdd format
Maintenance
item No.
U021
Memory initializing
Description
Initializes all settings, except those pertinent to the type of machine, namely each counter, service call history
and mode setting. Also initializes backup RAM according to region specification selected in maintenance item
U252 Setting the destination.
Refer to *1 of the maintenance mode item list about the item initialized.
Purpose
To return the machine settings to their factory default.
Method
1. Press the start key.
2. Press [EXECUTE] on the touch panel.
3. Press the start key. All data other than that for adjustments due to variations between machines is initial-
ized based on the destination setting.
4. Turn the main power switch off and on.
For errors occurred, turn main power switch off then on, and execute initialization.
Error codes
U024
HDD formatting
Description
Initializes the hard disk.
In addition, the following settings are also initialized by initializing the hard disk.
System menu (user login administration, job accounting, address book, one-touch keys and document box
etc.), shortcuts and panel programs
Purpose
To initialize the hard disk when replacing the hard disk after shipping.
Method
3. Press the start key to initialize the hard disk.
Description
Codes Description
01 Configuration initialization error
02 Counter initialization error
20 Engine initialization error
40 Scanner initialization error
2JZ/2JX/2JV/2H7-5
1-3-23
Apr 15, 2013 | Kyocera Taskalfa 250ci Color Copier...
F2-40 repeatedly on a new Sharp MX4110 machine
during setup the machine do,nt install toner during calibration 25-2 steps: 1. Execute Simulation 25-01 and verify that the TCD_K value is less than 26. 2. Execute Simulation 7-1 and highlight [DV Check Disable]. 3. Open the Doc Feeder. 4. Place a piece of white paper in the lead edge area of the platen glass covering about 1-2 inches of the lead edge area of the copy. This will prevent jamming in the Fuser Unit. 5. Run 50 sky shots. 6. Check Simulation 25-01 and note the TCD_K value when it stabilizes. 7. Repeat steps 2 through 6 until the stabilized TCD_K value of Simulation 25-01 is 40 or higher. 8. Execute Simulation 7-1 and verify that [DV Check Disable] is not highlighted. 9. Hit CA and make sure machine comes to a ready state. 10. Turn Machine off/on. Make sure it comes to a ready state. 11. Make a copy and check the copy quality. 12. Run Copy Quality adjustment 12a according to the service manual if necessary. Note: TCD_K value of 26 or less will cause the MFP to display F2-40 error code. Remember that the TCD_K Value is inversely proportional to the Toner Concentration. If the TCD_K Value is stabilized at 40 or higher, then the F2-40 error code will not appear. Once you recover from the F2-40 Error Code, the MFP's Process Control will take over and regulate the Toner Concentration.
Sep 13, 2012 | Sharp "MX-4100N Copier, Printer, Scanner...
I start the machine and after 5 seconds give me the 116-324 error code
Thats called an exception error. One of 2 things. Either it needs a complete software upload, or the network control board, called the ESS board has failed.
You can try these steps
This step will delete any print or copy job that is in process, and then perform a reboot.
To execute: simultaneously press and hold the 1, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
This step will delete all pending print or copy jobs in the job queue, and then perform a reboot.
To execute: simultaneously press and hold the 6, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
This step will delete all pending print or copy jobs in the IOT job queue (DC 3535: does not delete any job data stored in the Network Controller), initializes the IOT HDD (refer to ADJ 9.8 for details), and will and then perform a reboot. All customer data on the HDD will be deleted.
To execute: simultaneously press and hold the 4, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
This routine will set all IOT ESS NVM values to default. Do not attempt this procedure unless there is a known-good Machine Settings floppy, an accurate Configuration Report and/or other data that will enable you to reload the correct NVM values for this machine.
This step will initialize the IOT ESS NVM (SYS-System and SYS-User) and then perform a reboot.
To execute: simultaneously press and hold the 3, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
The last one IOT ESS NVM will clear all your netrowk settings.
May 07, 2011 | Xerox WorkCentre M-24 Color Copier
I get the following error as soon as i start casino.exe. The application failed to initialize properly (0xc0000005). click ok to terminate the application. please help me. i like konami casino game...
In many cases this error has been generated by faulty RAM memory. So if you have just upgraded your computer with some new memory and you started getting this error then would remove them and see if the error goes away. If it does then send the memory back and get a refund!
In Windows XP Service Pack 2 Microsoft introduced Data execution prevention (DEP), a set of hardware and software technologies that perform additional checks on memory to help protect against malicious code exploits. In Windows XP SP2, DEP is enforced by both hardware and software.
Some software/application behaviours are incompatible with DEP - data execution prevention.
/NOEXECUTE
This option is only available on 32-bit versions of Windows when running on processors supporting no-execute protection. It enables no-execute protection (also known as Data Execution Protection - DEP), which results in the Memory Manager marking pages containing data as no-execute so that they cannot be executed as code. This can be useful for preventing malicious code from exploiting buffer overflow bugs with unexpected program input in order to execute arbitrary code. No-execute protection is always enabled on 64-bit versions of Windows on processors that support no-execute protection.
There are several options you can specify with this switch:
/NOEXECUTE=OPTIN Enables DEP for core system images and those specified in the DEP configuration dialog.
/NOEXECUTE=OPTOUT Enables DEP for all images except those specified in the DEP configuration dialog.
/NOEXECUTE=ALWAYSON Enables DEP on all images.
/NOEXECUTE=ALWAYSOFF Disables DEP. (This setting doesn't provide any DEP coverage for any part of the system, regardless of hardware DEP support. The processor doesn't run in Physical Address Extension (PAE) mode unless the /PAE option is present in the boot.ini file.)
This error also seen when people have updated drivers for their graphics card. If this happens just roll back your drivers. Also keep an eye on the vendors website to see if they have an update/patch available or coming soon.
Mar 03, 2011 | Konami Casino Inc. for Windows
I have an eMachine T3410. When it boots, a screen
your missing the biosinfo.inf. try reinstalling the system but backup everything you need first.
Jun 09, 2009 | E-Machines eMonster 600 PC Desktop
Desktop doesn't appear on the computer.
hi there, The error 0xC0000005 is generated by an illegal "memory access violation". This can be caused by anything from faulty RAM, an incorrect/corrupt device driver, poorly written/updated software and more commonly under Windows XP Service pack 2, malware/adware installations.
i would suggest that the ram in your computer has possibly broken down over a period, may i recommend obtaining some new ram, if you go to www.crucial.com they can provide you with information that tells you which ram you have in your PC.
Jan 25, 2009 | Acer Aspire 3680 Laptop
Kyocera FS-6025MFP Laser Multifunction Printer - Monochrome - Plain Pa Logo
105 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
