Question about Onkyo Audio Players & Recorders
Is there a way to reset onkyo tx-ds494 receiver
  • Official Brand Answer
  • 333 Answers
HI Preshay, to reset the tx-ds494 first press and hold Video 1 then also press and hold Speaker A, the display will show Clear then the unit will shutdown. Please note that everything will revert back to factory defaults so it will be like taking the unit out of the box for the first time. If you need further assistance please contact our Product Support Team at 800-229-1687, Thanks, JT
Posted on Jul 31, 2015
SOURCE: Onkyo tx-sr800 PROTECT mode
Hold video1 and press speakers A button, it will say "clear" If the message protect appears again, then its service time.
Posted on Sep 05, 2007
  • 17 Answers
SOURCE: My Onkyo tx-sr606 7.1 receiver turns off by itself
hi, when the unit shuts off by itself, it means that the protection circuity inside has been activated. it can be a problem with the receiver itself or it is just detecting something hooked up to it that can cause possible damage so it shuts off.
you would need to disconnect everything from the back and by itself, try to turn it on, see if it will stay on and then crank the volume way up to max. if it stays on, the receiver is ok and you then need to rehook your devices one by one starting with the speakers until you determine the one causing the receiver to shut off.
however, if the receiver shuts off and won't turn on even by itself, it means that the problem is internal and it either has to go back to your dealer for an exchange or it has to be sent to a repair center for servicing.
hope this helps a bit.. ^_^
Posted on Mar 09, 2009
SOURCE: Onkyo AV Receiver TX-SR 805 no display on the receiver
Finally one of us found the solution - thanks to cambrian
Please follow the link
http://www.avsforum.com/avs-vb/showthread.php?t=857502&page=579
BTW: My knowledge of electronics is very limited, but nevertheless I could fix the problem. I hope you can do it too.
Posted on Mar 12, 2009
SOURCE: How can I reset my Onkyo TX-SR601? Hard reset...
Hold Video 1 and Press the power button then turn it back on i had the same problem
Posted on Mar 11, 2010
  • 137 Answers
SOURCE: how can I reset Onkyo receiver TX-SR602 without
press and hold vcr 1 button and then push power button, it will reset
Posted on Apr 14, 2010
Testimonial: "You are genius and excellent, thank you for your help!"
Would like to connect onkyo TX-DS494 to my television to play the television sound thru the receiver
To get the sound into the Receiver you don't need to go from the TV. On the back of the cable box there are a pair of audio outputs. Connect those to the inputs on the Onkyo. When that is done you need to select the input on the Onkyo to match the input that you have wired it to. You will then have audio come through your system.
Jan 08, 2015 | Onkyo Audio Players & Recorders
Shorted binding post
The front right channel audio output semiconductor will need to be replaced, and i recommend a qualified technician because this will be a complex repair.
Mar 19, 2012 | Onkyo TX-DS494 Receiver
Playing music from my computer into my tx-ds494 it has been cutting out into a really loud fuzzy noise like when your between radio stations
Sound like a poor connection to me. Verify the integrity of the cable on some different equipment if possible. Use some electrical contact cleaner such as DeOxit or Servisol Super 10 on the cable connectors and also in the computer audio output. Spray cleaner on the jack and then push in and out of the socket several times to scrub the connectors.
If you are using built in sound from a PC, it may be worth getting an external audio interface as the standard internal ones are not known for their hi-fi sound!
Sep 20, 2011 | Onkyo TX-DS494 Receiver
I cannot get the A and B controls to run all speakers at the same time?
You cannot use the A and B speakers simultaneously.
(Note on page 18).
Mar 27, 2010 | Onkyo TX-DS494 Receiver
Sensor Remote control
i have the same problem, have you found a sollution yet?
thanks,
peter
(haborufan@yahoo.com)
Nov 24, 2009 | Onkyo TX-DS494 Receiver
My remote working but recevier doesnt get signal
hey,
Apr 12, 2009 | Onkyo TX-DS494 Receiver
Onkyo HT-R501 7.1 reciever issues
i have the same problem with a onkyo tx ds494
Jan 05, 2008 | Onkyo TX-SR605 Receiver
No audio
Most of the time its the amps that are bad and need changing. This will be transistors on heatsink in the reciever. Part number should be on the amp.
Sep 19, 2007 | Onkyo TX-DS494 Receiver
TX-DS494 Surround Sound Issue
don't switch to stereo mode. switch to prologic mode
Aug 06, 2007 | Onkyo TX-DS494 Receiver
132 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
