Question about Plumbing
On my utilitech 3/4 sump pump. It had worked fine until now.2yrsold. The float is sticking. I took it apart and cleaned the shaft, and both floats and put a thin coat of Vaseline and reassembled. HELP
    Sergeant:
  • 290 Answers
That's why I buy Wayne pumps and not some store brand like Behr, Defiant or Utilitech.
Posted on Apr 16, 2015
  • Anonymous Apr 16, 2015
    That comment doesn't help me!
3 Suggested Answers
mkh5094
  • 145 Answers
SOURCE: just purchased a home with water ace sump pump.
That's the idea; if you lift the float the water starts pumping because it works off of that float. That type of pump is usually meant for water that is in a tub or bucket, so that when the water reaches a certain height and causes the float to rise allowing the pump to kick on. I use a pump like that to pump our the drained water from my washing machine in my basement, i let the water go into a big 50 gallon drum and then once the drum is half full i have it set so the float rises and pumps out the water. That being said, if you are putting this in your basement at floor level, you would need to get a 10 gallon bucket meant for sump pumps (you can get one at your local home store) and rent a jackhammer if your basement is concrete and put the bucket in the floor and the sump pump in the bucket, this is called a sump pit. Another option is to get whats often called a "floor ******" pump. Its a pump that sucks the water out when it reaches around a half inch of depth and it can be used in several feet of water (I've used these as well, there is no float involved), and it can be set on level ground there is no sump pit needed. The one thing with my pump you may not want, is that it's constantly running because its constantly monitoring for water so that a lot of water will not build up (especially if water can damage some thing in the surrounding area) . You can check out all the types at your local home store.
Posted on May 28, 2010
  • 185 Answers
SOURCE: My sump pump wont kick
Hello, the pump motor is controlled by the float switch. If your motor is running constantly even when you move the float switch around, then I would say that either the switch is shorted internally, or the wires going to the switch are shorted, thusly causing the motor to run. Is the float on a separate adapter to the pump, or is it wired into the pump?
joe
Posted on Jan 10, 2011
Need a new float switch for utilitech sump pump. can't find!?
Fixya does not sell replacement float switches.
Aug 07, 2017 | Electrical Supplies
I have a 12 volt emergency sump pump system SD-BSP. Sensor float failure.
If it is anything like mine the sensor is on a cord So what I do
is get some plastic wire ties and tie the cord part lower on the pump
so the float part does not have to move so far. cheap fix
oh BTW if you cannot secure it to the pump then maybe you have some vertical part you can secure it to .
GL
edward edwardaustinassociates
May 12, 2016 | Dehumidifiers
Motor would not start intermittently. Disassembled to determine possible problem.
The oil has to be there. Intermittent starting is usually the float switch hitting something in the sump. If the pump motor has a capacitor on it, replace the capacitor.
Aug 20, 2015 | Utilitech 1/3-HP Cast-Iron 95 GPM Sewage...
Sump pump does not go on all the time have to shake pipe to get it going so water doesn't overflow
There should be a float switch in the pit, sounds like its getting stuck and when you shake it it activates. Check the switch, the rod, etc.
Mar 01, 2015 | Utilitech 0.33-HP Thermoplastic...
We have a utilitech sump pump model #0313508. I am looking for the plastic, or metal standoff through which the float operates.
You might have to make your own. Think of stainless steel rod etc. Utilitech is not a universal brand. Parts are not available and the whole unit is expensive. Grainger does not have anything and it appears that the exclusive provider is lowes.
Sep 20, 2014 | Electrical Supplies
Why wont the pump turn on
If the pump is plugged in through a float switch the switch may be bad- try plugging the pump in by just the plug for the pump itself if possible -if that works then you need a new float switch.
Jun 10, 2014 | Utilitech 1/3-HP Cast-Iron 95 GPM Sewage...
Flooding carb
carb float is sticking,clean bowl good
Oct 12, 2017 | Yamaha RD 350 Motorcycles
Pump won't shut-ff
Hi Ron...
Check your float switch....sometimes they can get stuck to cause this problem of not shutting down after draining the orginal water.
Take the float switch and move it up and down...this may help to clear the stuck switch inside of the float
Bud
Apr 24, 2013 | Utilitech 1/3-HP Cast-Iron 95 GPM Sewage...
Pump not working
If power is going to pump and float switch is good, motor has fried, time to get a new one.
Oct 07, 2012 | Utilitech 1/3-HP Cast-Iron 95 GPM Sewage...
Fixed! Zoeller M53 won't turn on. Will turn on with a slight tap.
I had the same problem of pump not turning on unless I tapped the pipe to create a vibration. I took the float off and cleaned the grime / buildup. The buildup changed the buoyancy of the float (made it heavier) such that it did not float high enough to trigger the switch. Once cleaned, the float floats much higher above the water line and triggers the switch.
Apr 04, 2012 | Zoeller M53 Mighty Mate Iron Body, Poly...
Plumbing Logo
441 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
