Question about Sewing Machines
How do I get my sewing machine to sew with correct tension and straight stitches?
When the stitch tension is correct, each stitch is at a slight angle instead of in a straight line. I have tried adjusting both thread and bobbin tension, but I cannot get proper stitch tension and a straight stitch line.
  • 1,631 Answers
Over time, internal adjustments and servicing is required, at a sewing centers, service dept.
Take it in, have them look and repair, pay the nominal charge!
you will be glad you did!
Posted on Apr 16, 2015
bargainbox
  • 1388 Answers
SOURCE: My bottom thread is loose when sewing a straight stitch
Please TRY the solution BEFORE giving your considered rating.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
Posted on Jul 24, 2008
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
Mimito7
  • 128 Answers
SOURCE: Top thread stitches correctly but bottom thread loops.
FYI---- Loops on the bottom-- problem is in the threading..
Loops on the top--- problem is with the bobbin.
Posted on Apr 19, 2009
sburtenshaw1
  • 5 Answers
SOURCE: Shirring fabric?
When putting your shirring elastic on the bobbin, don't thread the elastic through the bobbin holder,adjust the stitch length longer,and loosen the tension, other wise if you want to put it through the bobbin holder you have to loosen the tension screw on the bobbin holder, and then you have to adjust it back for ordinary sewing,
Posted on Feb 13, 2010
  • 980 Answers
SOURCE: Sewing machine not stitching
Sounds like you need to retime the machine, if you email me I can attach instructions drivewithken@blueyonder.co.uk
Posted on Jun 26, 2010
Is the Kenmore sewing machine 15343 able to do a baste stitch? If so, how?
A baste stitch is basically setting the machine to a straight stitch with the longest stitch length available. Loosen the top tension slightly if you want to remove the basting later.
May 12, 2017 | Kenmore Sewing Machines
The top of the stitching is so loose, it can be pulled out with no effort. Have retreaded several times, used manual as guide. Tension is on 4, stitch length on 2.5 and stitch width on A.
Remove the upper thread. Install a brand new needle
RAISE the presser foot and rethread from the beginning--make sure the thread path is correct.
Set the upper tension at the midway point which is usually the factory standard. This is a beginning point. Every machine is different and may require some tweaking to get the stitch tension where you want it.
Make sure the bobbin is inserted in the bobbin case and turning the correct direction and the bobbin tension is threaded correctly.
Retest your machine.
If the bobbin thread is tight and still pulling the upper thread down, either tighten the upper tension slightly and retest. If it is still the case, then the bobbin tension probably needs to lightened up slightly.
The tension is correct when both threads meet in the middle of the fabric.
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
How to Adjust Sewing Machine Tension on Craftsy
Understanding Thread Tension Threads
Oct 15, 2016 | Sewing Machines
My thread keeps bird nesting on the bottom of my fabric what am I doing wrong? What are the correct settings for a straight stitch?
Is your bobbin threaded correctly? You should be able to pull out the thread slowly while feeling it very slightly holding back. It should not pull out easily or quickly.
Could be something wrong with your tensions, try adjusting the upper tension first by starting at the middle setting and working gradually higher and then lower till you get a neat even stitch.
Nov 29, 2015 | Sewing Machines
How to adjust the bobbin tension.
According to the manual, you should not need to adjust the bobbin tension (and I located other sites which stated the bobbin tension cannot be adjusted on this machine). Apparently, all the tension adjustment is accomplished through the upper thread::
"EN Thread Tension Upper thread tension Basic thread tension setting: "4". (1) To increase the tension, turn the dial to the next number up. To reduce the tension, turn the dial to the next number down. A. Normal thread tension for straight stitch sewing. B. Thread tension too loose for straight stitch sewing. Turn dial to higher number. C. Thread tension too tight for straight stitch sewing. Turn dial to lower number. D. Normal thread tension for zig zag and decorative sewing. Correct thread tension is when a small amount of the upper thread appears on the bottom side of fabric. Lower thread tension The bobbin tension has been set correctly at the factory, so you do not need to adjust it. Please note: - Proper tension setting is important for strong seams. - There is no single tension setting appropriate for all stitch functions, thread or fabric. - A balanced tension (identical stitches both top and bottom) is usually only desirable for straight stitch construction sewing. - 90% of all sewing will be between "3" and "5". - For zig zag and decorative sewing stitch functions, thread tension should generally be less than for straight stitch sewing. - For all decorative sewing you will always obtain a nicer stitch and less fabric puckering when the upper thread appears on the bottom side of your fabric. 1 A B C 22 D"
Doing further research, I found this statement on a machine review site:
"After reading reviews online from where I've bought my drop-in bobbin machines, I think many of the negative reviews are due to the bobbin thread coming up without laying across the bobbin. It can cause the stitches to look very sloppy and no amount of tension adjusting can fix the stitches."
There are several machine review sites wherein 4423 owners stated their disappointment in the 4423's performance. Some said the machine failed almost immediately and others said the machines developed problems when sewing heavy fabric.
Apr 26, 2015 | Singer 4423 Sewing Machine
Tension setting for small straight stitch on a Kenmore 10 Stich model 385 1249380 sewing machine.
Please go to Kenmore model 385 1249380 sewing machine sell shop and ask the machanic or shopkeeper.
Jan 01, 2014 | Sewing Machines
Bernina activa 210 won't zigzag and has bobbin issues on straight stitch
it's very possible that the machine is slightly out of time & needs to be service at a sewing machine shop
is the fabric & thread & needle compatable with each other?
did you use every thread guide when threading the machine?
is the bobbin in correctly?
is the bobbin warped?
Mar 20, 2012 | Bernina Sewing Machines
Im using a free mashine foot to do embordery work and i cant get the tension setting right. ive tried all the diffrent settings and the stitch seems really loose when i sow. how do i get the setting...
First make sure you have a good quality cotton thread. I like to use Mettler silk finish 50 weight natural color. Start by sewing a straight stitch on two layers of light cotton fabric. You should have a tension the looks the same on both sides of the fabric when you sew. Adjust the tensions, if nessesary, and then try a sample on a practice sandwich. You might have to increase the top tension just slightly.
Apr 24, 2011 | Janome 4623 Mechanical Sewing Machine
I have just aquired a old singer machine that is straight stitch only. The problem i am having is when sewing the top stitch is slightly diagonal, while the underneath is straight. I have tried...
Are you sure that you have an 1120 because I looked up your manual (it is free on www.singerco.com under the customer support tab) and it is not just a straight stitch machine. If, it is not an 1120 put your correct number in and read the manual. Look on the back of your machine for your model number.
Nov 01, 2010 | Singer 1120 Mechanical Sewing Machine
Tension problem using zigzag stitch
Most likely the fabric is too light weight to sustain the thread tension using a wide zig-zag stitch. Tunneling will occur in this case.
Loosening the tension (top & bobbin) could also be beneficial.
Sometimes the machine has a special foot (sometimes called overlock) that will help. However, using something to add more body to the fabric, like a wash-away or tear-away fabric stabilizer to the seam or even adding paper will help limit tunneling. Sometimes heavy starch applied to the seamline before stitching will be helpful.
tunneling when zigzagging Threads Magazine Gatherings Forum Sewing...
zigzag stitch troubleshoot
May 08, 2017 | Kenmore 19233 Computerized Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
