Question about Marantz SR-5009 7.2 channel home theater receiver
I am not getting sound from the marantz 5009 receiver to the tv. I am using hdmi cables from receiver to the tv
    Sergeant:
  • 290 Answers
Huh? why? would you not want to get sound from the lousy TV speaker to the receiver and it speakers instead? That's how I have my Onkyo THX system set-up. My Samsung TV actually has decent speakers but even they are junk compared to a real speaker system. Even $500 worth of real speakers can sound better then the speakers on a $5000 TV. Do not do it.
Posted on Apr 16, 2015
    Top Expert:
  • Marantz Master
  • 10,875 Answers
The hdmi is only an input on your tv,you cant get sound from your tv to receiver using hdmi
How to hook up the TV
To use the TV as a Monitor: Use an HDMI cable from the Monitor Out on the 6006 to an HDMI Input on the TV. You need to go into the setup menu and set the HDMI sound to go to the amp and not the TV.
If you are tuning TV stations with an antenna and the TV tuner: First connect the TV as above so you can watch your other sources, like Blu-ray players. Then add an Optical Digital Audio cable from the output on the TV to an optical input on the TV. When watching antenna TV, select the input on the 6006 that the optical cable is connected to. You may have to play with settings in the TV and the 6006 to get this to work! You should be able to listen to 5.1 sound while watching tv over the antenna.
Mar 08, 2015 | Marantz SR6006
HDMI no longer working as pass through for Comcast and Tivo
sounds like your digital board is going bad. Is the unit still under warranty?
Jul 29, 2013 | Marantz Audio Players & Recorders
Hdmi to component connection for surround sound
Does you tv have an optical audio output? That would be the easiest way.
Jan 07, 2013 | Marantz Sr8200 Thx Ex Surround Dolby...
No image, only sound when connecting marantz sr 7005 hdmi out to hdmi in on tv philips 47pfl9632d
Whatever video components you have, they should be, depending on inputs on TV, should be run to TV first. Recievers do have pass through ports but, are not the best way to achieve picture and sound. HDMI cables are great but you r reciever may not be able to transfer the video. What I suggest is taht you run your componenets, cable/sat box, DVD, etc. via HDMI, componenet, etc., to TV input, then, run audio out from TV, via(best) digital optical. You can use TV's menu to choose what you watch while, you only have the one input to reciever. Scan your recievers menu to make sure you have selected the proper mode(TV, Aux, Vid2, etc.).. If you run your video unit to TV with component cables, you will have to get your sound through separate cable(s). Component cables have graet video, but do not carry the sound.
Jun 14, 2011 | Marantz SR7005 Receiver
New tv, new marantz sr5004, hdmi cable- no sound out of speakers
To really help you would require a bit more detail. HDMI is the video part of the signal - the audio part may require additional cables. Also, source material may play a role. I'd start by seeing if you have some audio outputs from whatever your source is and connecting those to the Marantz. Beyond that, I'd need more info to be sure I was giving decent advice.
Oct 22, 2010 | Marantz SR5004
I have a Marantz SR5004 AV Surround Receiver. There is an HDMI cable from the cable box to the Marantz and another from the Marantz to a Samsung HDTV. Everything is fine when the cable box is set to an HD...
Hello First off i would determine if the same thing happens when the cable box is connected directly to the TV with the hdmi cable.
If the picture goes out get a new box from your cable company.
If it works fine then its time to call Marantz
My Denon avr 4310 does a similar thing and after a lot of research it seems that the problem is with how digital signals are sent through the HDMI cable and how the control board of your receiver processes those signals.
Here what I mean
HDMI is meant to simplify connections by transmitting video, audio and CONTROL signals through 1 cable.
The problem becomes when you introduce a "middleman" in this case your receiver the control signal doesn't always get interpreted correctly.
My TV has the capability to "turn off" the "control" signal coming through the cable if yours does try that first (i have a sharp 52" led) this solved some of the issues.
My receiver has the capability to accept different inputs and merge them so here is how I get around the problem.
1. I use HDMI for video signal but also use the optical for audio this allows me to send the "complete" hdmi signal through the receiver and to the TV this complicates things but also allows you to get audio through your tv speakers so if you want to watch something late at night you aren't waking people up when the receiver gets loud. This stopped things like the video flickering or turning off.
You will have to play with your menu's to see if you can do this on your unit.
How to fix this easily? Dump HDMI and use component (red, blue green RCA's) for video yes its still HD and yes you will have to run audio separately. but it eliminates all the digital processing issues that receiver manufacturers haven't worked out.
I was pretty upset when I spent $1500 for my Denon receiver and Denon then told me that HDMI doesn't always make anything better.
Hope that helps
Feb 14, 2010 | Marantz SR5001
I have the following hardware: Marantz SR-4003 Receiver, Samsung LN52A650 HD TV, Samsung BDP-1500 Blu-Ray player, Scientific Atlanta Explorer 8300HD cable box, two Paradigm Millenia 20 LCR Bookshelf...
Remove the HDMI cable (out) to the speakers from the receiver.
Connect regular speaker wire from the receiver to the speakers.
Of course, remove the (now extra) HDMI cable from the tv.
That will remove the loop.
Jan 25, 2009 | Marantz SR-5600 Receiver
Compatibility with Samsung LCD Display
It sounds like the HDMI port on the back of your Marantz is damaged. if you know for sure that the HDMI port works on another tv still you might just use component connection because the visible difference between component and HDMI is not very recognizable.
Jan 13, 2009 | Marantz DV4001 DVD Player
When running video thru the amp, the pic flashes on and off
usually that is an issue of cabling and/or the monitor. The Marantz units are pretty darn stable. Check your setup to see if it is upconverting.
If you can, try a new HDMI cable to the TV. You could also try the second HDMI out, to see if there might be a problem with that particular output port. You can also try a different HDMI port on the TV.
Another thing to try is to directly connect your DVD player to the TV. If your cabling is all in walls, etc, you can get an HDMI coupler at a big box store for $15.00 or so. That will tell you if it is any of the cables, the DVD player, or the TV.
Jan 05, 2009 | Marantz SR7002 6.1 Channels Receiver
Marantz SR-5009 7.2 channel home theater receiver Logo
116 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
