Question about Proscan 37LC30S60 TV
How to unlock input - Proscan 37LC30S60 TV
Micromax i am forgotted my phone lock code
Micromax q75 phone lock ? : Solution: If you have not changed the default phone lock code for your micromax q75 phone. Then use "0000"(four zeros is the default code) and press the home button(top left most button and not the green sim 1 button). If you press the green button it will say " Emergency calls only" it means you are clicking wrong button. hope this helps you.
Nov 03, 2010 | Swiss Tech MicroMax 19in1 Multi Tool Clam...
Need to reset input code on Mitsubishi tv with remote I am able to bypass the blue screen of annoyance by holding ''QV'' and 9, but I do not know how to create / reset the password.
In the advanced menu from the main you should be able to navigate to the lock input, when you try to unlock the input it will ask for the code. Just press the QV + 9 and this will unlock the input. Then you can either create one or just leave it unlocked.
I hope that this helps you with this issue.
Thanks for usning Fixya.
asnowman
Oct 18, 2009 | Mitsubishi WS-55511 55" Rear Projection...
How do i unlock my phone
Dear if you have no code or any idea, its the best way you should install its software. After install software your phone will unlock and now you can choose your lock code by yourself own your choice.
Good Luck
Sep 06, 2009 | LG Cell Phones
2000 4.6 range rover suv
You require an unlock code/ security code from the dealer. This will consist of 4 numbers. You can then input this code into the door lock to clear imobiliser. You will have to do this every time until you have your remote replaced or repaired. There is a procedure for inputting the code. What the display through the window with the door closed. You need to turn key to unlock or lock (depends on model) until you see the display react to your input. Once this happens you are ready to input the code. If for example the code was 3241 and you have turned it 4 times to the unlock position (most likely) you would start by turning it 3 times to the unlock, 2 times to the lock, 4 times to the
unlock, 1 time to the lock, pause then unlock the car and start the engine. It sounds tricky but once you get the hang of it its not too bad. If when you start to input the code it starts locking and unlocking the central locking is is not accepting the code. The difficult bit is getting it to recognise you are inputting the code. The central locking will do nothing during the code entry. Best doing this when the light is fading as its easier to see the display in the dashboard. Thats it, all you've got to do now is find the code. Often on a card inside the owners service books if still around!!
Good Luck John
Dec 16, 2008 | 2000 Land Rover Range Rover
Phone unlocking
I am sorry, I don't do phone unlockings. Thats not my area of expertise. Please try another expert. I believe a chap called Ekse could do this for you..
I do apologize.. And oh yes, please do not rate this post at all, as I did not provide any solution..
May 11, 2008 | Samsung SGH2100SGH600V300 Unlock/Unlocking...
Samsung sgh-c170 can not unlock my passed word can not remmber it help
1. Insert unaccepted sim to phone.
2. Input *2767*3855# and phone will reboot and will be temporarily unlocked.
3. Input *7465625*638*00000000*00000000#
4. Input #7465625*638*00000000#
5. Input *#7465625# to check the locks....all locks should now be inactive.
I tested it in my Samsung SGH-C170 without a SIM card and it did work till #2.
May 01, 2008 | Cell Phones
I Keep getting the message: "dig. unlock" when I go to record a CD
Here is what I grabbed from the manual.
The message Dig.Unlock Means:
"There is an incomplete connection of the digital input jack during
digital input recording, or the input signal is not being input properly
due to some other factor."
Mar 03, 2008 | Denon DN-C550R 2-Disc CD Recorder
Phone Freeze
hi there maybe i can help
insert a different sim to your phone then
input this code: *2767*3855# wait till it reboot2.gif
now your phone is open next input this
code: *7465625*638*00000000*00000000#
next again input another
code: #7465625*638*59258259#
finish now your phone is permanently unlock.
feel free to use any sim...... ok!
* if the second code you input, didn't work go dierictly to the last code ok......
peace!
Dec 14, 2007 | Samsung SYNC SGH-A707 Cellular Phone
Sony receiver optical sound "unlock" str-de898
Just fixed it, The Optical cable wasnt properly plugged in on the other end.
Found the fix here:
http://esupport.sony.com/US/perl/model-home.pl?mdl=STRDE945&LOC=3
Oct 09, 2007 | Sony STR-DE898 Receiver
Proscan 37LC30S60 TV Logo
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
