Despite adjusting sharpness to the max, the picture is still fuzzy, hard to read text on screen. Is there another way to adjust it?
    Top Expert:
  • Televison & ... Master
  • 74,496 Answers
What is the level of Contrast. Check it. It should be more than 50% of its total value, to get satisfactory picture.
Posted on Apr 16, 2015
Testimonial: "Thanks for the help. I did adjust the contrast level and the picture improved, but, it still is fuzzy. Anything else I can do?"
I have a sony trinitron 36in tv, the screen works fine, colours are all great, no flickering or random shapes at all, its just a little blurry around edges, especially small text, its very blurry and...
it is very easy you just need a very small straight edge screwdriver
you should try to adjust sharpness setting with on screen adjustment first
if tv is too old tube might be going "soft" and sharp focus might not be able to be fully achieved anymore
good luck
Mar 13, 2011 | Sony FD Trinitron WEGA KV-36HS510 36" TV
The screen says, "press enter to align your cartridges" !!!
The alignment process prints one page, and then you put that page into the scanner. The scanner reads the page, compares the actual alignment with the optimal alignment, and adjusts the printer, in order to produce "sharp" (opposed to "fuzzy") colour pictures.
Aug 22, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Jvc 27'' TV is too dark
There are two small holes on the rear side through which you can adjust focus and screen. Use a flash light and locate the two adjustable slots inside the holes. This part carries high voltage. Do not use a metal screwdriver to adjust. Put the TV facing a mirror so you can see how it works. Do not turn more than 1/8th of a turn. The focus control makes picture sharp or fuzzy. Screen control could change brightness. While watching the picture in the mirror, slightly adjust the screen control. Do not turn too much. If it doesn't work, then call a JVC authorized repair center.
Jan 22, 2010 | JVC AV-27D203 27" TV
Tv is alittle blurry, its hard to read words
when its hard to read words its usually the sharpness which make the t.v.'s look either blurry or sharp or right in between. you can fix this by adjusting it thru your tv's menu either on the tv or your remote, look under the picture tab in the menu and there should be a sharpness adjuster there. adjust as needed
Oct 13, 2009 | Televison & Video
Ricoh CL7000 text is blurry/fuzzy
probably only when printing in colour? Black only, is ok right?
It needs to have it's line adjustment procedure done. This is a series of complicated trial and error adjustments performed in service mode that the individual colours are adjusted based on printouts generated by the printer. Can only be adjusted by a service tech with experience with this adjustment.
Jul 11, 2009 | Ricoh Office Equipment & Supplies
Philips 34pw9818 fuzzy screen
Inside the set you should see a large part with a red wire coming out the top. That is the flyback transformer. There will be 1 or 2 controls on the back of it. One should be labeled screen and one focus. Carefully adjust the focus one until the picture is again in focus. Please note that in that area are high voltages (33,000V) that can be dangerous. Be careful where you touch. IT is best to have a mirror so you can see the picture while adjusting the focus control.
Dan
Feb 04, 2009 | Philips 34PW9818 34" TV
Lg 37in the picture cquality in hd is sometimes fuzzy
There is quite a lot you can do. Go to menu, picture settings and select user 1. From here you can adjust everything from colour to contrast to warmth to sharpness. The best thing to do is to swith to XD manual adjustment and make sure the mpeg noise reduction is set to max. This removes artifacts and gives a better picture. Oddly, connecting via SCART rather than HDMI will give a more watchable picture if the HD broadcast is't at a very high bit-rate. I hope that helps :o)
Jan 15, 2008 | LG 42LC2D 42 in. LCD HDTV
Unclear images
Remove the rear cover and adjust the focus control on the flyback. Use a non-conductive probe, available as adjustment tools from any radio shack. On the FBT (Flyback Transformer) you have two protruding adjustments - one marked screen, the other focus. The screen adjustment increases the G2 voltage to the crt and brightens the picture by increasing the voltage exponentially. You don't want to adjust the screen voltage. The other is the focus, you can easily turn that clockwise or counter clockwise and watch the screen to set it at your preference.
Hope this helps.
Bill
Nov 11, 2007 | E-Machines 17F2 17" CRT Monitor
Fuzzy screen
take off the front coner under that will be another cover it will require a screwdriver to remove now there will be a murata component with nobs on the front be careful only one nob controls focus the rest of which control the projectors
Oct 27, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Fuzzy Display
check your sharpness control in the adjustment setup. If its set to max you might or sme sets have a tendancy to look grainy. Also check your source and be sure the signals strong. Such as just adding another tV to a cable line can cause weak signal. Ceck it with another set in its place. If thats the case simply add a small 20.00 cable amplifyer. Good Luck
Jul 27, 2006 | ViewSonic N2000 20 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
