What does error code 628 mean? - Office Equipment & Supplies
What does error code 1649uli indicate?
You have to call the Company representative who will guide you through the error code. Call :1-800-628-8458
In case you don't have the manual, here it is: http://www.searspartsdirect.com/partsdirect/user-manuals/TC5000-Bowflex-Parts-BOWFLEX+TREADCLIMBER-manual
Good Luck!
Feb 02, 2016 | Bowflex TreadClimber TC5000
How i solve error628 in photon net seter?
It is generally an issue with your modem, phone line, or a blocking port. This article answers the question how to fix error 628 Windows 7.
  1. Contact ISP to Check the Phone Line
  2. Upgrade the Network Driver
  3. Repair your Network Configurations
  4. Reinstall Modem Device
  5. For an instant fix, use Reginout
Apr 09, 2012 | Computers & Internet
I have a laptop which is going to be the victim of error 628 please tell me how to fix Error 628?
Check out this WEB site for details of this error.
http://www.wiki-errors.com/err.php?wiki=628
Dec 27, 2011 | Acer Aspire M5641 PC Desktop
Cant program dish remote control
Hi, Cheri Torres with DISH Network Customer Service here. We have a few different codes for each of our different models of remotes. I will list here for you the best codes for our more popular models of remotes and the instructions for addressing the remote to the Sharp TV. I hope this information helps and if you have any further questions please let me know!
Remote models
3.0, 3.1, 3.2, 3.4 IR remotes - codes 628, 739, 521, 629, 605, 607, 521.
5.0, 5.2, 5.3, 5.4 IR remotes - codes 628, 521, 741, 605, 607, 739, 629.
4.0 and 4.4 IR/UHF remotes - codes 628, 605, 741, 629, 652, 739, 679, 835.
6.0, 6.2, 6.3, 6.4 IR/UHF remotes - codes 569, 720, 500, 456, 506, 834.
20.0 IR and 21.0 IR/UHF remotes - codes 628, 521, 515, 001, 627, 835, 605.
Oct 22, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
How to solve error 628 in idea net setter. please give me an advice? i installed my idea net setter in my laptop, but when i click to connect, i've got a message ERROR:628, redial or close option are...
i also faced this problem error 628 code error again and again.. the solution explained here is also very helpful.. i fixed this problem by visiting this http://www.error628.com .. someone might get help from this site also.. thanks for sharing information about error 628..
Jul 05, 2011 | NetGear WGR614 Wireless Router
How to get the remote pin- code for the sharp TV
Hi, Cheri Torres with DISH Network Customer Service here. I came across your post and wanted to see if I could help. We have a few different codes for each of our different models of remotes. You should be able to find the model of your remote on the back of the remote at the top usually a two to three digit number with a decimal point. I will list here for you the codes for the remotes as well as the instructions for addressing your remote to your TV. I hope you find this information useful and if you have any other questions or concerns feel free to email me at Cheri.Torres@Dishnetwork.com. :)
Codes for Sharp TV
3.0, 3.1, 3.2 and 3.4 IR remotes - 628, 739, 521, 605, 526 and 835.
5.0, 5.2, 5.3 and 5.4 IR remotes - 628, 521, 741, 605, 739, 607, 608, 629 and 526.
4.0, 4.4, 6.0, 6.2, 6.3 and 6.4 IR/UHF remotes- 628, 605, 608, 739, 835, 741, 607, 658, 740, 674 and 628.
20.0 IR - 628, 521, 740, 654 and 898
21.0 IR/UHF remote - 835, 152 and 213.
Instructions for addressing remote to your TV.
  1. Turn the Television On
  2. Press and Hold the TV mode button until all other mode button light up red.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press the pound(#) button once.
    Note: The LED will flash three times.
  5. Test functionality with the TV
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Feb 21, 2011 | DISH Network IR Remote Control
While connecting data card it showing error 628
Hi Mohammed Fai,
Which is your operating system?
Assuming that your Operating system is Vista or Windows & i Have the Below Information.
This may help you.
Error code 628 means that "the port was disconnected". You may refer to:
List of Error Codes that you may receive when you try to make a dial-up connection or a VPN connection in Windows Vista
http://support.microsoft.com/kb/923944
Here are the following checklists recommended for setting up VPN:
1. Make sure you logon using the correct username or password or try different username.
2. Make sure the router is VPN pass through or GRE is enabled.
As part of troubleshooting, try these steps:
1. Boot to safe mode with networking and check if you can establish the connection from there.
Refer:
Start your computer in safe mode
http://windows.microsoft.com/en-US/windows7/Start-your-computer-in-safe-mode
Advanced startup options (including safe mode)
http://windows.microsoft.com/en-us/windows7/Advanced-startup-options-including-safe-mode
2. If the computer is connected to a router, bypass the router to check if it works this way. Refer the router manual for the same.
3. Upgrade the modem/router firmware. Please visit the manufacturer's website for the update.
Considering there maybe some specific settings on the connection which is related to your VPN service provider, it is also recommended that you contact PublicVPN.com for support.
PublicVPN.com support
http://www.publicvpn.com/support/index.php
Note: FixYa provides third-party contact information to help you find technical support. This contact information may change without notice. FixYa does not guarantee the accuracy of this third-party contact information.
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 13, 2011 | Computers & Internet
I have this error what do I do? Harmony 628 "system error 1"
This is a memory issue that can not really be fixed. Usually it means that one if the transistors has come loose off the logic board. Anyway, it's a hardware issue. I would look into contacting Logitech for a relacement remote.
Jun 11, 2010 | Logitech Harmony 628 LCD Remote Control
jasbo
jasbo
