Question about Epson CX3810 Stylus Color All-In-One Printer
After printing a series of pages on both sides, when I took out the last page and reincerted it the printer stopped and all lights came on.
I have used this technic many times in the past.
  • Jim Rawson Apr 19, 2015
    I found the problem, it is a broken plastic latch .
  • Jim Rawson May 14, 2015
    I was able to fix it, I pushed the plastic part and the coil portion of the spring back in place and then I cut a section of a toothpick and wedged it into the center of the coil part of the spring and the metal tab that supports the spring. This is holding the plastic part in place, and now the printer works.
  • Epson Master
  • 2,898 Answers
So, did you get an error message? Did unplugging the printer get it working again?
How are you reinserting the paper?
Posted on May 13, 2015
Benimur
  • 6966 Answers
SOURCE: Printer not Print data in English Language
Hi, you may want to reset/restore the Epson LX300 to default settings. This can be done by pressing down on the FONT button while powering on the printer. If done right the LX300 will print a test page with the firmware version. It is also possible that the drivers are corrupted. In Start, Printers & Faxes, delete the LX300 printer, restart your PC and then re-install via Add Printer. In some cases, defective parallel cable can also cause problems. Unfortunately the only sure way of checking is by replacing the printer/parallel cable with a known good/operation cable. If the printer would really be requiring service, a Service Manual is available at (http://www.eserviceinfo.com/index.php?what=search2&searchstring=DPA-300) Hope this be of some help to you. Good luck and pls post again how things turn up.
Posted on May 26, 2007
SOURCE: Epson rx420 printer
Another post suggests that you printer is dead -see (http://www.fixya.com/support/t354202-epsom_rx_425_just_prints_half_page) but I've had the same problem - things seem to be ok after I reset to the defaults in the main page of the printing preferences.
Posted on Mar 15, 2008
SOURCE: EPSON LQ - 2180 paper settings
I HAVE CUSTOME SIZE OF PAPER WHICH IS NOT AVILABLE IN THE PRINTER LIST .WHEN I DEEL WITH WINDOS XP
BUT WHEN DEEL WIHTH WINDOS 98 ITS OK
NO I DONT HAVE WINDOS 98 . MY QUESTION HOW I CAN ADJUST PAPER TO CUSTOM SIZE
Posted on Nov 24, 2008
SOURCE: Auto cutter does not cut automatically
TM 220a and TM 220b should come with auto cutters
You have to unscrew the metal tab under the printer, you will find two sets of DIP switches. upper one is DWS 1 and the lower one is DWS 2. On DWS 2 you need to have jumper #2 ON. this enables or activates the auto cutter on printers. Good luck...
Posted on Jul 04, 2009
  • 63 Answers
SOURCE: the printer only prints half a page then moves to next page and a
Before printing, the printer checks the paper size. If the paper edge guide is positioned incorrectly, the paper may be fed at an angle. If this happens, the bottom of the paper is therefore at an angle and not perpendicular with the paper feed rollers. This can result in the paper sensor not recognising the real page width as it can only detect a certain amount of the bottom of the paper sheet which is nearest to it.
If only part of the width of the paper is detected, the printer considers that the paper width is less than it actually is. To avoid printing on internal parts of the printer such as paper feed rollers, the printer automatically cuts the image to fit the detected paper width As this phenomenon depends on the paper feeding condition, it can be random.
Reload the paper and make sure it is loaded correctly. All the way to the right and the paper guide correctly adjusted.
Posted on Feb 10, 2010
Testimonial: "Thank you so much, I no longer have a problem. It seems such a simple solution now I know the answer! I thought it was something major."
Why is the light flashing on the right side
If the light flashing is the "light bulb like button" or the "Ready/Light" button, it means that either the printer is:
• The printer is busy receiving and processing data or printing.
• The printer is printing a directory, font list, menu settings pages, or Print Quality Test Pages.
If it's Busy:
• Wait for the message to clear.
• Press and release Cancel to cancel the print job.
• Press and hold Cancel to reset the printer.
If it's printing a directory, a font list, menu settings pages, or Print Quality Test Pages:
• Wait for the pages to print. The Busy message is displayed as the pages print. The Ready light is on when the
printing stops.
• Press and release Cancel to cancel printing.
Jul 31, 2012 | Lexmark E250dn Laser Printer
Middle of print job - stops to CLEAN - then starts from pg1 AGAIN
This is a simple 3 step fix
a) Get rid of printer
b) Get rid of husband
c) Get new printer
Hope this works!! :-)
Jul 16, 2009 | Brother MFC 210C All-In-One InkJet Printer
Jam bothed ways
try this link and scroll down the page and see if anything on the page helps you out... HP LaserJet 6L Printer paper jam both ways Google Search
Oct 24, 2017 | HP LaserJet 6L Printer
HP psc 1310 printer autoprints a test page
the autoprint which you r telling is called allignment page which your printer is printing everytime.just when the printer prints that autoprint you take that autoprint and place the printed side of the paper on the scanner glass and press the scan button.the printer ON/RESUME light will blink for 1minute then automatically stop and then u will not get this autoprint till u replace any of the cartyridge from the printer.
Dec 15, 2008 | HP PSC 1315 All-In-One InkJet Printer
Test Page
thats not the test page that is allignment page which is printing.
keep the the printed side of that page which comes out on the scanner glass.press the ---scan ---button.the on /off light will blink, wait till it stops blinking.and after that everything will be normal.
for any thing else let me know.
thanks.
Sep 17, 2008 | HP LaserJet 1200n Printer
Aligning printer after new ink cartridge inserted
SOLUTION: Start the cartridge alignment by performing a series of button presses from the front panel of the product.
  • HP PSC 1200 and 1300 series:
    1. Turn on the HP PSC 1200 or 1300 series product.
    2. Disconnect the USB cable from the all-in-one.
    3. Press the sequence of front panel buttons below to start the print cartridge alignment process. The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
      1. Press and hold Cancel .
      2. While holding Cancel , press On .
      3. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons.
      4. Press Cancel again.
      5. Press Copies .
      6. Press Paper Type .
      7. Press Color Start Copy . The alignment page will begin printing. If the alignment page does not print, repeat the button-press sequence in this step.
    4. When the alignment page has printed, place the page face down on the scanner glass and press Scan . The alignment is complete when the On light stops blinking.
    5. Reconnect the USB cable.
CAUSE: This can occur if the cartridge alignment is canceled or times out without a valid print cartridge alignment stored in memory.
Oct 29, 2007 | HP PSC 1350v All-In-One InkJet Printer
Last page of printing stops 3/4 through the page.
Try cleaning your heads with appropriate solution. Then, cancel all print jobs. Try again. If it does the same i would turn it off, inplug all the cables, replug all and turn on. Try again. If still no good, completely unistall printer then reinstall it. Try once more. Good luck
Jan 16, 2007 | HP PSC 2175 All-In-One InkJet Printer
Epson CX3810 Stylus Color All-In-One Printer Logo
35 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
