Question about Toshiba REGZA 26HL47 TV
What is Worng with t.v. it turns itself on then off again every 10 seconds
Within that time frame I can hit the input button and get it to HDMI mode and have my computer hooked to it and it stays on no problem can this be fixed or do I need a new t.v.
    Top Expert:
  • Toshiba Master
  • 74,106 Answers
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Apr 16, 2015
Testimonial: "Thanks I didn't see anything on the link will have to call a repair shop"
I own a 2005 Ford Five Hundred and I am trying to get my keyless entry to work.
I assume you are trying to program the remote. Here are the instructions. Your question is very vague.
1. Turn ignition from OFF to RUN 8 times within 10 seconds, with the 8th time ending in
RUN. Door locks will cycle to confirm programming mode.
2. Within 20 seconds press any button on first keyless remote. Door locks will cycle
to confirm programming.
3. Within 20 seconds, press any button on second keyless remote. Door locks will
cycle again to confirm programming.
4. Turn ignition to OFF. Locks will again cycle to indicate end of programming mode.
Oct 20, 2012 | Cars & Trucks
1999 Mercury Sable Keyless entry wont work
I only have the instructions. If it won't program you may have a problem in the module. In that case see the dealer for testing and diagnosis
. Turn ignition from OFF to RUN 8 times within 10 seconds, with the 8th time ending in RUN.
Door locks will cycle to confirm programming mode. 2. Within 20 seconds press any button on first keyless remote. Door locks will cycle to
3. Within 20 seconds, press any button on second keyless remote. Door locks will cycle
Jul 03, 2012 | 1999 Mercury Sable
Have mecruy montneer 2001 lost keys how to program it
Programming Instructions: 2001 Mercury Mountaineer.
1. Turn ignition from OFF to RUN 8 times within 10 seconds, with the 8th time ending in RUN.
Apr 26, 2011 | 2001 Mercury Mountaineer
How to program keyless entry? bought vehicle used from dealership
Feb 04, 2010 | 2003 Ford Expedition
Dynex tv works. bought ps3. when hooked up to
I would suggest you check if your PS3 is set up on going through the HDMI Cable.On your PS3's XMB scroll to settings -> Display Settings -> ANd from there go down to the one that says "Y Pb/Cb Pr/Cr Super-White (HDMI)" and hit X and select the option Yes... That sets the PS3 displaying through the HDMI
If you are already have done that I'm pretty sure you know you have to change the Input on your TV to HDMI... Take your remote and hit Input -> Scroll down to HDMI on the Input Source menu and hit Enter when you get to HDMI
If the AV on your PS3 works and not your HDMI sounds like Display Settings issue...
If you have done all that, that is strange if it still doesn't work.
There are some people that are having problems with the AV Cable with the PS3, I tried this and it really does work. I switched from HDMI on one tv to a AV Cable on another and when I did that neither TV would display content from my tv. The fix for this is resetting your PS3, like on a iDevice you hold the home button and lock button, for the PS3 you hold the Power off button and the Eject button for around 10 seconds. This resets your PS3 into default video settings. Until it Turns on, Beeps, and Turns off. This should work.
Jan 01, 2010 | Televison & Video
1) I turn on the power and place a prerecorded
If it is not a bad soldering joint somewhere, it could be the mode switch. They can sometimes be cleaned with Servisol Video 40, but you might have to replace it.
Dec 21, 2009 | Panasonic AG-1980 S-VHS VCR
Trying to program a remote, but it doesn't work.  i followed the instructions turned the key from off to on 8 times and left it at on, but the locks did nothing. can you help?
WHAT FOLLOWS IS THE CORRECT PROCEDURE, REMEMBER YOU MUST COMPLETE THE 8 KEY CYCLES IN LESS THAN 10 SECONDS, IF YOU DO IT RIGHT THE POWER LOCKS WILL GO UP AND DOWN TO INDICATE IT IS READY FOR PROGRAMMING.
Jul 08, 2009 | 2002 Ford Taurus
Car key remote
Mar 24, 2009 | 2001 Ford Expedition
Apex 1919 tv model brand new and stopped working
I had the same problem. Turned out to be bad capacitor on the main power supply board. The board has a heavy red and black cable at one end and several grey wires at the opposite end. Near the grey cables there are three blue cylinders (two large and one small) surrounded by a black metal frame heat sink. One of the two larger ones was "pregnant" swollen and about to burst. I changed it and the other one like it will new ones from Radio Shack P/N 272-1032 1000 uf 35 WVDC. The unit powered up and worked fine again.
Find a friend who is handy with a soldering iron - parts cost about $3. Be sure to unplug and discharge everything before diving in.
Not a bad little TV/Monitor otherwise.
Good luck
Mar 21, 2009 | Apex Digital LD1919 19 in. LCD TV
No signal
mine did the same thing...it was on rgb...didn't have ability to plug in computer to tv as suggested previously and I kept trying to hit input button on side of tv after turning tv on..didn't work but when I pushed input button before turning on tv when i turned on tv input screen was up and was able to move input to hdmi...everything works now.
Jan 04, 2009 | Vizio L32 32 in. LCD HDTV
Toshiba REGZA 26HL47 TV Logo
48 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
