Hoover max extract 77. It is leaking or spraying water only(sprayers)when in upright position after shampooing. Doesn't leak when turned off/on but does from catch basin under tank when pedal released
    Sergeant:
  • 290 Answers
Obviously, it is either not fully inserted or the seals are leaking.
These shampooing devices are very picky about how you insert each part. They are not as temperamental as their older models, which I tossed in the garbage after getting a heated model, but they can still be difficult to handle.
Now, on difference is when the handle is upright all suction goes to the attachment hose. The further you lean the handle down the more suction goes to the lower compartment but you said it is leaking from the bottom. I suspect your supply chamber is the leaking area. You are just noticing is more because the lower section has less suction you suck up any leak before you see it.
Posted on Apr 16, 2015
SOURCE: Hoover Steam Vac clean water tank valve leaks
Honey! It's broke. You can manuever the little black valves out, but you will only find the hole in the clean water tank. I have the EXACT same problem. My advise to you is to take the valves, caps and handle off, sell them on EBAY and then buy you a whole new clean water tank.
Posted on Nov 18, 2008
  • 190 Answers
SOURCE: water tank leaks
If the tank is leaking, when removed from the cleaner, it is not user serviceable.
Posted on Oct 03, 2009
  • 190 Answers
SOURCE: Hoover Steam Vac V2 Deep Cleaner leaking clean water
Fill the tank and determine if the plastic is leaking, or if the valves are leaking. if the tank is cracked, it would need replaced. There is an improved design now available.
You may cycle the valves on the bottom with the eraser end of a pencil.
  • 190 Answers
SOURCE: hoover steam vac leak from the bottom when tank
The tank is not sealing to the black rubber ring seal on the lower handle. make sure this seal is not displaced.
Posted on Nov 20, 2009
  • 240 Answers
SOURCE: My Hoover SteamVac Max Extract 77's dirty water
There are several possibilities for low pick up. The most common problem is that the lid is not correctly seated on the recovery (lower) tank. It is also possible that the rubber seal on the motor standpipe is out of place. The round tube on the bottom of the tank sits against the seal. Remove the tank and look for a large rubber ring on top of a plastic pipe. A less common issue is damage to the rug nozzle because the screws holding it against the carpet have been broken loose by dropping the shampooer on it's nose.
Posted on Jan 22, 2011
Hoover max extract 77 manual
Hi! Follow the link below to view the manual for the FH50240. Hope this helps!
http://hoover.com/file/611/
Jul 19, 2014 | Hoover Max Extract 77 Carpet Cleaner -...
Why does my hoover max extract leak water onto the floor?
seals faulty, replace or shop replacement if within guarantee
Jun 28, 2014 | Hoover Max Extract 77 Multi-Surface Pro...
Hoover max extract 77 wont pick up water
did you make sure the dirty water tank is cleaned out and the cap is on?also did u check the clear kinda hour glass shaped thing in the front where the water sucks up at to make sure there is no blockadge?
Mar 30, 2014 | Hoover Max Extract 77 Multi-Surface Pro...
My max extract 77 hoover wont spray
Make sure all water lines are not clogged with anything 1st. Then check to see if the switch/lever or button that actuates the spray is functioning/working. If it's a mechanical switch/lever etc, see if you can take it off and clean it thoroughly and check to make sure there are no broken parts. If it's an electrical switch/button or lever, you need to check and make sure it's clean, and all the contacts to wires are NOT broken or damaged. You may have to replace parts if they don't function.
Oct 15, 2013 | Hoover F6055-900 SteamVac Maxextract LS...
Max extract is leaking
this link is for the diagram of all parts, you will need to check all the seales and O rings and for cracks in the tanks.
http://www.ereplacementparts.com/images/hoover/F5914-900.pdf
Nov 09, 2012 | Hoover SteamVac F5914-900 SpinScrub...
Hoover max extract 77 water tank leaking
Remove the little black plastic plug on the bottom of tank (has a metal spring around it), that is where it is leaking. Wrap Teflon (pipe tape) around it and the spring. Replace black plug. Not a permanent fix, but can help if you are on a bind. It worked for me.
Sep 09, 2012 | Hoover F5505 SteamVac Spot Vacuum
WHERE DO YOU PUT THE SHAMPOO IN THE PRO SHAMPOO MACHINE THERE IS A CONTAINER IN THE BACK AND THERE IS THE WATER BAG IN THE FRONT SECTION
The shampoo solution goes in the back container. The clean water goes in the water bag in the front section.
If you need parts you can find them below
http://www.usavacuum.com/category-s/387.htm
Make sure to give positive feed back.
Thanks. USAVACUUM.COM
Mar 07, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell steam cleaner will not spray shampoo
My Bissell stops releasing shampoo when the handle is lacked upright, when there is no water in the tank (the most common cause of this issue), or when water is not flowing through the machine because the sprayers are clogged.
Make sure the shampoo container grommet is releasing properly when you press the trigger. To check this, remove the shampoo tank from the Bissell, stand over a sink, and use a finger to push up inside the grommet on the shampoo container, the part of it that mates with the rest of the Bissell. Shampoo should dribble out when you do this. If it won't, the grommet may be clogged.
May 29, 2009 | Bissell 7950 ProHeat Upright Wet/Dry...
Heating & Cooling Logo
1,022 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
