Question about Proscan 37LC30S60 TV
How do I unlock the input on my proscan television
Have a 19" Proscan flat screen TV. Can't get the channels back.
Not enough info
Channels from the air cable/satellite/fios
Using the tv to change channels or other device.
Is the INPUT button on the correct input port
Sep 28, 2015 | Proscan Televison & Video
How to fit a sound bar to a proscan tv
1) Go the Sound Tab on the remote's Proscan menu
2) Set the system's "Digital Audio Output" to PCM (pulse code modulation)
3) Connect a coaxial cable from the Coaxial "jack" on the back of the TV to the Digital Input "jack" on the back of the sound bar.
It should work now!
Feb 05, 2015 | Proscan Televison & Video
Connecting sound bar to proscan TV
Proscan has released hundreds of models of televisions over more than two decades, so I can't be specific without more information. There are also hundreds of different sound bars on the market. The answer given should apply to all situations:
Ideally, the sound bar should be connected to the television using one of the methods (in order of preference):
  • Optical cable output from the television into the optical cable input to the sound bar; (best)
  • SPD/IF coaxial output from the television into the SPD/IF coaxial input to the sound bar; (really just as good)
  • RCA R/L outputs into RCA R/L inputs to the sound bar. (not nearly as good as either of the above)
Jun 03, 2014 | Televison & Video
How do I hook a DVD player up to it
If your Proscan TV has inputs for left and right audio and video, you can plug the DVD player in and select video input using your remote
Sep 28, 2013 | Proscan Televison & Video
I have a proscan CTC169CG5 CRT tv that has two composite inputs but have no idea how to switch them
Tune to 90 for S-video, 91 for input 1 and 92 for input 2.
90 and 91 uses audio 1 for input
92 uses audio 2 for input.
you may have to enable them in the setup menu.
tom
Jul 30, 2009 | Proscan PS27123 TV
Cant get picture or sound...Proscan 27113
You can tune to 90 for input 1 S-video, 91 for input 1 composite and 92 for input 2 composite only.
Most RCA and GE brand replacement remotes will work using code 000, or 001. I use code 237 for my 5 in 1 remote and can get PIP and the setup displays to work.
tom
Jun 15, 2009 | Proscan PS27113 TV
Proscan ps27108
are you changing the input to see it picture? have you connected the red input plug to the side of the tv?
Sep 09, 2007 | Proscan 19LA25Q 19 in. LCD Television
Proscan 37LC30S60 TV Logo
42 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
