Question about iPhone Apps
How to set my fitbit6 to show sleep paterns - iPhone Apps
  • iPhone Apps Master
  • 607 Answers
Https://help.fitbit.com/articles/en_US/Help_article/1314
-On fitbit dashboard, tap or click sleep tile. The tile says on "How did you sleep? Or if you tracked sleep night before it says how many hours and minutes you slept
    -Tap or click the moon icon on button
    -Find option to turn off sleep insights
Posted on Jan 04, 2018
Monitor goes to sleep immediately after turning on the computer. How can I fix that?
go to start,then pc settings,then monitor or power options the to power and sleep and change on plug to 4 hours and on battery to 10 minutes
Jun 11, 2015 | Computers & Internet
Jvc model av36f702 it jumps of evry time im trying to put it on with the remote . i tink the timer is set to 0 secones .can i reset the tv.
press display button & it shows the following
07
NOW 12:20 PM
SLEEP TIMER OFF/on
ON/OFF TIMER EVERYDAY
ON TIME 7:00 PM
OFF TIME 10:00 PM
• The current channel or AV input (Channel 07)
• The current time (12:20 pm)
• Sleep Timer status/minutes remaining (The Sleep Timer is off)
• On/Off Timer status (Set to turn on everyday at 7:00 PM, off at 10:00 PM)
• Each Press of the DISPLAY button changes the display mode:
Press the SLEEP TIMER button & set it to OFF
Dec 22, 2010 | JVC AV-36F702 36" TV
MY MONITOR SHOWS: VGA No signal DVI No signal then shows: Check Video Cable Then: Monitor going to sleep
Try another cable, borrow one, then try monitor in another PC / laptop, if it works then either the software settings for the sleep mode are on or it may be a faulty video card.
Oct 15, 2010 | HP Compaq WF1907 Monitor
Change the date and time
1 Press Menu/Set, 0, 2.
2 Enter the last two digits of the year.
Press Menu/Set.
3 Enter two digits for the month.
Press Menu/Set.
(For example, enter 09 for September,
or 10 for October.)
4 Enter two digits for the day.
Press Menu/Set.
(For example, enter 06 for 6th.)
5 Enter the time in 24-Hour format.
Press Menu/Set.
(For example, enter 15:25 for 3:25 P.M.)
6 Press Stop/Exit.
The LCD now shows the date and time
whenever the machine is idle in Fax
mode.
When the machine is in Sleep mode, the
LCD shows Sleep.
Jun 25, 2010 | Brother MFC-7220 All-In-One Laser Printer
System goes to sleep when spacebar is used
1) Navigate to the 'Power Options' (Start Search powercfg.cpl)
2) Select your power plan.
3) Click: Change plan settings.
4) Crucial Link: Change advanced powers settings
5) Research the Aladdin's cave of settings, in particular: 'Sleep'
6) Expand: Sleep after. If it's a laptop check both the 'Plugged in' and the 'On Battery' settings.
7) Choose: 'Never' to prevent your computer going into sleep mode.
8) Remember to click 'OK'. (Or apply if you want to configure more options.)
Aug 29, 2009 | Microsoft Windows Vista Ultimate Edition
Set the sleep function
I had to go through every one of the menu settings to find the sleep function.  Your manuals leave a LOT to be desired.  The index is almost useless. Functions such as this should be in the index.     A few examples to show the general way of setting functions should be in the manual.  Or show the flow charts to get to a setting. Not a happy camper, Sandy
Jun 05, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
BROTHER FAX MACHINE 2800
Your Brother machine#s Sleep Mode function reduces power consumption while the machine is idle. You can adjust how long your Brother machine is idle (between 00 and 99 minutes) before Sleep Mode is initiated. Please note that the default setting is 00 minutes, and the timer automatically resets itself after the Brother machine receives a fax,receives data from your PC, or makes a copy. To adjust your Brother machine#s Sleep Mode setting, please follow these steps:
1. Press MENU/SET, 1 (General Setup), 7 (Sleep Mode).
2. Use the dial pad to enter the amount of time the fax machine is idle before Sleep Mode is initiated (00 to 99 minutes).
3. Press the MENU/SET key to confirm your choice.
4. Press the STOP/EXIT key to exit the menu.
NOTE: If you frequently print, copy, or fax, set the idle time long
enough to insure that you will not always have to wait for the Brother machine to warm up.
Dec 02, 2008 | Brother IntelliFAX 2800 Laser Fax
Sleep Mode showing on the screen
SLEEP MODE MEANS NOTHING UNLESS YOUR USING IT WITH A PRINTER IT IS SAYING SLEEP BECUSE IT IS WAITING FOR A PRINT JOB IF YIOU ARE NOT REC. CHECK THE MODE KEY AND AMKE SURE IT IS SET TO FAX ONLY
Oct 11, 2007 | Brother IntelliFAX 4100 Laser Fax
iPhone Apps Logo
491 people viewed this question
Top Apps Experts
Bill Boyd
ray gallant
Are you an App Expert? Answer questions, earn points and help others
