Question about Sceptre X460bv-f120 46-inch Class Television 120hz Hdtv Lcd And Pc
Ideas? TV Works BUT has extremely Hi Pitched Screeching from power board.
I have fixed this since I started writing Although Never fixed. Machine was repaired under warranty 2 times... If you replace the power board http://www.shopjimmy.com/sceptre-3bs0231812gp-power-supply-unit.htm They still sell rev1. The smallest transformer in the center of the board was screaming. I isolated it by hearing then I firmly pushed on this transformer to the weight of my push shut it up quiet till released. So I re-soldered all the connectors of this transformer as to remount it to the board. It is quiet now. If you visually look at the transformer. you will see that the transformers are smothered in a yellowish clear rubberized plastic. The plastic on the one I remounted was visually cracked. Another step I've heard is to slather some more epoxy on top of it. Take Care
    Top Expert:
  • Sceptre Master
  • 74,136 Answers
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on Apr 16, 2015
Testimonial: "We are the technicians. We are here to do the repairs. "Surgery" on Power Supply Capacitors is almost always recommended. Whole board swapping swap can be used to isolate issues. In the field you don't always have full boards. 15w 25w 40w Soldering guns, solder sucker, solder should be in your tool kit. Caps 470Uf 16v 25v 35v 1000uf 16v 25v 35v 2200Uf 16v 25V 35v 3300uf 16v 25v 35v if you invest $50 in Caps you could repair just about anything power related on the spot. PS the BlogSpot above attacks you"
MY EMERSON TV MODEL #E320EM3 suddenly shut down and there is a Hi pitched screeching sound coming from it
Your Emerson TV has a problem at its power supply if it is possible get it changed .
May 18, 2017 | Emerson Televison & Video
Tv just started making a very high pitched noise, although picture and sound are fine?
Barb, noise may be from a power supply/ transformer on it's way out.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
HELP what is that high pitched noise when tv is on
Is your LCD making buzzing or high pitch noise
Mar 04, 2016 | Sanyo Dp55441 TV
When I went to turn on my 20 month old 46in LCD LN46A500 it made the loudest high pitch screeching sound that no one would like to hear and the picture was black. The remote buttons and the TV control...
The power supply board have fail badly,all that high pitch screeching sound,it came from those high voltages gaps from those tranformers,that giving ur tv high voltages.The power supply board,that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 25, 2010 | Samsung LN46A500 46 in. TV
High pitched rev when accelerating up to 30mph and a losing power with a sound like someone scratching thier nails down a blackboard
Sounds like the clutch is failing. The engine is reving up and the bike doesn't as much? the screeching is the clutch slipping, check to be sure the clutch is adjusted with free play at the handle and smooth operation ( cable works smoolthly ). Then reserch how to get the cluch set and when it arrives change the clutch. It's possible that the primary gear set has failed is it really loud? Take the cluch cover off and inspect for busted parts and striped gears. what ever you find write down the parts needed and put it back together as the longer it's apart the more likly you'll never get it fixed.
Jun 03, 2010 | 2006 Yamaha XT 125 X
Screeching noise
rear drum bearing needs to be replaced
Sep 25, 2009 | Maytag Dryers
Water pump cli
Sounds to me like she might have spun a main bearing......
Jul 16, 2009 | 1997 Honda Civic
RCA VCR makes high pitched whining noise when it's on...
The power supply is starting to fail. There are a number of capacitors in the power supply that need to be replaced. A local repair shop should be able to fix this easily. Figure on $10 max for parts.
Dan
May 05, 2009 | RCA VR508 VCR
High pitched screeching noise when in spin cycle
Sounds like the belt is worn and might need to be replaced. Let me know if I can do anything else. thankyou for asking.
Mar 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
High pitched screeching/broken handle release
For the handle problem, detent lever part #2030052 and costs $4 to $5. A bearing in the motor is what is making it sound bad, part #2032211 and will cost around $60. You could try bissell.com or call them. They can at least let you know who has Bissell parts near you.
Mar 25, 2008 | Bissell CleanView 3596 Bagless Upright...
Sceptre X460bv-f120 46-inch Class Television 120hz Hdtv Lcd And Pc Logo
44 people viewed this question
Top Sceptre Televison & Video Experts
Henry  Thomas
Henry Thomas
Jaime Hernandez
Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
