Question about Sony Stereo Am Fm Receiver Tuner Amplifier Amp Str-de885
Where to order cords
Where do I order the antenna cords for my receive plus all the speeker wire I lost it in the moving process
  • Sony Master
  • 5,487 Answers
Any Hi-Fi store will be able to provide them. Amazon have a good selection of cables and wires. As with all cables and wires with hi-fi the better quality sound you want the more expensive the cables you need to get. But it's your choice. You will need to specify which cables you need, based on the connections between your hi-fi and the Receiver.
Posted on Jun 29, 2015
Which cord is the antenna on eclipse cd receiver model 8443
It will be the black cord with a female
connection half inch hole, or there will be
a small half ince hole in the back of unit
where the antenna wire will plug inn
Jun 16, 2014 | Eclipse CD2000 CD Player
Am fm reception bad
FM reception is weak
What to do
• Extend the power cord as much as possible. The FM antenna is in the power cord.
• Move the power cord to adjust the FM antenna
• If you still have problems with FM reception, you may need an external antenna.
* Call Bose®Customer Service to request one.
The external antenna on your radio is a coax (round) design It needs an adaptor and an antenna which are cheap.
Easy to make, radio shack "F" connector 90 degrees or straight, to 300 ohm wire connections. Attatch a 300 ohm flat ribbon antenna cable to those two screws and plug into radio and see how your reception is. You will need to position the antenna wires to get best reception. I have hid them in back of paintings and so on.
Cheapest solution next to putting an extension cord on radio power cord.
Jan 03, 2011 | Bose Wave Radio
We can get analogue tv and foxtel chanels but we have lost all digital tv chanels. We have run a full scan but nothing happens
unplug the power cord plug from the tv then unplug the antenna cable look inside the antenna metal peace make sure the wires are not touching to each other first connect back the antenna plug then the power cord if its an interior antenna your problem is the antenna
Oct 17, 2010 | Sony BRAVIA KDL52XBR2 Television
Any 1 no the speeker color codes or speeker order?
yellow 12v battery
red 12v accessory
black earth
blue/white amp rem
blue power antenna
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
green rear left +
green/black rear left -
purple rear right +
purple/black rear right -
that should help u
Aug 17, 2010 | Sony Car Audio & Video
Am/fm radio stations not clear... I have the AM antenna attached... but there is no attachment for FM
First of all check for any nearby source of interference.....Move your unit away from all computers, fluorescent lights, neon lights, microwaves, cell phones, and cell phonemag-glass_10x10.gif chargers. These devises tend to produce noise in the medium frequency band, where AM radio is broadcast.
If the unit plugs into the wall with a nonpolarized plug (where both prongs are the same size), try reversing the plug inmag-glass_10x10.gif the outlet. Moving the plug to another outlet might help, too.
check for fault in the antenna lead, (common) or bad earth on the antenna to body
If you don't have an antenna connected to your FM receiver,With a receiver or tuner, connect a wire-loop or T-shaped dipole FM antenna to the back of your unit. Move the antenna until you get the cleanest signal. Use a signal-strength meter or display to gauge signal strength if your unit has one.
  • Step 2 If you're still not getting a good signal, try an indoor amplified antenna, which you'll find at an electronics store. Don't buy one unless you get a guarantee that you can return it for full credit if it doesn't solve your reception problems.
  • Step 3 If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters.
  • Step 4 If you're using a portable FM radio where the only antenna is the power cord, stretch the cord as straight as possible and experiment with positioning again.
  • Step 5 Temporarily switch to monaural mode to improve a weak signal on an FM receiver.
  • Read more: How to Strengthen FM Radio Reception | eHow.com http://www.ehow.com/how_114024_strengthen-fm-radio.html#ixzz0u9nhGXAL
    If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters. Make sure to Switch from stereo to mono.
  • Step 4 With a receiver or tuner, connect a wire-loop or T-shaped dipole FM antenna to the back of your unit. Move the antenna until you get the cleanest signal. Use a signal-strength meter or display to gauge signal strength if your unit has one.
  • Step 5 Alternatively, upgrade to a third-party passive or powered antenna.
  • Step 6 Install a rotatable roof antenna for the best possible reception. Connect your unit to an existing televisionmag-glass_10x10.gif roof antenna for the next-best alternative.
  • Read more: How to Improve FM Reception | eHow.com http://www.ehow.com/how_5554_improve-fm-reception.html#ixzz0u9oTaz4Y
    Jul 19, 2010 | RCA RT2760 System
    Improve reception
    HI there,
    Well Yes you can improve the reception, please follow the below steps -
    Improve FM Radio Reception -
    1. If you don't have an antenna connected to your FM receiver, purchase a simple dipole antenna--a simple T-shape flexible wire-- and connect it to the FM antenna inputs on the receiver. Because FM signals are directional, you'll want to experiment with the positioning of the wire to find the best reception of the station you're trying to receive.
    2. If you're still not getting a good signal, try an indoor amplified antenna, which you'll find at an electronics store. Don't buy one unless you get a guarantee that you can return it for full credit if it doesn't solve your reception problems.
    3. If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters.
    4. If you're using a portable FM radio where the only antenna is the power cord, stretch the cord as straight as possible and experiment with positioning again.
    5. Temporarily switch to monaural mode to improve a weak signal on an FM receiver.
    Improve AM Reception -
    1. Gradually rotate the radio 360 degrees. Leave it in the position where it sounds best.
    2. Reverse the AC plug if it isn't polarized. (If you can flip the plug over, then it's non-polarized.)
    3. Plug the radio into a different AC outlet.
    4. Move the radio closer to a window.
    5. Experiment to learn if appliances and powered products in your home are causing interference: computer monitor, television, electric blanket, light dimmer, fluorescent light, hair dryer, air conditioner, smoke detector. If possible, turn off the offending item. Otherwise, move the radio to another room.
    6. Upgrade to an external antenna if your receiver, tuner or radio has a place to connect one.
    7. Buy a passive AM antenna that doesn't need to be connected to a radio or receiver.
    Good Luck!!
    Thanks
    Dec 29, 2009 | RCA RP5430 Clock Radio
    No... i need to see how to wire this thing up i moved and lost the manual
    Solution 1) The antenna goes to the antenna jacks, the video audio inputs to the video audio input jacks, the speakers to the speaker jacks, etc.
    Solution 2) Find a friend who knows a bit about home AV systems and ask him to help.
    Solution 3) Post the details of the receiver model and what other components you have in your system.
    Nov 15, 2009 | Pioneer Audio Players & Recorders
    RCA TV with Guide Plus that no longer receives guide at night
    Please clarify what you are getting. Is the Guide Plus coming up with no programs listed? If so, it may be that you lost power and the set has to be turned off overnight to "reload" the program schedule. If that is not the problem, have you recently changed to digital through a digital receiver? You need to have your analog antenna connected to receive the program listings. You may have to install a splitter to have both the digital antenna and the analog antenna connected. I have an RCA with Guide Plus and ran into the same problem, but solved it by reconnecting my analog antenna and leaving the set off overnight to reload.
    Feb 15, 2009 | Televison & Video
    There is a short buzzing sound from the rear left speeker then CD failure shows up on the display and no sound is produced .Model Sony CDX-GT470U I have wired it up according to the instructions and can't...
    The problem was that one of the speeker terminal wires was touching the metal body
    of the car on the edege of the hole where the speeker magnet sits.
    Once I moved the bare wire a little it fixed the problem.
    It's the little wire on the speeker itself not the wire that runs to the player.
    Dec 09, 2008 | Audio Players & Recorders
    Lost USB cord- where to order one?
    The cord you are looking for is a regular "Mini USB" cord and can be purchased at compusa. http://www.compusa.com/products/product_info.asp?pfp=cat3&product_code=50461398
    Jul 24, 2007 | iLO (2 GB) MP3 Player
    Sony Stereo Am Fm Receiver Tuner Amplifier Amp Str-de885 Logo
    147 people viewed this question
    Top Sony Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
