Question about The Toys
Some of the scoring pads on my dartboard have bubbled up and are causing an error or leaves no room for the pad to press the sensor.
It has never gotten wet and was hung up and being used when it started happening. All together, there are about 14 pads that are puffed up (8 large square pads, 4 white and 4 black) and (5 large black triangular pads and 5 white large triangular pads). Is there a way to fix this problem or way to order new pads? I don't want to spend $200 buying a new one when it works fine and should be an easy fix.
geniusguy
  • 103 Answers
SOURCE: porshe boxster brake pad wear sensor
Hi
The pads may need adjusting...However the physics behind all this says that when the pads are wet...there is reduced Friction...and hence lower braking power...this may be perceived as a worn out pad when it is wet....Try apply the brakes to dry the pads when driving and the sign should go off...
Genius Guy
Posted on Oct 16, 2008
SOURCE: Top row of pads don't work, can I fix them? MPC2000xl
go here:
http://www.mpcstuff.com/pad-sensors-with-ribbon-for-mpc.html
there is also an install video.
i have the same exact problem.
best,
m
Posted on Apr 23, 2009
SOURCE: touchpad
This touchpad works with the same principle of a PC keyboard or a TV remote control: pushing the touchpad makes a shortcircuit between two electrical paths.
To fix the problem you need to clean the two contact surfaces that are in the bottom of the metallic film (the label where you can see de up and down arrow) and the upper surface of the electical paths (the touchpad chip) because they are dirty and their electrical properties (conductivity in this case)are missed.
Steps to fix this problems:
1. Take off the four tiny screws (two at both sides of your mp3)
2. With a very small screwdriver take apart the back cover of your mp3. Make it gently but firmly the first time it seems hard to separate it, but the back cover do not has anything more to be retained on its position. Before totally separte the back, take notice that: A) The battery is scticked to the back cover and you need to disconnect the cable that connects it to the circuit board. Separate them carlessly will break the connector or the thin cables, it will be very difficult to repair this failure; B) there are two plastic chromed pieces at the upper side of the mp3 (the ring for the strap and a large one rectangular piece that seems to reforce the audio out plug connector. Take notice how this chromed pieces are in place in order to reinstal it again latter. They will pull down because pressure only mantanis them in position.
3. With the back cover pulled apart you can see two more identical screws to the four you retired on step 1, These screws are almos at the midle of the body of the mp3. Take off this two screws.
4. Now you can take off the front cover.
5. Once the front cover is pulled out, you can see the touchpad in it's positon, take off the plastic outher square (the one that has the marks Tun On, Forward, Backward and Return) it's easy to do so.
6. Now you can see clearly the piece that don't works: the touchpad. You need to separate it from the mp3´s body. There is a flex cable that connects the touchpad to the back of the printed circuit, on the circuit board there is a connector that secures this flex cable to the board, don't pull out ,at this moment, the cable...
7. You need to take notice that the connector has two tiny brown and rectangular plastic pieces at the left and the right of the conector. This pieces, when pulled in, secures the flex cable to the connector, and when pulled out release the pressure that secures it and you can take in or take out the flex cable. Don't try to move the secures before read ...
8. With a tiny screwdriver move out (in the same direction of the flex cable) the tiny brown and rectangular pieces no more that one or two milimeters or you can broke them and can't ever make a good electrical contact, you need to be very careful to avoid damage this plastic fragile pieces.
9. Once you move this plastic secures, you can retire the flex cable from the connector, pull out to do this.
10. Now you can retire the touch pad and put it appart of the mp3.
11. With the touchpad on your hand you can see (use a magnifier to see details) that the "metal" area where you push with your fingers to control the options of the mp3 is only a tiny label, and I can tell you that this label is sticked with adhesive to the plastic "chasis" of the touchpad.
12. On one side of the touchpad label you can pull in the tip of a tiny screwdriver in order to separate the metal label of the plastic chasis. Find it and begin to separate this label, the adhesive is not too firm, once you start to see that you can separate it without damage (believe me, is too difficult to damage the metal label by separating it) you can separate totally the label from its site.
13. Once separted the label, you can see that its bottom side has a black square, this square is electrical conductive, its surface has to be clean showing an uniform black color, if you see that has dust or anything else you need to clean it up. To do that, use a pencil´s eraser to rub up the surface. The pencil's eraser has tritured crystals that works like a light sandpaper and cleans all substances that prevents the electrical properties of this black material. Finally use ethyl alcohol or electrical contact cleaner, spray it over the black square and use a tissue to make a trully clean surface (it must have the same black color and looks glossy while you see it against a light source)
14.Now you need to clean the other electrical conductive black surface that reamains in the body of the touchpad. If you pay attention, you can see electrical paths, this paths works the same way like a keyboard or remote control to sense when you touch a key or a button. This black surface needs to be cleanead the same way you did in step 13.
15. If you make a good cleaning process that restores the electical conductivity of both surfaces, the fix is maked, you now have a Samsung´s YP-Z5 mp3 working again. You need to return all unmounted pieces to its position.
16. To mount (stick) the label over the plastic chasis of the touchpad, you don't need another glue, the same that remains in the label, incredibly is reusable. I recommend that before stick up the label mount on its position the plastic square that has the marks of Power On, Back, etc and then stick over the metal label (doing so, makes easy to align the edges).
17. Reconect the flex cable to the circuit board, secure it pull in the brown rectangular plastics of the connector to its original position.
18. Put the front cover of the mp3 on its original position.
19. Restore the two screws in the back of the circuit board, this screws needs that front cover will be on its position in orfer to tighten up.
20. Return the back cover to its position, don't forget the top plastic rectalngular and chromed protector and the ring for the strap.
21. Restore the outher four tiny screws and...
22. Ready, check your mp3. It must works now!
Posted on May 19, 2009
SOURCE: white screen!!
i need help too.. please help me?
my screen is ALL white and the touch screen isnt working anymore.
please help me!
i love this phone.. i dont want to get a new on
but it looks like i have to;
i really need help!
reply as soon as possible pleaseee!
thank you :)
Posted on Jul 05, 2009
SOURCE: Wooden piece puzzle square/rectangles various sizes coloured dots
it's okay I ended up finding the instructions. thanks.
Posted on Jan 03, 2010
When the dart hits it momentarily shows the score and then deletes the score with a verbal "miss".
Buy a dartboard that has no electronics. On these devices the dart stays in the place it arrives at and you can read the numbers on the board to see what the score is. This is far cheaper than repairing or replacing your electronic dartboard.
Dec 20, 2013 | Viper Eclipse Electronic Dartboard"
Tip
Frigidaire Dishwasher Error Codes and Service Test Mode
Many modern appliances have error code build in to the control programing to help with the diagnosis of a failure. Frigidaire dishwashers with display s will flash Er then a two letter error code.
Er i s a Switch error (Replace Console Pn# 154639207)
CE is a Configuration error (Replace Control Pn#154543602)
UO is a Vent that will not close. (Replace Vent Pn#154682301) or remove blockage
uF is a Vent fan Not running (Replace Vent Pn#154682301) or remove blockage
Other codes you my see in the display that are not errors
LO is Low rinse aid
PF is power failure
Ho is Water Heating
CL is close Door
01-24 hours of delay
Service Test
To enter service test you must turn off the power and PF will be displayed. While in PF press and hold Pad # 1 and Pad # 7 at which time an “rt” will appear in the display. To get it out of service test Press Pad # 1 and the Pad # 7 this will return you to PF mode.
[ (#1)(#2)(#3)(#4)(#5)(#6)(#7) (#8)(#9)(10)(11) ]
Press pad # 1 Active water valve Ultimate Scrub Maxx Clean Valve on =FL Valve off =rt
Press pad # 2 Test Speed motor (1 Time) motor @ 2800 rpms Speed Wash pad ”28′ First two digits motor speed
Press pad # 2 Test Speed motor (2 Times) wash motor @2950 rpms Speed Wash pad “29′ in display
Press pad # 2 Test Speed motor (3 Times) wash motor @3150 rpms Speed Wash pad “31′ in display
Press pad # 2 Test Speed motor (4 Times) wash motor @3450 rpms Speed Wash pad “34′ in display
Press pad # 2 Test Speed motor (5 Times) turns off wash motor No light on ”rt” in display
Press pad # 3 Test Dispenser dispenser powered Normal Wash on = “Sd” off = “rt”
Press pad # 4 Test Drain pump on/off China Crystal or Party glasses on = dP off = “rt”
Press pad # 5 Test Fan dry Active vent on/off Top Rack,Eco Wash Glasses on = Fan speed off = “rt”
Press pad # 7 Test Rinse aid level none Rinse only low = RE full = RF off = “rt”
Press pad # 8 Test Soil Sensor none Wash Silencer or Wash pressure on = sensor voltage reading off = “rt”
Press pad # 9 Test Thermistor none Wash Temperature on = Temperature in °F off = “rt”
Press pad #10 Test Heater on/off Heater on/off No Heat Dry on = HO off = “rt”
on Dec 23, 2009 | Dishwashers
Clicking sound and squealing brakes
Hi,Front brake pad worn out. This noise comes from the wear sensor rubbing against the rotor. Replace brake pad
- Presence of dirt or scored rotor.
- Dust plate bent and touching rotor.
- Contaminated brake pad
Read more about brake problems at this website
www.thecarproblems.com
Jul 20, 2013 | 2004 Kia Spectra
How is a dartboard setup and how is it scored?
Dartboards are divided into wedge shaped segments that are numbered non-sequentially 1 through 20. Each wedge is separated by wires which run to the center of the board. The center is made of 2 parts: the outer portion (which scores 25 points) and the inner portion (scoring 50 points). The wedges are subdivided by 2 narrow rings; the outer ring (double ring) scores as double the number indicated for that segment of the board, while the second ring (located halfway between the double ring and the bullseye scores as triple the number indicated for that segment of the dartboard.
Jul 26, 2012 | Sport & Outdoor - Others
F1 error code on the ERC. No replacement ERC from Sears (Kenmore) or GE (manufacturer). The oven temp sensor is within specs at 1100 ohms @ RT.
The F1 error code refers to one of the buttons on the touch pad being the problem and not spefically the erc unless on your model the touch pad is built in to the erc.On older model the touch pad was a different part on newer models its only part of the erc
Yes indeed 1100 ohms is the exact spec.for the sensor at room temp. however if the sensor were bad the error code would F3 if had a open circuit(infinate ohms) and F4 if it were shorted(zero ohms)
Jul 29, 2011 | Ovens
Rear brake noise after brake replacement
probably a dumb question, but if there is a backing plate, did you make sure it isnt bent and hitting the rotor? you never want to sand new rotors, although i dont think it would cause this concern. i would suggest lightly scuffing up the brake pads. this will eliminate any noise caused by the contact of the rotors and pads. if it goes away then you know its a problem with the pads/rotors.
scoring of only the inside rotors would make me think that possibly the caliper slides are frozen up. make sure they move quite freely on the slides. it is not uncommon for brake pads to score rotors though.
but brake noises at low speeds that dont' change when applying light brake pressure are usually some sort of metal or something contacting the rotor.
Mar 23, 2010 | Toyota Camry Cars & Trucks
How do i score bowling in a dartboard game
how to play and keep score BOWLING
This dartboard adaptation of bowling
is a real challenge! It is a difficult game
in that you must be very accurate to rack
up a decent score. Player one starts the
game. You must select your “alley” by
either throwing dart or manually pressing
segment of choice. Once alley is selected,
you have 2 remaining darts to throw in
which to score points or “pins.” Each
specific segment in your “alley” is worth a
given pin total:
Segment Score
Double 9 pins
Outer Single 3 pins
Triple 10 pins
Inner Single 7 pins
There are several rules for this game as follows:
1. A perfect game score would be 200 in this version of bowling
2. You cannot hit the same singles segment twice within the same “frame” (round). The
second hit will count as zero points. Hint: Try to hit each single to reach 10 points in
the frame.
3. You can score 20 points per “frame” by hitting the triple segment twice.
4. Hitting the double segment with your second dart will only count as 10 points if you
scored a double on your first throw. Otherwise you will score a total of 9 points by
throwing a double with your second dart.
Mar 03, 2010 | Halex 64339 Match Play Electronic...
Error code of "Er s" appears on the display and inside the light remains on at RINSE Low. HELP!
LO is Low rinse aid
PF is power failure
Ho is Water Heating
CL is close Door
Service Test
Let me know how this works out for you.
Benjamin
2 Volvo Questions?? First: My air from the vents stopped blowing on all speeds. It happened three days ago, then miraculously started working again while I was driving about 30 minutes or so later. It...
ok part one
the wiring may be loose or the switch is worn out & works intermtantly or there is a bad earth connection
ok part 2
the squeal my be built up brak dust! this caused by fitting pads that are TOO HARD!
you can get a different pad that will not squeal but also there could be a rattle plate thats causing it its the steel plate against the **** pad !
Cheers Rob
Aug 15, 2009 | 1992 Volvo 940
Ihave disc pad warning light on if I replace disc will computor recognize
replace the pads...there is a sensor on them that snaps in and when the pads get thin it will create a ground turning on the light...hope this helps
May 22, 2009 | 2005 Volkswagen Touareg
Toys Logo
216 people viewed this question
Top The Toys Experts
Paul Carew
Lawrence Oravetz
Are you a The Toy Expert? Answer questions, earn points and help others
