Question about Garden
I have a chariot jr 52in riding mower it starts but will not move
    Top Expert:
  • 10,875 Answers
Replace drive belt
Posted on Apr 16, 2015
52in encore mower that runs. When it wants 2, I believe it's a safety sensor that keeps I from starting my question is where is it located and is there more then just 1 besides the 1 under the seat
Sometimes there is an oil pressure sensor that shuts the mower down if no oil pressure is sensed within the first 30 seconds or so. It could also be something as simple as a loose wire in the ignition circuit.
Jun 13, 2016 | Garden
My Craftsman riding lawn mower LT2000 (2002/2003) stopped moving. The drive belt seems to be loose. The engine starts and cutting blade engages fine. Was working fine but stopped working when it started...
there should be a drive belt tensioner somewhere on the belt, it usually works off the clutch/brake, when you push on the brake it apply's the brake and also takes the tension off the belt to stop it from moving.
Not sure of your ride on mower but that is how my ride on mower works so I hope this helps.
May 19, 2014 | Craftsman Garden
My Weedeater riding lawn mower will not move in forward or reverse after it has started
Check your drive belt that it has not slipped off.. also check your drive lever on the right side (speeds, neutral, and reverse). The mower uses this lever to angle the motor against the belt to move it..
It is most likely the belt or the angle misaligned if the engine is turning...
Apr 21, 2013 | Weed Eater Weedeater 26" Riding Mower
Mower starts but will not go it is a lt1040
the mower deck and the drive system each use there own belt check your belts
Aug 07, 2012 | Cub Cadet Garden
1999 52 INCH GREAT DANE CHARIOT MOWER CONSTANTLY PULLS TO THE LEFT
if its a zero turn there are ajustments on the pussbars to even it out
Jul 24, 2011 | Garden
Just got the mower 6 weeks ago gas cap will not stay on if you cut around bushs. I have gotten leaves in tank,need to take tank off to clean it out. It is a YT 4000 42 in. cut 24 hp . thank B.M.Davis Jr.
Only around bushes? If you getting so close that the bushes are forced up against the bushes I recommend trimming this area, or use a push mower if the ground is in good shape for it, however if your not getting very close to the bushes I will need more info
May 20, 2011 | Craftsman YT 4000 42" Briggs Stratton 24...
I cannot get the tractor to continue running even after I add starting fluid. It runs as long as I add fluid. I bought a fuel filter , pump and hoses. I still can't get the engine to keep running. I...
I would take the carburetor apart and soak it in a solvent. It is very common for the fuel passages to become blocked by gasoline which has turned to a shellac type substance over a long winter of sitting idle. If it was running fine earlier this year then that is not the problem, but it sounds like a fuel supply and you have excluded the other possibilities so I would give that a shot anyway.
Nov 11, 2010 | John Deere 22HP VTwin Hydrostatic 42"...
My riding mower start but it wont move
Is it a Hydro, or belt drive?
Is Hydro on bypass?
Is the belt off, or broken?
May 05, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mower will run will not go foreward or backward
With transmission in neutral...start the engine and move the speed lever to highest speed and move it back to brake position, then shift the transmission into gear and move speed lever, this will fix the problem.
Apr 26, 2009 | Garden
Garden Logo
43 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
